Addiction 2021.2
#7427
Should Be More Popular
Quoted: 22614 Post(s)
Liked 8,935 Times
#7428
Liked 8,935 Times
#7429
Bikes: Canyon Endurace, Merckx liege 75, Cinelli Vigorelli
Quoted: 167 Post(s)
Liked 114 Times
I was hyping up these Hutchinson Fusion 5 tires but noticed the rear leaked air quicker compared to the front. I put roughly 1200 - 1400 miles on these and now feel uncomfortable going on a ride... Damn!
#7430
VFL For Life
Bikes: Velo Volmobile
Quoted: 28665 Post(s)
Liked 1,860 Times
I was thinking you were retiring from cycling, as another Doug is.
#7431
Bikes: Shmikes
Quoted: 10182 Post(s)
Liked 5,880 Times
I have something similar and have not found it very useful. On one particularly tricky setup with brand new pads, it seemed no better than simply squeezing the brake to get the approximate position and then I still had to fiddle manually with the alignment and tighten the bolts in teensy micro-increments to get rid of the rub. In other cases, when switching wheels, just putting a bungie on the lever and cranking the bolts works just fine.
#7432
Klaatu..Verata..Necktie?
Quoted: 10456 Post(s)
Liked 11,947 Times
#7433
Mostly Harmless
Bikes: Have two wheels
Quoted: 13726 Post(s)
Liked 4,536 Times
#7434
Mostly Harmless
Liked 4,536 Times
#7435
Mostly Harmless
Liked 4,536 Times
#7436
VFL For Life
Liked 1,860 Times
#7437
cowboy, steel horse, etc
Bikes: everywhere
Quoted: 12806 Post(s)
Liked 7,734 Times
Doing the Stan's shake immediately after first inflation with fresh sealant helps seal the weeps a bit.
Likes For LesterOfPuppets:
#7438
Mostly Harmless
Liked 4,536 Times
#7439
Administrator
Quoted: 11978 Post(s)
Liked 6,676 Times
We've had ours. It was glorious. Knocked the temp down 15 degrees, from 90 to 75.
#7440
Silver Comet Fred
Bikes: 1
Quoted: 8852 Post(s)
Liked 3,001 Times
I mean DougRNS, who lives way closer, offered to take me to see KSU Owls action if I drove to Metro NW ATL. You need to sweeten the pot.
I also offered to buy you a hot dog. That might not be a good thing.
#MysteryMeat
#7441
Silver Comet Fred
Bikes: 1
Liked 3,001 Times
#7442
Bikes: everywhere
Liked 7,734 Times
I guess you should keep your windows rolled up during cicada season
https://www.npr.org/2021/06/08/10044...-crash-in-ohio
#7443
Bikes: Shmikes
Liked 5,880 Times
Mine is actually a slightly different tool and maybe I’m not using it right. I’m sure your higher skill level makes everything a lot easier.
#7444
Silver Comet Fred
Bikes: 1
Liked 3,001 Times
#7445
Mostly Harmless
Liked 4,536 Times
I mean. It's just a fancy strip of metal. I did rib the shop owner a bit for putting one at every mechanic's station.
Tales of my "higher skill level" are somewhat exaggerated. Except my awesome bar tape wrapping skills, of course.
#7446
Quoted: 10238 Post(s)
Liked 5,190 Times
#7447
Liked 5,190 Times
#7448
Mostly Harmless
Liked 4,536 Times
#7449
VFL For Life
Liked 1,860 Times
