So much for saddles with carbon seat rails
Zen Master
Just moments after ordering a saddle at a friend's bike shop, I was talking to him as he lifted a 15lb CF road bike to clamp into the stand, holding the back of the saddle and stem as he lifted it. As the bike got up to about shoulder level the saddle just ripped off in his hand. I immediately said "That saddle I just ordered doesn't have carbon rails does it?" Both rails failed right where they were clamped. It was pretty impressive.
Ron - Tucson, AZ
Ron - Tucson, AZ
Zen Master
The setup looked pretty much like a newer factory build. The seat clamps were a good 2" long at the rail contact/clamp area. I didn't pay much attention to model clamp this was but could gather that info come Monday. I'm not worried; I don't ride on carbon rails.
Ron - Tucson, AZ
Ron - Tucson, AZ
Prefers Aluminum
Bikes: Wife: Trek 5200, C'dale Rush Feminine, Vitus 979 Me: Felt S25, Cervelo Soloist, C'dale Killer V500, Miyata Pro (fixie)
If the bike weighed only 15 lbs, it seems odd that it failed when he picked up the bike by the seat. If anything, I'd think that the rails would have failed when he installed the seat and rode it around, because that would have put a lot more pressure on the seat and rails. Of course, he might have just installed it and hadn't ridden it with the new seat.
QUOTE=Nick Bain;12966353]was it a Chinese seat?[/QUOTE]
I have two "Chinese" carbon/carbon rail saddles (Merek off of the bay). I weigh 220lbs and have'nt had a single problem. Fantastic, super light, comfortable and cheap. About 1K KMs on each and no probs what-so-ever. IF one breaks I will definitely buy again with no hesitation.
The one that broke must have been a cheap American Knock-off of a Chinese one.[
Zen Master
Ron - Tucson, AZ
Ron - Tucson, AZ
Passista
Quoted: 890 Post(s)
Liked 752 Times
Maybe they're engineered to stand a lot of downward force but not the opposite way? But what do I know, I have a superstitious fear of carbon stems, saddle rails, etc...
Super WW
Bikes: A really light one and a really heavy one.
Quoted: 70 Post(s)
Liked 43 Times
In my 4 years of carbon saddle use, my first one failed when the rails "pretzeled"- used the wrong type of seatpost w/ it (halfpipe cradle and beams). But, not catastrophic- they replaced that one w/ a brand new one and after slightly over 2 years, the rails failed- but again not catastrophic- the material started splintering. I was on a century ride and I noticed my saddle leaning back. That said, I was able to shift my weight forward on the saddle and alternate w/ standing and finish the last 35-40 miles of the ride w/out incident.
No catastrophic failure. Now using an ax-lightness saddle.
Should Be More Popular
Quoted: 22732 Post(s)
Liked 9,101 Times
The one that broke must have been a cheap American Knock-off of a Chinese one.[[/QUOTE]
I also have a Merek saddle with no problems.
Certainly one should be careful with carbon anything, but I would not damn all carbon-railed saddles based on one failure.
Bikes: COLNAGO CLX AND ENIGMA ECHO
I have Fizik carbon railed saddles on two bikes both of which have covered many thousands of miles. Something was clearly wrong with the saddle/clamp/fixing arrangement in the OP example.
Administrator
Bikes: Cervelo C5, Guru Photon, Waterford, Specialized CX
Quoted: 1108 Post(s)
Liked 2,218 Times
Yeah, either the clamp wasn't the correct one or it was over-tightened or both. CF rails are strong when you follow instructions
