Ever Crashed Due To A Flat Tire?
Quoted: 539 Post(s)
Liked 44 Times
The best for avoiding flats is tires with flat protection built in. Tire liners need to be positioned right, if they're off position they can accidentally wear a hole in the tube themselves.
I've had a few nervous moments from the bike wallowing with a soft tire but none of them have put me on the ground. Knock wood, my crashing has been off road on loose stuff or mud and not where I could get really badly hurt.
If the OP is really paranoid about flats, somebody was touting a project on Kickstarter to make a bicycle sized version of the Bib Mousse foam "tube" used on dirt bikes. This sacrifices some ride quality and speed but it's almost impossible to flat.
contiuniously variable
i crashed yesterday beacuse of a flat front that i forgot about. when i got on the bike the first thing i did was stand up and peddle and as soon as i was turning the corner the flat tire sliped on the road and the whole bike want down with me miner cuts and scrapes and some road rash on my back it sucks.
Quoted: 1062 Post(s)
Liked 665 Times
Yup, a few weeks ago. I was nursing a low front tire, pumping it every mile or so, trying to get home. I reached a turn that I've taken 1000's of times, and didn't think about the tire. I went down hard.
Quoted: 18378 Post(s)
Liked 4,512 Times
I don't think I've ever had a flat cause a crash. Lots of experience with flats, but not crashes due to flats.
I have, however, had crashes (road cracks) that caused flats.
I have rolled sewups before. Probably due to being too lazy with gluing. I don't think it caused me to crash though. And that has been an awful long time ago.
As far as flats, I can usually feel when the tire starts bumping, when pressure is low, but not quite completely flat.
Quoted: 5791 Post(s)
Liked 2,581 Times
IMO - a flat should never lead to a crash. Decent bicycle handling skills should allow us to manage the consequences of even a sudden high speed blowout.
However compost happens and life doesn't always as it should, and sometimes circumstances conspire to remind is that should and could are very different notions.
So, IME, yes I've had the bike lay me down because of a flat. Ironically, despite a great number of high speed tire failures (tubular tire road bike), I've never had a crash that way. My bad luck wasn't a sudden blowout, but rather, a slow leak in the front wheel's 1.9" tire which wallowed when I attempted to turn into a driveway. The circumstances ensured low speed, so the injury to pride was more serious than my skinned knee.
FB
Chain-L site
FB
Chain-L site
Bikes: 2008 Dawes Haymaker 20XX Leader LD515 TotoCycling Road Bike
Quoted: 27 Post(s)
Liked 32 Times
Nope. The only instance where I would lose control from a flat would be a complete blowout on a high speed descent while leaning heavily into a corner. If I get a flat there is enough time for me to react and slow down.
Quoted: 4806 Post(s)
Liked 3,931 Times
This may sound crazy, but I am thinking about converting the commute bike to tubulars with sealant. I've had flats with tubulars, including one where the tubular casing actually blew in half (it was an old tire that I should have replaced) and the bike seems more controllable with a deflating tubular than what I've experienced with deflating clinchers.
Commuted on tubulars for decades. I see real advantages. The fast change in any weather, any conditions (not limited to being sober or awake), no flat two miles later from whatever caused the first on and is still hanging out in your tread, rimstrip, etc. and if your life or bike depends on a fast change, you can always do it. (Flatting in unsavory neighborhoods at night ...)
I always used Tubasti in part because the rim stayed sticky enough for a reasonably secure with a dry tire. Never cleaned the rim. Always felt the rim/cement interface, once good enough to survive tire pulls, should be left alone and just added to.
My current city bikes are still running Paselas as the rest of my bikes are going tubular. Won't make the switch until a tire shows me it's commuter ready (and comes in 28c).
Edit: I plead guilty to answering an old post but my testimony stands.
