Help !! Sachs Orbit 2 x 6 indicator chain side axle nut needed - 10mm x 1mm
Hi Everyone,
Does anyone know where I can get a 10mm x 1mm pitch nut - suitable for an indicator chain ?
The only ones I can find are imperial or 10.5mm.
I'm in the UK.
Any help gratefully received.
I'm in the UK.
These people say they have m10x1.0 nuts.
Bianchi Goddess
Quoted: 2930 Post(s)
Liked 2,927 Times
I think Unknown is talking about a nut like on a Sturmey Archer hub.
you may have to buy a standard style 10x1.0 nut and a 1.5 sturmey and the find a tinkerer to make what you need
Sugar "Kane" Kowalczyk
Quoted: 303 Post(s)
Liked 136 Times
10x1M is a standard thread size for RD threaded mounts, some of which have
backing nuts. It was also the standard size for threaded rear axles of yester
year when sealed bearings were rare and threaded cones and nuts were all
10x1M in size. These would all be fairly thin, under 3mm thick in hex form,
cones thicker of course. An older bike shop may have a box of spares stashed
from that era. www.twowheelsgood.co.uk was mentioned as a source of 2x6
and 3x7 Sachs gear nuts, and they mentioned the really odd 10.5M nut.
Standard nuts such as the source mentioned in prior post are going to be thicker
than hub nuts. You will need to determine how thick the nut must be or if it
is a non standard form factor. A removed or spare RD mount from bikes that
use these as 'breakaways' to save the CF frames could be reshaped, but these
are soft aluminum with limited strength.
Quoted: 2026 Post(s)
Liked 1,096 Times
M10x1 is the threading for almost all rear axles so any locknut would have that thread. Shimano hubs are still cup and cone so the locknut from any of them would fit. I expect any LBS has a box of spares.
Bikes: Planet X Kaffenback, Homebuild eBike, 26" folding MTB & tadpole tricycle
Defining the requirement more
I understand what is being asked for here, but unfortunately can't actually help with a source.
If you look at the cut-away picture below, the nut required is that on the right hand axle (the other nut is any standard M10 x 1 axle nut).
The axle has an indicator chain running through it to operate the gear change. To guide the chain the nut must have a smaller diameter on the outside, which can be seen in the image. Also visible is the radius (also required) on the outside to assist the chain in turning 90° to go forward to the gear change cable.
Unfortunately it appears all Sturmey Archer hubs are imperial, either 3/8" or 13/32". Most metric hubs are now M10.5 x 1 (which seems to be the current hub gear standard) but not many of them use indicator chains.
Good luck in the search
Quoted: 303 Post(s)
Liked 136 Times
Had that picture in the back of my mind, thinking back to my Hercules 3 spd which had a nut like that, cerca 1954 maybe, the indicator chain being the
trigger.
trigger.
https://www.sjscycles.co.uk/sturmey-a...646-prod19212/
https://www.sjscycles.co.uk/brompton-...gra-prod13621/
You should see, these sit over the axle-nut and, and have a roller
for the indicator chain to change direction.
that may let you adapt to the situation.
Gear Hub fan
Bikes: Civia Hyland Rohloff, Swobo Dixon, Colnago, Univega
I note that the OP says thatthis is to fit a Sachs Orbit. That is old enough Sachs so the axle threading in question may well NOT be 10mm. Most older Sachs hubs and still SRAM T3, P5 and S7 hubs, which are basically older Sachs designs, use what is listed as a "FG 10.5" axle threading and nuts. This is per the 2010 SRAM IGH technical manula information. FG nuts were a special German cycle industry thread size per what I have read.
What the OP probably needs is a current SRAM T3 or old Sachs Torpedo right side axle nut to get the correct threading. 10mm, the old FG 10.5 and Shimano IGH axle nuts are all different enough threading so they are not interchangeable. Close but no cigar!
