Can you bend it?
Quoted: 358 Post(s)
Liked 136 Times
Can you bend it?
I just got back from the store and my load shifted in the front basket. (Wald) It bent backwards 30 degrees. Can it be bent back to it's normal shape without harm? It looks ok but I never bent a basket so I thought I would ask this list first.
Quoted: 2604 Post(s)
Liked 1,933 Times
There's a good chance you can bend it back. There's an even better chance that the next time you overload the basket like that it'll bend again. How much did you load into it?
Quoted: 4806 Post(s)
Liked 3,933 Times
If this was a rear rack, I'd say straighten it and go. I know someone who had a minor mishap with a handlebar bag (cause never found) and damaged her jaw and teeth. Surgery corrected that but her ability to play a clean note on a flute never returned.
Quoted: 358 Post(s)
Liked 136 Times
It is the basket part. I guess it's Aluminum. I had about 20+lbs in when the load shifted. A case of soda did the job. Now my question is, it safe to ride or should I junk it?
Randomhead
Liked 3,701 Times
can you post a pic? I have never seen a Wald basket that wasn't galvanized steel, which is very bendable. As you have found out.
Quoted: 358 Post(s)
Liked 136 Times
Camera on the phone is junk. I was thinking of scaping the basket as it bent backwards (again.) after the last shopping trip. I think it's a Wald 186 (???).
Randomhead
Liked 3,701 Times
Do you have a magnet?
