Random Skipping Under Pressure
Quoted: 10238 Post(s)
Liked 5,191 Times
Couple of months ago I built a trek 5200 with Ultegra 6500. The group set came off of my Ritchey Breakaway, which I bought used a couple of years ago. I think I put about 4,000 miles on the groupset but I have no idea how many miles are on it before I owned it. Never had any issues with it while it was on the ritchey, but I also never did much hard riding with that bike.
The 5200 has become my crit bike, and I also I use it for training, specifically intervals and sprint training.
I have noticed that recently it has started to skip when under a heavy load. I have narrowed it down to the number 8 cog but the wear seems fine. I replaced the chain, and it still does it, but I am not sure if it is still just the 8th cog or if the issue has moved to other cogs as well. Have not been able to ride it.
The other thing I have noticed, when I shift to a smaller cog, occasionally it will get easier to pedal 1 or 2 strokes before it engages. It is not consistent and I hear it shift, I can’t figure our why it does this. When I put the groupset on, I installed all new cables. I’ve put about 500 miles on the bike since I built it, and it does not do either issue in a bike stand.
Thoughts? If it’s the cassette I have no issue replacing it, just didn’t want to do that if it’s not the problem.
Quoted: 1282 Post(s)
Liked 1,397 Times
when my 11t and 12t were skipping, the wear was pretty much impossible to see (even when removed and cleaned), yet replacing it completely them completely fixed the problem.
Liked 5,191 Times
Liked 5,191 Times
^ Agree with mschwett, it can be impossible to determine a skipping cog just by sight.
Ran into this problem recently on a really nice looking vintage freewheel where one cog in the middle of the cluster slipped terribly under load. Just had to bite the bullet and replace it. Problem solved.
Thanks, could the other issue be caused by a worn cassette as well?
Likes For bampilot06:
Quoted: 4446 Post(s)
Liked 1,585 Times
Liked 5,191 Times
I didn’t pay attention enough in the past to see if it’s after coasting. I’ll ride it tomorrow and see if that’s the case.
Bikes: !982 Trek 930R Custom, Diamondback ascent with SERIOUS updates, Fuji Team Pro CF and a '09 Comencal Meta 5.5
Quoted: 1299 Post(s)
Liked 741 Times
"The other thing I have noticed, when I shift to a smaller cog, occasionally it will get easier to pedal 1 or 2 strokes before it engages. It is not consistent and I hear it shift, I can’t figure our why it does this. When I put the groupset on, I installed all new cables. I’ve put about 500 miles on the bike since I built it, and it does not do either issue in a bike stand."
sounds like a Freehub Pawl engagement issue to me. they can be quite random.
there's a chance enough grunge has built up on your cassette to cause this, but that's usually only on an MTB...How old is your chain? check it for wear or have someone do so that is qualified. If the chain and cassette are ok, then it's definitely the Pawls in the Freehub not engaging consistently.
try this quick test.. lay the bike on it's left side.. shoot a "psst" (a few drops) of penetrating oil into the freehub's center... clockwise spin the wheel for a minute or so..... go ride the bike and see if the skipping still occurs...
Liked 5,191 Times
Chain is brand new less than 100 miles, that was my first attempt at getting to to stop skipping.
I’ll try lubing the free hub tomorrow. Thanks.
Likes For KerryIrons:
Liked 5,191 Times
Rode it today, did intervals, and it didn’t skip once under load.
Then randomly during easy spinning it started skipping a lot on different cogs.
I pulled the wheels and the cassette off. I put the cassette on a different set of wheels and will give that a go tomorrow.
I also poured a generous amount of tri flow on the free hub body of the old wheels.
