Headlight Suggestions?
Commuting Fool
Bikes: 1988 Miele Azsora, 2022 State All-Road 4130, 2003 Jamis Coda Comp, 1983 Specialized Expedition, 1994 Norco Monterey
Quoted: 104 Post(s)
Liked 72 Times
Specialized pizza rack has a seemingly handy mount for a headlight, but I haven’t figured out a way to use it. It appears that it is not threaded. Any headlight suggestions for this type of mount or a clever way to attach something? I’d like to keep it low budget, but bright enough for night riding.
Commuting Fool
Quoted: 104 Post(s)
Liked 72 Times
This is what I’m going to try. I decided to post in the case it helps someone somehow. It took a bunch of searching around and contemplation. The only concern I have is keeping the single bolt from rotating and having the accessory bar swinging from side to side, but I’m hoping lock washers and locktite will help. The Cateye 400 seems like a decent amount of light at a reasonable price to quality ratio.
Happy banana slug
Quoted: 1533 Post(s)
Liked 1,530 Times
I wonder if that mount is for a dynamo headlight like this one? Or for a reflector; but that would be just dumb. Good luck with your hack.
Likes For Korina:
Mostly harmless ™
Bikes: Heavy, with friction shifters
Quoted: 1107 Post(s)
Liked 216 Times
To see the road (and potholes) at higher speeds on a dark night (no moon or street lights), I would recommend a model with 80 or more lux.
Busch + Müller also make a good rear light, that has a brake light function:
https://www.bike24.com/p225270.html?sku=92772
Relja Dynamo Novović
Happy banana slug
Liked 1,530 Times
@Bike Gremlin, I wasn't suggesting OP buy a dynamo hub, I was just trying to figure out what that mount was designed for. A dynamo light doesn't make sense either because the mount is in the middle of the rack rather than to one side. I checked the Specialized website and they don't have any headlights to go there, so I give up.
Mostly harmless ™
Liked 216 Times
As for the middle - that should be no problem for mounting dynamo hub lights.
Wires can be routed along the tubes, just as they are routed for the middle of the rear rack mount (if the rear mudguard doesn't have wire attachments).
Relja
Likes For Bike Gremlin:
Miles to Go
Quoted: 5224 Post(s)
Liked 3,585 Times
Miles to Go
Likes For timdow:
Liked 3,585 Times
Miles to Go
Since it goes through, I would go for a bolt with washers and a nylon lock nut.
[QUOTE=rumrunn6;22994990]oh ok I see.
it might rotate down over bumps so I'd def. use something to secure the nut & bolt, maybe a lock washer or some loctite[/QUOTE]
Likes For timdow:
The dropped
Bikes: Pake C'Mute Touring/Commuter Build, 1989 Kona Cinder Cone, 1995 Trek 5200, 1973 Raleigh Super Course FG, 1960/61 Montgomery Ward Hawthorne "thrift" 3 speed, by Hercules (sold) : 1966 Schwinn Deluxe Racer (sold)
Quoted: 1739 Post(s)
Liked 1,014 Times
Peter White of PeterWhitecycles.com has a few articles dedicated to mounting and wiring the models of lights he sells, however it hasn't been updated in a while and doesn't cover a mount slung under a rack. I'm extremely biased towards bicycle lights that meet the German lighting standards because they operate like modern LED headlights in cars. When aimed correctly, the light will provide a flat even light that shouldn't blind other road users. I'd look for a light that is compact to fit under the rack. I'd also consider a remote battery pack to keep the light small, or even just to have the bulb and reflector mounted there and as close to the underside of the rack as possible. Busch & Muller makes the Ixon IQ Speed that has a remote battery pack, but doesn't seem to have an armature for bolting to the frame as it's primarily a handlebar lamp. Beware that the Ixon IQ Speed was introduced a decade ago.
