Look Keo Clip in pedals not working, pls help
I bought my first pair of clip in pedals and shoes.
Pedals are Look Keo Classic.
Set them up, tried to clip in but physically couldn’t even with all my weight on one pedal.
Wound the tension down to as slack as possible.
now they clip in but as soon as I take the pressure off they clip right out again.
So, I increased the tension, slightly, thinking it would hold better but again I physically can’t clip in.
Any suggestions?
Any suggestions?
Quoted: 1819 Post(s)
Liked 1,696 Times
Take them back to where you bought them. I have been using Keo pedals since they first came out and have never had any problems with either clipping in or retention even at the lowest spring setting. There has to be a defect with yours.
Quoted: 839 Post(s)
Liked 1,061 Times
+1^^^. Pretty rare these days with shoes being compatible with most cleats but if you installed the cleats and had to force them to bend to the contour of the shoe when screwing them down this could also be a problem. A little bending is normal but too much and it won't fit the pedal properly.
I can get the front of the cleat in, no problem, it’s just the back that won’t go. Cleats came with the pedals and fit on the shoes nicely. When I take my shoes off and look at the cleats visually they look like they will fit in the pedals but I cannot get them to go that last little bit and clip in.
Liked 1,696 Times
Likes For Joeymckay:
Backwards or upside down? I think the triangular shape mount would make it impossible to mount backwards with the toe facing back. My first thought was upside down.
Quoted: 1944 Post(s)
Liked 2,164 Times
Good job figuring it out.
John
John
Quoted: 114 Post(s)
Liked 119 Times
I know I've done similar, but I never admit it and just blame the cat.
Likes For MudPie:
Quoted: 839 Post(s)
Liked 1,061 Times
Ha ha, don't feel too bad. I remember a local TV station had a segment on bike safety and the "expert instructor" had his helmet on backwards the entire time.
