What files for working with metals?
Old 04-19-10, 08:17 PM
kipibenkipod
Got an old Peugeot
kipibenkipod's Avatar
Bikes: I had a Trek 1200
Hi,
Is there special brand that I need to look for when buying set of files for metalworking?
Thanks,
Kfir
kipibenkipod is offline
Old 04-19-10, 09:15 PM
BurnMetal
Frankenbiker
Bikes: The Main Three: Dahon Boardwalk S1 , Texas Tall - Bike , Trek 7.2 FX
Special brand? Umm, any brand will work for metalworking. Generally speaking, the cheaper they are, the quicker they will go (like any tool). Make sure, obviously, that the files are specific to metal working (don't get wood files, for instance). Beyond that, I've found that a metal file is a metal file. ::shrug::
BurnMetal is offline
Old 04-19-10, 09:35 PM
kipibenkipod
Got an old Peugeot
I guess I will just buy whatever I find and experiment with it.
Thanks for your reply,
Kfir
Old 04-19-10, 09:40 PM
BurnMetal
Frankenbiker
That's honestly the best way to do it. I always buy medium grade. One up from the cheapest that's there. Files aren't really like wrenches, etc. You're rubbing it up against another metal, so it's going to incur wear by default. You're only concern is that the metal used in the file is harder than the metal you're grinding against. Since this is the purpose of a metal file, most anything that has that label will keep at least a minimal hardness (though, I'm sure you can get pretty cheap, and therefore, pretty low hardness).
One thing to remember. Use "mild" steel files on "mild" steel metal. Use Stainless Steel files for Stainless steel metal and aluminum.
Old 04-19-10, 11:54 PM
DannoXYZ
DannoXYZ's Avatar
Quoted: 109 Post(s)
Liked 9 Times in 6 Posts
Technique also makes a huge difference in production speed and tool durability. You want to make contact only on the push, and lift up the file on the return stroke. Don't use a sandpaper motion of back & forth with constant contact. You'll destroy a file of any quality 10x faster than necessary and only get 10% of its useful life out.
DannoXYZ is offline
Old 04-20-10, 01:25 AM
Torchy McFlux
Torchy McFlux's Avatar
Bikes: NOYB
Having a file card handy for when you're working with aluminum is good too. They're cheap and keep them clean and cutting like they're supposed to.
Torchy McFlux is offline
Old 04-20-10, 01:40 AM
kipibenkipod
Got an old Peugeot
Thanks all for your replays.
I will keep all your good tips in mind.
Regards,
Kfir
Old 04-20-10, 10:09 AM
Daytrip
Medicinal Cyclist
Daytrip's Avatar
Bikes: 2003 Klein Q Carbon Race; 2009 Giant OCR-1
Chainsaw raker (depth gauge) files are really hard and really good, IME. If you need a round file, chain saw sharpening files are also top notch. You can buy both at any saw shop. You can also find them at Big Box stores where cheap saws are sold, but you'll pay more than you will at a saw shop.
Daytrip is offline
Old 04-20-10, 02:40 PM
alharris
alharris
Wiki has a useful page on files: https://en.wikipedia.org/wiki/File_%28tool%29
alharris is offline
MichaelW
General Cycling Discussion
9
10-16-15 06:20 PM
mikepwagner
Bicycle Mechanics
18
06-06-13 03:54 PM
calstar
Framebuilders
6
05-02-12 11:29 PM
Airburst
Framebuilders
7
10-31-11 04:02 PM
meangreen
Framebuilders
23
05-22-11 02:59 PM
