Chain rollers not resting in cog teeth properly
Bikes: 1992 Trek 800 Antelope, 1971 Triumph
I noticed this when I had my fixie in the stand this morning. The chain and cog have ~300 miles on them,so dine so surprised if it was worn already. I have another cog and chain that are pretty new so I can switch them out if I have to. Here is a picture:
The gearing is 46x16 if that helps, KMC chain, Sugino all city 46t chainring and unknown brand 16t cog.
Quoted: 5874 Post(s)
Liked 2,722 Times
It's hard to tell from a photo, but the chain's pitch seems to be too large. This is classic "chain stretch" but it's really early a 300 miles.
Confirm "chain stretc" measuring with a 12" ruler. The pins at both 0 and 12" should line up perfectly (24x1/2" pitch). If the 12" length of chain is more than 12", that's wear which allows the links to move apart at the pins.
Question--- were you care full to properly tension the chain?
If yes, that might be the problem. A tensioned chain is an over tensioned chain, and will lead to rapid wear. Properly "tensioning a chain is about leaving the proper amount of slack in the system. Since sprockets are often eccentric, you want to find the tightest place and leave vesitlgial slack there - about 5-8mm FREE up and down play at the center.
FB
Chain-L site
FB
Chain-L site
I did leave the proper slack in the chain. I built this up with help from a friend and he suggested I leave at least 10mm of slack in the chain and I've always made sure to leave that much slack in it. I'll go ahead and put the other cog on and see if that fits better.
Liked 2,722 Times
BTW- if it is a stretched chain, then you might need to reconsider your lube.
FB
Chain-L site
FB
Chain-L site
Chain has VERY little to no wear according to the 12"
ruler method. Probably the cog then, yes?
Liked 2,722 Times
Looks like it judging from the photo. If the pitch doesn't match spot on, then either the chain is long, or the sprocket is small, and you've eliminated the first.
FB
Chain-L site
FB
Chain-L site
Bikes: Old ones, plus a 2014 roam.
Wait, is this referring to the rear gear? I've only ever compensated for eccentric chainrings/front gears, not the rear ones..
Liked 2,722 Times
Since the sprocket usually doesn't divide evenly in to chainring (48/16 being a common exception, and which shouldn't be used on a fixed gear bike) the exact time that the high spots will be at opposite ends only happens once in a while. That's what you want to make sure still has slack, so turn the cranks until you have confidence that you're OK, especially if you prefer to dial out as much slack as possible. (I ride fixed, and like minimum backlash, so leave only the least vestigial slack)
FB
Chain-L site
FB
Chain-L site
pro in someone's theory
Bikes: FTP
Quoted: 72 Post(s)
Out of curiousity, is the cog one of @Scrodzilla's one-dollar wonders?
Quoted: 86 Post(s)
if it was me, i'd try another cog if i had one and see where that leads me. OTOH i might, if the chain doesn't skip, just try to forget about it. after all, as long as the chain is not skipping i don't feel i have much to worry about.
Liked 2,722 Times
This applies only to fixed wheel bikes.
If the rear sprocket divides into the front, as in 48/16,the rear wheel will turn exactly 3 times for every rotation of the pedals. That means the same part of the tire will be on the ground for each power stroke, and most importantly when reverse torquing to stop. 48/16 means that your tire wear will be uneven, and one or two spots will wear out much sooner than the rest.
Obviously, freewheels eliminate the problem by randomizing the wheel/pedal relationship.
FB
Chain-L site
FB
Chain-L site
I understand the skid patch thing, but this isn't an issue if one doesn't skid, right? Can the "power stroke" create patches of localized wear on the tire like skidding can?
Liked 2,722 Times
Yes, depending on your power and riding style, though the effect will be much less than the skid patch wear.
FB
Chain-L site
FB
Chain-L site
Liked 2,722 Times
As to using a 1/8" chain on a 3/32" sprocket, the tens of thousands of riders who do this prove it's OK.
FB
Chain-L site
FB
Chain-L site
Chain is not too narrow. It's a single speed, 1/8", 4/32" chain. I switched the cog for a different one and it fits perfectly. Now I'm curious why the cog is a shorter pitch. Could it be that it's a funky 10mm pitch cog?
Quoted: 86 Post(s)
BTW, as i think all know, but just for clarification, 3/32 chains don't work on 1/8 chainrings or cogs, but 1/8 chains work on 3/32 chainrings and/or cogs.
Liked 2,722 Times
The sprocket may be undersized because of manufacturing error. To see how it's possible, understand that pitch and radius are related, with the pitch changing roughly six times the radius error. (circumference = 2piR) So if the teeth are cut 0.001" too deep the pitch will be 0.006 short.
Gear sprocket machining is very exacting work, easy when dialed in, but equally easy to screw up.
BTW- a worn chain can cause a similar problem without appearing stretched. If the rollers are worn, the chain settles deeper into the sprocket, where the pitch is shorter. I didn't mention this earlier, based on the age of your chain, and I bring it up now in case other readers run into a similar issue.
If changing the sprocket solves the problem, then it was the sprocket. If not, then take another look at the chain.
FB
Chain-L site
FB
Chain-L site
Liked 2,722 Times
There are a number of ways to produce sprockets, running from stamping to generating the tooth profile on a CNC machine.
One of the ironies is that the cheapest way to produce sprockets in volume (stamping) produces the most consistent quality, decent, though not great, but always on size. Expensive sprockets produced in low volume on CNC machines are the ones most likely to be made undersized.
FB
Chain-L site
FB
Chain-L site
