Real-Time On-Bike Headwind Indicator
I live in an area with high winds and very unreliable forecasts. I can't stand going out on a ride with supposedly 6mph winds and finding the wind so strong that it ruins the ride. I thought maybe it would help to have a real time indicator of wind on the bike.
unfortunately it doesn't work. The screen on the anemometer can't be read while sitting on the bike outdoors unless it's in direct sun. The phone display, in addition to covering my smartphone bike computer app, is too small to read without crouching and squinting.
the anemometer doesn't indicate wind direction so I'd have to sort that out in my head based on my speed and the reading. I haven't tested it enough to know how much hassle that would be.
I'm probably returning all this stuff.
the CdaCrr app with weathermeter anemometer looks really good but it's not what I'm looking for, I want a bike computer with bluetooth anemometer compatibility. CdaCrr looks looks like it's intended for recording runs and analyzing later.
And as awesome as I'm sure the $300+ power meters are, I can't justify spending that much and I'm not sure they display real time wind anyway.
so then I thought about making my own, maybe a weighted vane design.
has anyone else dealt with this problem? Any suggestions? I estimate that in the past year the wind has ruined more than half the days for biking. The anemometer won't change that but it could help psychologically and make it more tolerable, until the day I can move.
Quoted: 821 Post(s)
Liked 1,655 Times
If it seems too windy to ride when you start out, then don't ride.
An anemometer really isn't going to help you much if you're out riding, and suddenly the wind picks up. You'll know when that happens without the instrument. Power meters measure watts you are pushing through the crankset, not wind, although your watts will be higher into a headwind vs. flats for the same road speed.
I'm not aware of any bike computers that are compatible with an anemometer. BTW, where do you live where's it so windy it ruins half your biking days?
Likes For Bald Paul:
I'm 1.1 miles south and about 5 or 6 miles west of the NE corner of Colorado.
Quoted: 1277 Post(s)
Liked 1,392 Times
no idea where you live, but it's windy AF here most afternoons, with 30+ gusts crossing the bay and in exposed areas near the water. it's fairly predictable though, so i use the sailflow site, which has the most measuring stations i've seen publicly available, and includes charts over time for average, gust, and direction.
the charts over time can help you spot patterns. as cool as the idea of a weather station on your bike is, do you live somewhere where you really don't know before you set out if it's going to be windy? and if you hit a fierce headwind, you would know - and just turn around or deal, no?
Quoted: 2952 Post(s)
Liked 3,106 Times
A powermeter won't tell you anything about the wind, just the power you're putting into the bike. This is actually a benefit in a way. If you're doing power-based training, it doesn't matter how fast you go, just how much effort you give for the defined time interval. So on windy days, I'll do my work intervals into the wind. Psychologically it feels better to be pushing into the wind, and because you go slower (and therefore a shorter distance for a given time) it shortens the amount of road you need to complete the interval. It's changed my attitude towards windy days--now instead of ruining a ride, it feels like a good day to work.
Roadie
Quoted: 23 Post(s)
Liked 57 Times
I have the same problems in the open farmland where I ride. Accuweather says 4 MPH and I swear I hit long stretches of 15 MPH headwinds. Humidity seems to add a few more degrees of difficulty. The real problem is that no matter what direction I go in, I always seem to be going into the wind!
Likes For Pinelander:
Likes For mschwett:
Holy cow that sailflow site may just solve my problem.
unless it's crank based I think your power meter has to have a wind reading. Maybe not user accessible.
Kinda like your power training, my plan was to get a wind reading and then when I'm biking just think of the wind as invisible hills and valleys, and when it gets ****** just tell myself I'm climbing higher than the Rockies (only like 14.5k'). Either shorten the ride or just know I did a lot more effort.
There's a station north of Ovid on road 29 and I wanted the data from it but didn't know where to look. Unfortunately it's not on sailflow either.
maybe it's private? It's all farms around here.
Quoted: 1461 Post(s)
Liked 1,485 Times
I find apps like Windy and Sailflow to work pretty well at forecasting wind speed and direction. I also have a general weather radar app that includes a wind direction layer on it that is usually pretty accurate.
I use these when heading out on a ride to decide which direction I want to go. I like to start into the wind so I get a tailwind on the way home, whenever possible. My rides start in the city so often the wind is doing something different once I get out away from trees/buildings so I can't always rely on the "look outside and see which way the wind is blowing" technique.
I'm not sure a handheld windspeed indicator is going to provide much valuable info once you're out on the bike. At that point, you've already made the decision to ride and selected a direction. If a headwind or crosswind is too stiff, you just turn around. I'm not sure why you'd need to see data to confirm that decision.
Liked 1,392 Times
Likes For mschwett:
now they use gps, accelerometers, a pitot tube, temperature sensor, barometer, e.t.c.
Likes For asgelle:
Quoted: 20810 Post(s)
Liked 9,456 Times
Direct force power meters, which are the vast majority in use, use strain gauges - no wind wizardry needed. There's are some meters, like the PowerPod, that infer power by way of incorporating air speed, bike speed, acceleration, slope, etc. I would assume that you'd be able to easily tease out wind speed with one of those devices, but I don't know - meaning I've never looked for it - if that's a data field that head unit manufacturers have embraced/made available.
Liked 3,106 Times
Liked 9,456 Times
Liked 1,392 Times
no, the vast majority of power meters do NOT use gps, pitot tubes, etc. they must have internal accelerometers (or similar) in order to deduce speed of rotation, which they report as cadence, but all other sensors (like temperature) are for calibrating the strain gauges and nothing more.
Imagine flat highway as far as you can see, you're pedaling hard but barely moving. No speedometer, no wind meter, and you'd be kind of like AARGH WTF right? I thought this was a fairly normal reaction, and the logical next thought is, "how fast is this accursed wind anyway?" "What would be my equivalent ride distance with no wind?" "At what wind level do I give up?"
Meh. If you're riding at, say, 200 watts, a headwind will slow you down and a tailwind will speed you up. But it's still 200 watts.
in the 80s? what?
Liked 1,392 Times
from the DCR review:
With a Quarq DZero unit the company does their 10K temperature compensation for each unit that leaves the factory, which means they record how the unit responds to a massive temperature range, ensuring higher levels of accuracy at any cycleable temperature level.
With regards to temperature compensation, German road bike mag TOUR has a powermeter test in its current issue. Lab and field tests which included temperature sensitivity tests (lab). They always take an engineering approach to testing.
They concluded that the Dzero temp compensation does not really handle larger temperature changes very well. The competition seems to do this better (Infocrank, 2Inpower, SRM, P2M NG). Now I’m a little bit concerned about my Dzero’s accuracy.