Commuting Fool
Quoted: 104 Post(s)
Liked 72 Times
I did get it to work. I filed down two sides of the braze-on located in the middle and attached the mounting bracket. The bracket had a slot of sorts that when paired with the flat sides I filed, prevented it from rotating. The light barely fit and it works really well for my needs. I may consider getting another light for the other side of the bracket considering they are cheap. I think it would look the bees knees.
Likes For boneshaker78:
A.K.A. purple fork man
Looks like OP found a cool solution though!
Likes For ilchymis:
Liked 3,585 Times
got a link for the bracket?
Commuting Fool
Quoted: 104 Post(s)
Liked 72 Times
Happy banana slug
Liked 1,530 Times
I remember the AWOL; it was pretty cool IMO. Shame they dropped it so quickly. How do you like yours? And yes, the OP's hack is quite nifty.
It has some downsides:
- It's rather heavy.
- I have some toe overlap on this bike (especially with fenders installed), but that's maybe unavoidable, being a shorter rider on a smaller-frame bike. Maybe I'd be better off with a bike with 650b wheels.
- I replaced the (in my experience) fiddly TRP HY/RD brakes with pure mechanical TRP Spyre disc brakes. Almost the same stopping power but much less fiddliness.
- Quick release and disc brakes is another fiddly combination; I'd much prefer through-axles with disc brakes, I think.
- Nice that it has a bottom bracket mount for a kickstand, but it took a ton of trial and error to find a two-legged one that doesn't interfere with either the chain or the rear tire. I'd prefer a mount point for a rear wheel kickstand, but this frame doesn't have one. (Though I suppose I could have someone weld one on, since it's steel...)
Likes For ilchymis:
Liked 3,585 Times
Likes For rumrunn6:
Happy banana slug
Liked 1,530 Times
For the toeverlap you might try shorter cranks like these; your knees and hips will be happier too. I wouldn't worry too much about weight; however heavy our bikes are, we're heavier. So, to complete the threadjack, do you have pics of the bike?
I like it a lot! I have about 10,000 miles on mine. It's my daily commuter, and I also just did RAGBRAI on it.
Likes For Korina:
Always happy to provide bicycle pictures I normally leave the fenders on year round (even when it's dry out, the mud flaps seem to keep some amount of dust away from the drivetrain), but I left them at home for easier shipping to Iowa.
Likes For ilchymis:
Happy banana slug
Liked 1,530 Times
Sweet, thanks for the bike pr0n. If you're less than 6 feet tall or have short legs, you'll likely benefit from shorter cranks.
I also leave my fenders on year-round for just that reason. Mounting fenders being a huge PITA has nothing to do with it, nothing at all.
Thanks for the pointer on crank length. So far I've just been using the 170mm cranks that came on my bikes, but I realize I have no reason to believe this is optimal for me, and obviously shorter cranks equals less overlap.
Likes For Korina:
Bikes: 2020 Masi Giramondo 700c; 2013 Lynskey Peloton; 1992 Giant Rincon; 1989 Dawes needs parts; 1985 Trek 660; 1985 Fuji Club; 1984 Schwinn Voyager; 1984 Miyata 612; 1977 Raleigh Competition GS
Quoted: 1126 Post(s)
Liked 253 Times
If you go to Niterider website they have a refurbish section, I bought a Lumina 1100 for $40! The only refurbish one they have left now is the Lumina 900 for $30, more will come in, but when is the big question.
The one thing about Niterider lights is that the light comes apart with screws, you can replace the battery yourself, or send it in, the last I checked it was $24 for NiteRider to do that, it could be more now with inflation, if they do it, they check the entire light out including the seals. Batteries in lights only last an average of 500 hours, unless it's a Lezyne, those last 250 hours, but the LEDs are good for at least 50,000 hours, so we're forced to throw away a perfectly good light because the battery won't hold a charge?! What a waste, not only to the landfill but also natural resources; so at least the NiteRider all you're going to throw-out is the battery and you can take those to recycle places.