Gear Hubs Owned: Rohloff disc brake, SRAM iM9 disc brake, SRAM P5 freewheel, Sachs Torpedo 3 speed freewheel, NuVinci CVT, Shimano Alfine SG S-501, Sturmey Archer S5-2 Alloy. Other: 83 Colnago Super Record, Univega Via De Oro
Visit and join the Yahoo Geared Hub Bikes group for support and links.
https://groups.yahoo.com/group/Geared_hub_bikes/
Guess again
I looked back at the SRAM technical manuals back to 1999 and all the SRAM hubs, i.e. those since the Sachs Orbit 2x6 hub, used 10.5mm axles.
What fietsbob suggested is a good idea and would do the job, but I don't think they are as robust as a steel lead-out nut. I know the bike the hub's for is a MTB folder and the indicator chain is on the inside of the fold and will potentially be hit by the front forks. Will those plastic pulley roller guides withstand that abuse for long?
Ideally what is required is an M10 x 1 indicator nut.
There are no nuts in doughnuts.....
I'd like to thank everyone for their suggestions and respectfully point out that the title says '10mm x 1mm'.
Yes, I have tried a 10.5mm nut and it's far too loose to even tighten down.
A nut similar to the traditional sturmey archer nut, but with the correct thread for the axle would be ideal.
Any ideas anyone ?
Any ideas anyone ?
Calling SJS is worth a moment on the phone, or Email them..
would they be durable?
derailleurs are not durable if you crash on them ,
so bypassing the practical in quest of the perfect ..
Normal shop type kludge: You could get a Sturmey indicator nut ,
braze over the threads,
then re thread them with a 10x1 tap.
I have a short indicator nut made to go on top of a separate
Nut to secure the hub to the frame
there are sram/sachs hubs used in Mk 3 Bromptons,
same thing, nut holds the hub, in Bromptons case
a washer holds the chain tensioner assembly by the second indicator nut
which is not really needing to be holding the hub to the frame.
Brompton has an exploded diagram on their website, Bertie, as part of their parts numbering explanation. PDF download .
Yea West US to UK is not going to be cheap for postage ..
would shift the whole hub, not a few small parts rendering the rest useless.
Gear Hub fan
Unfortunately tatfiend you are wrong, the Sachs Orbit is a M10 x 1 thread as I know that he tried a SRAM T3 nut on the shaft and it was very loose. I also know that he tried a standard M10 x 1 axle nit on the shaft and it is a perfect fit and one will be used for the non-indicator chain side.
For some reason apparently Sachs made the Orbit indicator side axle threading 10mm, different than their other hubs at the time. That appears to make the needed nut practically a collectors item with no current equivalent.
Orbit 6 x 2 with a drum brake built in. laced up and used for a while 13 -32 cog cluster ,
not really a cassette, but the body is part of the hub, not a screw off freewheel..
Will trade for a liter tin of Rohloff all season oil ..
You got independent testing to refer me to. ?
the stuff I get in the little vials adds Molybdenum powder which is another lubricant material.
buffers the gears banging into each other..
Constant mesh gears aren't likely to be banging into each other.....
A modest controversy over terms here ... not all your teeth of a planetary gear, touch all the time,
like a a 60 tooth annular gear , and a 20 tooth planetary rotating inside it.
now 60 teeth in a 60 tooth , would be more a splined connection , than a gear ratio,
but it would be constantly meshed.
I'm discussing just getting another maintainence oil change kit with another dealer in an neighboring state's largest metropolitan area. apparently I should just buy the whole kit, including the fill screw.
cleaning oil , draining, and then filling with the 'all season' stuff..
since I just commute a few miles into town center and back ,
rather than trying to best the circum-cycling around the world record of someone half my age..
My miles per month is not impressive..
was thinking of topping off
the hub to make up for seepage past the seals ..
10 ml out of the 25 of a full change.
The hub doesn't need much oil in it and an extra 10ml might be too much.
You don't need to put 25ml in for an oil change anyway.
TBH the whole point of an oil change is to flush particles out - diluting contaminated oil won't - in any way - reduce the amount of unwanted particles in the oil.
Equally, not flushing it will leave more than a desirable amount of undesirables in the hub.
Compromise - flush it out then refill but only put 1/2 the 25ml of fresh oil in and don't buy drain plugs that you don't need.......
