Front Tire won't fit through rim brakes
I have a Giant Contend 3, completely stock: https://www.giant-bicycles.com/us/contend-3
That 700x28c tire is quite a bit wider than the rim itself. While it clears the fork just fine, it gets caught up in the brakes when I am trying to remove and replace the wheel, such as when I am travelling with my bike. This occurs even with the brake lever released and the brakes in their widest position.
I end up having to basically force the wheel/tire in and out, which throws my brakes out of alignment a bit. I don't really like doing this, can't imagine it's great for the brakes, and am wondering if there is another way, because with my current transportation setup I have to remove my front wheel every time. So practically every time I do this, I end up having to make adjustments to my brakes or get different sounds, the toe-in gets messed with, etc...
Tires have to be forced thru brakes.
SE Wis
Quoted: 2750 Post(s)
Liked 3,407 Times
carry a pump, deflate as needed, reinflate
Likes For dedhed:
Quoted: 4816 Post(s)
Liked 3,945 Times
Yes, carry a good pump. But no, don't deflate and re-pump every day! This is 2021, not the dark ages! There is a way to add another release in the brake cable path. I don't know what it is but I wouldn't stop until I found (or invented) it. An easy one is brake levers with built-in releases but brifters are not yet so enlightened. I'd see if there is an equivalent to the in-line barrel adjusts. You could just use a barrel adjuster to loosen, then re-tighten the cable (in addition to the caliper brake release),
Likes For 79pmooney:
Quoted: 2026 Post(s)
Liked 1,096 Times
Can you set the pads with a bit more clearance when the brakes are fully closed and still have good lever travel? An alternative is to set the pads wide and use the cable adjuster on the caliper to tighten them up. Then use the adjuster to gain more clearance when you want to remove the wheel.
Likes For HillRider:
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,571 Times
Looking at the Giant page, I spy a barrel adjuster on the upper brake arms. On my bikes with caliper brakes, I clamp the brake cable in the right spot so that I need to turn the barrel all the way out (but just before losing any thread engagement) in order to get the brake pads close enough to the rim. Then, wheel removal is a matter of opening the QR and adjusting the barrel all the way in. It allows a fully-inflated tire to pass through for me (28mm tires on 20mm rims), but I like Ben's idea to add an in-line QR or barrel adjuster to provide more slack if you need it.
Likes For ThermionicScott:
SE Wis
Liked 3,407 Times
Likes For dedhed:
Quoted: 631 Post(s)
Liked 405 Times
I look at the picture of the brake and it looks like someone setup the brake with the cam release lever open. If so loosen the cable and close the lever and readjust the brake.
Likes For Rick:
Quoted: 347 Post(s)
Liked 418 Times
Mother Nature's Son
Quoted: 854 Post(s)
Liked 1,443 Times
That sure is what it looks like to me. Even after doing this, you may still not have clearance. That depends on the width of your tire. I personally have no issue with having to let the air out, and then pump the tire back up after remounting the wheel/tire. Were talking about maybe 10 seconds to deflate, and maybe a minute to inflate. Forcing the tire through and having to readjust the brakes is just making it a bit more difficult, and taking more time. How often do you dismount the wheels?
Quoted: 604 Post(s)
Liked 1,064 Times
As stated, loosen the cable, and set up brakes properly.
Tim
Tim
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
And what's wrong w/ the threaded end of your skewer? It is on backwards?
Liked 3,945 Times
Old fart
Quoted: 3594 Post(s)
Liked 3,407 Times
Mother Nature's Son
Quoted: 854 Post(s)
Liked 1,443 Times
Everybody has their way, not right or wrong. As one post stated, just get a bike with disc brakes. I have no doubt that is the answer for some. For me, even doing it every day, every time, not a problem. If I have my bike with me, I have a pump. It is not worth it, for me, to install inline cable adjusters. I would just be changing from pumping every time to adjusting every time. Even with those adjusters, one is going to be limited in tire width that would fit through the opened calipers.
Mother Nature's Son
Quoted: 854 Post(s)
Liked 1,443 Times
Not kidding here, I am not sure if that is a serious post, or not. Back to " Just get a bike with disc brakes". You do it our way, and I'll do it mine, is that a song?
I had the same issue when I replaced the brake calipers on a bike fitted with Schwalbe Big Apple 26" X 2.35" tires. It was a very big disappointment, as I LOVE those tires and, like you, have to take the front wheel off every time I transport the bike. I deflated/inflated the tire for a few months but finally got tired of that and ended up putting a more narrow tire on the front only. Surprisingly, the ride doesn't feel that much different.
Old fart
Liked 3,407 Times
Absolutely serious. It takes maybe ten seconds to remove or install a brake pad; much less time and effort than deflating and reinflating a tire with a hand pump.
But @Rick Makes a good point re: the caliper release cam. If you adjusted your pads close to the rim with the caliper release in the open position, you won't be able to get more clearance when you try to remove the wheel.
Quoted: 1814 Post(s)
Liked 923 Times
Those appear to be the stock tires, which are 28mm.
Seems unlikely that that bike would be sold with the tire not clearing the brakes,
so my bet is on the brakes adjusted with the release open.
Likes For woodcraft:
Quoted: 645 Post(s)
Liked 797 Times
Quoted: 645 Post(s)
Liked 797 Times
Likes For Litespud:
Advocatus Diaboli
Quoted: 4750 Post(s)
Liked 1,536 Times
Actually to make wheel removal easier was one of the minor reasons I had to get a wider-rimmed wheelset. Obviously for example, if your rim width is the same as, or a just slightly narrower than your inflated tire width, then the brakes after being adjusted to fit the rim width once you've flipped the release lever, don't have an issue clearing the tire. In my case I went from 20mm rims to 24mm rims which made all the difference. That said, I know neither the max rim width the stock Tektros can accommodate, nor what the current rim width is of the OP's S-R3 rims.
Likes For Sy Reene:
Quoted: 6233 Post(s)
Liked 4,836 Times
Since the OP hasn't told us I wouldn't assume the others are wrong for asking. If the rim is on the smaller side of what works well with 28 mm tires, then maybe the OP does have the release open and know to close it after the tire is in. However I find many cyclist that don't know what that release lever is for.
Old fart
Liked 3,407 Times
Not sure; that's why I asked. I see plenty of people riding around with their caliper release levers in the open position, so it's a real possibility that the caliper was adjusted with the release open.
also some people tend to like setting up their brakes with pads super close, thinking a really short lever reach is safer. Can make all the difference though.
also often a good sharp whack moves a tire past pads easily, where a slow push and wiggle will misalign more.
good spot on wonky qr end
Quoted: 841 Post(s)
Liked 1,071 Times
I'm with the previous posters who suggested just setting your brakes with the cable adjustment almost all the way out and just turning it in when removing the wheels. No tools or pump needed and also the quickest method.
