One more link, yeah or nay?
I switched from a 12-25 cassette to a 12-28 and am about to replace the chain and wonder if I should add one more link. Everything worked fine on a test ride with the old chain, even cross chaining from the big chainring to the 28.
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,571 Times
Very Senior Member
Bikes: Giant Quasar & Fuji Roubaix
Quoted: 413 Post(s)
Liked 343 Times
If that is the old chain, it looks fine. But have you measured the stretch in it? If it's stretched, I would add a link to the new chain. Let us know how you like the extra top gear, I might consider that on one of my MTB-kinda like the over drive I keep wishing for.
It's the old chain and has minimal stretch. As to the change in gearing, here's my take. My area is very hilly, with many grades between ten and fifteen percent. On my group rides virtually all the other riders have 28t and larger cogs. On some hills I often found myself trying to down shift even though I was already in my lowest gear, so for me it was basically a no brainer. On the 13 degree hills near my house it's the difference between standing up and powering up with the old cassette and staying seated for a relatively easy, albeit slower, spin up the hill.
Very Senior Member
Quoted: 413 Post(s)
Liked 343 Times
My bad. I haven't had my second cup of mojo yet this morning. I was thinking backwards. Yeah, you're right, that will give you a lower gear and on hills, a good thing I need a taller setup and I'm already at 11 teeth so my only option is changing up the front. Time for more coffee....
Here's a pic on the two smallest gears. It doesn't look like there's much room for the derailleur to take up much more slack.
Likes For audiomagnate:
For a minute I thought you said one more line. I guess it's time for new bifocals.
Quoted: 1163 Post(s)
Liked 442 Times
Big/Big and small/small are both gears that you should not normally be using. If you add links this would be OK if you intend to ride occasionally in the Big/Big combination. But then the consequence of that is now when you are in the small/small you no longer have that (last little bit of) clearance and the chain is now going to be clacketting on the cage.
I would leave well enough alone. One other alternative is to change your rear derailleur for a long cage.
Really Old Senior Member
Shift to Big:Big.
You want more than 1" and < 2"
Quoted: 1438 Post(s)
Liked 1,092 Times
As long as you can comfortably shift into big-big your chain is long enough. If you lengthen it you may have slack in the chain in small-small. You should not use either but no harm will come from a slack chain; too short is a big no-no.
For current 11 speed, Shimano spec is for big/big+2 on cassettes with a large tooth of 28 or more teeth, and for cassettes smaller they specify to shift into the highest gear (big/small) and for the chain length to be such that in that gear the pulleys form a perpendicular line to the ground.
But yeah, basically, the chain is supposed to be very tight in big/big, especially for large chains, on Shimano (Campy specifies sizing around small/small), so as long as you can shift into it and nothing looks like its about to explode, you're fine, and it will in fact shift its best in normal usage.
