Another Raleigh "Post Friday Lunch" Brazing Job
Bikes: I hate bikes!
Quoted: 431 Post(s)
Liked 710 Times
This one is so bad it is actually made me laugh out loud. This is a 1971 Raleigh Competition frame i recently got from CL. It had been re-painted at one point and looks pretty rough. While tearing it down I saw what I thought was rust bubbling under the re-paint where the seat tube enters the bottom bracket shell. I took a wire brush to and and found this:
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Wow! How many pints were had on this day's lunch?
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Quoted: 821 Post(s)
Liked 257 Times
Wow.
The shop I worked at when I was much younger stocked Raleighs.
Although the bicycles often performed quite well, we would constantly be amazed by the gaps in the brazing around the lugs.
Especially in the rear drop outs.
Happened far more often than you would think.
From the bottom of the line up to the top, many were afflicted by the "Friday build" issue.
Yours is a doozy though and I can't imagine it came from Raleigh that way.
Quoted: 17 Post(s)
Liked 43 Times
I think it is more likely that it came from Raleigh with the usual after-lunch brazing skips, and some amateurish zealot with too much brazing rod felt compelled to effect a "repair".
(In any case, it adds a bit of visual interest!)
- Auchen
- Auchen
Quoted: 431 Post(s)
Liked 710 Times
I hit it with a file and found a lug. I did not find any obvious signs of damage.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Get off my lawn!
Bikes: 1917 Loomis, 1923 Rudge, 1930 Hercules Renown, 1947 Mclean, 1948 JA Holland, 1955 Hetchins, 1957 Carlton Flyer, 1962 Raleigh Sport, 1978&81 Raleigh Gomp GS', 2010 Raliegh Clubman
Quoted: 93 Post(s)
Liked 98 Times
+1 on "it's a repair" Now lets pull the Raleigh workers out from under the bus with some pictures nice brazing jobs
Old fart
Quoted: 3598 Post(s)
Liked 3,422 Times
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Addendum: indeed, your post-cleanup pictures appear to show a brass-filled crack:
Quoted: 3464 Post(s)
Liked 2,831 Times
I vote repair too, note how the brazing material visible on the adjacent joints is a different color. I remember that these frames (the main triangle at least were brazed up not sequentially, but concurrently.
The way the brass is applied says to me that the joint was w/o much additional flux if any, and the guy hoped the brass found its way in.
Quoted: 660 Post(s)
Liked 601 Times
Repair....and a terribly bad one. Why the extra bead stock, anyway? Horrible. I do better than that. This begs the question as to what the problem was in the first place....and down there in the BB main lug??
Expired Member
Quoted: 3708 Post(s)
Liked 5,545 Times
I don't remember that they came from the factory with the cable guide brazed on. Mine is a bolt on.
www.theheadbadge.com
Quoted: 2422 Post(s)
Liked 4,403 Times
That's a repair following a crack at the BB shell, not factory work.
If you want to see some lousy factory work, ask forum member Michael Angelo to post some photos of the brazing he and I found under the paint of an early Super Course. It looked as if half of the job was done in brass, and the rest in copper. None too well either, no matter what the material.
-Kurt
-Kurt
Quoted: 431 Post(s)
Liked 710 Times
Well, if the consensus among the smarter folks here is that it is a repair, then my apologies to the good folks at Raleigh! As for the repair, what should I look for to determine if this is worth keeping? I rode it around the neighborhood prior to the tear down and it handled fine. The previous owner said he had it from the late '70's. So if nothing is obviously wrong, than it would seem that it is OK? Until it cracks again........
Oh an here is a nice Raleigh just set things right.
[IMG][/IMG]
[IMG][/IMG]
missing in action
Quoted: 42 Post(s)
Liked 49 Times
From what I've read about breaks at the seat tube/bottom bracket junction, the failure mode is fairly benign, you probably won't completely crash & burn if it fails again. The sticky bit comes when you eventually resell it - you disclose the repair and price it accordingly, the buyer promptly "forgets" to disclose the repair and resells it for full price. There are probably some creative things you could do to reduce the likelihood of that scenario if it would weigh heavily on your conscience...
Quoted: 28 Post(s)
Liked 60 Times
-Kurt
-Kurt
Much stronger repair method for the OP frame would be to remove the bottom bracket, completely clean and sand out the inside of the seattube down to fresh bare metal and then braze a short repair sleeve into the inside of the seattube, working through the BB shell. If you leave the sleeve protruding past the end of the seattube a tiny bit, it is pretty easy to get the bronze to wick up into the tight gap and inbetween the two tubes and distribute all throughout the cracked area of the seattube.
Old fart
Liked 3,422 Times
I think the seat tube socket on the BB shell cracked all the way around the seat tube. I've seen this happen before with those bulge-formed BB shells. IMHO, the best fix is to sweat the old shell off the frame and replace it with an investment cast shell, but it's a lot of work and not necessarily cost effective except on pretty high end frames.
Old fart
Liked 3,422 Times
Much stronger repair method for the OP frame would be to remove the bottom bracket, completely clean and sand out the inside of the seattube down to fresh bare metal and then braze a short repair sleeve into the inside of the seattube, working through the BB shell. If you leave the sleeve protruding past the end of the seattube a tiny bit, it is pretty easy to get the bronze to wick up into the tight gap and in between the two tubes and distribute all throughout the cracked area of the seattube.
Quoted: 83 Post(s)
Liked 13 Times
Of course that is a crack repair done down the line, not from the factory (not that that they did not do some shoddy work at the factory). I had lots of frame, etc. repairs like that done by somebody's Dad "who could weld" back in the Sting Ray BMX days.
Quoted: 431 Post(s)
Liked 710 Times
Bikes: 1951 Armand Carlsen, 1969 DBS Deluxe, 1949 Diamant, 1978 DBS Winner Tandem, 1955 Herkules... to infinity and beyond!
Repairs aside, my checklist for all things vintage goes something like this:
Is it from the 70's? ----> Is it British? ----> APPROACH WITH EXTREME CAUTION
Quality control took a dive in many industries in the latter half of the 70's - not only in the UK but in most of the western world. I've seen Sturmey Archer and Torpedo guts from 1957 looking brand new next to identical models from 1977 with equal mileage.
I sometimes wonder whether the infamous 80's were in fact the golden age for the European family car. Competition from Japan had driven build quality up and prices down, and most were still built on tried and tested principles (carburetors, no ECU etc.) making them perfectly serviceable for the average handy-man. Kinda like the 80's were the twilight years of steel bicycles with classic geometry.
Sorry for ranting. Maybe I derailed this thread back to its mistaken roots
Bikes: Treks (USA), Schwinn Paramount, Schwinn letour,Raleigh Team Professional, Gazelle GoldLine Racing, 2 Super Mondias, Carlton Professional.
Quoted: 78 Post(s)
Liked 30 Times
Quoted: 78 Post(s)
Liked 30 Times
Here's some quality Notingham "Ale House" brazing.
It took a few day of sanding and filing to get the lug work presentable. Here it is now being built up. It's a gift for my kid Brother.
Quoted: 28 Post(s)
Liked 60 Times
That description of the crack makes sense now. If the seattube itself is not cracked through, adding a large external fillet braze all around the cracked joint would likely be functional and could improve over the existing repair appearance.
Get off my lawn!
Quoted: 93 Post(s)
Liked 98 Times
Asian Raleigh.
Yes, I know
