Recommend me a front pannier rack for wifey's bike
Bikes: 2021 Salsa Fargo 1x12, 2019 Jamis Renegade Exploit 1x11. Motobacne NX Fat Tire
Quoted: 198 Post(s)
Liked 332 Times
Going to do some light touring and bikepacking this summer with my pampered wife. She has a 2016 Trek Crossrip and it has eyelets for a front rack but I’ve never bought one before.
please make a recommendation based on your experience and any pannier recommendations are welcome too.
Bikes: 2014 Trek Allant drop bar conversion, modified Schwinn MTN commuter, 2015 Trek 520, Soma ES, Salsa Journeyman, 1980 Trek 414
Quoted: 178 Post(s)
Liked 355 Times
Does the crossrip also have mounting eyelets on the inside of the fork blades? If so, the Salsa Down Under rack is a nice, sturdy opion. I have these on my 520, and they are solid. I just dont know about mounting on a fork that only has low rider mounts on the outside of the blades, as the rack might be prone to twisting while loaded with bags - might be okay though.
Mad bike riding scientist
Quoted: 6223 Post(s)
Liked 4,225 Times
Going to do some light touring and bikepacking this summer with pampered wife. She has a 2016 Trek Crossrip and it has eyelets for a front rack but I’ve never bought one before.
For panniers, it’s hard to go wrong with Ortlieb. Yes, they are expensive but they last forever. Mine have seen many a tour and are still going strong.
Stuart Black
Stuart Black
Quoted: 198 Post(s)
Liked 332 Times
I researched that Salsa rack and like you said, it really needs the inside eyelets for stability so I don't think it will work well here. A cross member is needed over the tire for stability.
Added pic
Quoted: 198 Post(s)
Liked 332 Times
Tubus Tara. Rugged and simple. You’ll probably have to get creative around the disc caliper but you’ll have to do that with any front rack.
Occam's Rotor
Quoted: 2366 Post(s)
Liked 2,331 Times
Tubus Tara. Rugged and simple. You’ll probably have to get creative around the disc caliper but you’ll have to do that with any front rack..
Quoted: 1183 Post(s)
Liked 834 Times
I use a Tubus Tara front rack with Ortlieb panniers; they work very well together. My wife rode across the country using Ortlieb Packer Plus front panniers on her rear rack.
Ortlieb Sport Packer Plus panniers used on the rear rack.
This is my set up, Tubus Tara with Orlieb Front Roller panniers.
Likes For Doug64:
Quoted: 3464 Post(s)
Liked 1,470 Times
I use a Tara on my Lynskey, I have a 2004 LHT rim brake fork on that bike and the rack fits well.
I think the Tara is a great rack if it fits well, but it does not have very much adjustment to get the top bar horizontal to some forks. My point is that you almost have to install the rack to find out if it fits well on any particular bike. The Tara was designed back when virtually all forks had a curve to their fork blades. And designed before disc brakes became common. I bought a Tara for a different bike and it did not fit well at all, but fortunately later found it to work great on the Lynskey.
On one of my bikes I found the Tubus Ergo to fit better (that is also a rim brake bike), the Ergo I think is discontinued but a few retailers still have it. It has a bit more adjustment to it than the Tara.
Perhaps you should ask her. The right rack might be the one she wants to be seen with. Pampering might require a 70-30, boy-girl weight distribution.
Good luck
Good luck
Likes For Pratt:
The Racktime Top-it mounts on the blades and over the wheel, hassle free (racks can always be a bit fiddily).
I belive that you could hang a Ortlieb frontroller on that.
https://hollandbikeshop.com/img/prod...38785-11-l.jpg
Btw. I run the Tubus Tara on my Fuji Touring with rim brakes.
Liked 1,470 Times
I would like to recommend to you a front rack, but there are many good ones out there, but the most important help you would get is from an experienced mechanic at a good bike store who is familiar with the common little work arounds that are sometimes needed vis a vis the brake caliper being in the way.
Another vote for the Tubus Tara. Their design makes it so the panniers get very low. This make the bike super stable on turns. Plus they're essentially indestructible, since the panniers would fail long before the rack. I put the heaviest things in my front panniers which I'd recommend, because it gives more stability and gets some weight off the rear wheel, which already gets the bulk of our bodyweight and camping gear.
Quoted: 198 Post(s)
Liked 332 Times
Quoted: 198 Post(s)
Liked 332 Times
Biggest concern is her disk brake housing getting in the way of rack or bags. Other than doing a fit-up with parts at a bike shop who has inventory, not sure how to be confident.
Doing and learning bit by bit is normal. A good mechanic can help with ideas of workarounds that we don't think of ourselves, that's been the case with me anyway.
good luck
good luck
Miles to Go
I have run the Tubus Tara in the past, and now use the Racktime Topit. I happen to like the load being a bit higher. For your wife's bike, using the Topit would eliminate disc brake clearance issues as it is installed higher.
and I would add another voice to the view that riding with front panniers lower down certainly is more stable and easier to ride with, depending on load weight, surfaces you are riding on, and rider biking skills.
unfortunately, the only way for this fellow and his wife to know and judge what they are comfortable with is to actually try the setups....
Quoted: 671 Post(s)
Liked 49 Times
Likes For DropBarFan:
Quoted: 198 Post(s)
Liked 332 Times
Thanks for everyone's input. No ordered the Tubus Tara from an area shop and will report back how it goes.
Likes For Toadmeister:
Quoted: 198 Post(s)
Liked 332 Times
Update: fit up the Tubus Tera today with no problems. Ordered some Ortieb packs for it.
Liked 1,470 Times
