Brakes
Brakes
What kind of brakes are "best" or which do you prefer?
Traditional v-brakes or disc-brakes? Is either better for control when you've got a loaded down bike?
Professional Fuss-Budget
There's no "best."
Cantis or v-brakes both work fine, parts should be available fairly widely. Both work fine in the wet. Cantis are a little more adaptable to a wider range of road levers without hacks like travel agents.
Discs work well, as long as you have proper braking technique. Parts may be a little harder to come by, so if you're doing a really long tour you'll likely benefit from carrying spare brake pads. They're not in wide use for touring bikes yet, so going disc will narrow your options a little bit.
Last fall I bought a Surly Troll with disc brakes; my previous bikes were all 80s road bikes with caliper brakes. I'm never going back to rim brakes. Discs work better overall, especially in wet/dirty conditions where rim brakes start to get sketchy. They may be a bit heavier, but maintenance isn't a real big issue (at least not with mine - Avid BB7s, which all bike tourists swear by). They're somewhat more expensive, so maybe there are high-end rim brakes that would be better than what I had been using, but discs have other advantages too - they don't wear your rims out, they work fine if your wheels are covered in mud or your rims are out of true (this may be more of an issue with off-road touring) and just overall better stopping power.
Hydraulic discs seem a lot more high-maintenance. I wouldn't really care to use them, although people talk about how amazing the performance is...the performance on my set is just fine.
Walmart bike rider
Disc brakes on some bikes can get in the way of racks and such. Other then that, it doesn't really matter which type you have, the success of your tour won't be on what type of brakes you have.
Bikes: Salsa Casseroll, Salsa Pistola, Surly 1x1, All-City Nature Boy
Now that I have both brake types I can say the disc's are better and on a tour designed bike don't interfere with bags and racks. That said I am not so sure I would want disc on my tour bike. I run Avid shorty 6's and they are great. They are made better by the addition of Kool-Stop salmon pads. The discs seem a bit touchy in the wet. I am accustomed to the rim brakes so that may be the issue but the disc bite hard and keep on bitting thats for sure. Best to see what works on your bike. Long unsupported tours with disc brakes would require extra pads and maybe just maybe a disc truing fork. The discs can be bent if you are not careful handling the rim during removal.
Bikes: Borealis Echo, Ground Up Designs Ti Cross bike, Xtracycle, GT mod trials bike, pixie race machine
Quoted: 8 Post(s)
I would do a search, there is page after page after page on this topic but to give you the cliff notes:
Both work great when set up properly, neither is perfect but both are very proven.
Quoted: 671 Post(s)
Liked 49 Times
Option for getting discs was a big reason for choosing the Surly Disc Trucker (to replace Novara Randonee) which is still at Bilenky for S & S couplers. Many tourists say rim brakes work just fine yet I read few posters that try discs & go back to rim brakes. Control is important, in cold rainy weather hands can become fatigued from braking effort despite theoretical stopping power. Walmart sells cheapo mountain bikes with disc brakes yet many production or even custom tourers don't have disc option. IMHO the touring-bike makers are just taking advantage of the thin market & conservative older buyers. Not impressed with the 'breakdown in Outer Mongolia' argument either. One can take spare pads & discs & also wouldn't count on remote 3rd-world bike shops for having much of any spare parts selection; even many US shops carry few components what with the internet & the fact that they make their money from service not parts sales.
Anyway, mountain bike pros/enthusiasts are pretty much disc-only; I don't see why they need better brakes than loaded tourers? BTW whatever happened to rubber brake lever covers? On loaded mountain descents (or even less demanding conditions) braking with slippery metal levers causes hand fatigue esp in cooler weather.
Bikes: Surly Long Haul Trucker, Salsa Mukluk, Riese & Muller Supercharger GT Rohloff (Forthcoming)
Quoted: 103 Post(s)
Liked 27 Times
I had cantilevers on my touring bike but now it has v-brakes which I found to be a vast improvement in braking capability over the standard cantilevers the bike came with. I also have disc brakes and caliper brakes. All work well in their contexts.
Andrew
Andrew
Ive got the Paul touring cantilever brakes really nice really expensive with Swiss stop green pads.Awesome stopping power just really expensive.
Options abound.. here are 4 i've got here.
German Magura HS33 hydraulic Rim brakes work extremely well.. Smooth ..
another fine, cable operated, cantilever Rim Brake, no longer made,
Scott- Peterson, the Self Energizing mech, has a helical cam and coil spring,
in each cantilever caliper.. and is pulled tighter by the rotation of the rim ..
and so the brake lever has some mechanical assistance..
I have them on 2 different touring rigs here..
in really foul weather the disc brakes on my recent bike friday work well,
and my Drum brake hub equipped bike as well, I use it's smooth modulation to good effect
on a bike I leave ,now, equipped with studded tires for Icy road days.
Mad bike riding scientist
Quoted: 6222 Post(s)
Liked 4,222 Times
There's no "best."
Stuart Black
Stuart Black
I've switched from mechanical discs to hydraulics (Shimano SLX), and the maintenance is actually less. The brakes are self-adjusting for wear, so the only maintenance is replacing pads, which requires about 5 minutes per brake. The newer rotors with a spider, either centerlock or 6-bolt, are less prone to warping. I recently installed a set of Shimano Ice rotors, and only one needed slight truing. The other was perfect right out of the box. Heat dissipation is also improved with the latest disc brakes and rotors. Stopping power in all conditions and no rim wear are the main upsides.
Bikes: 2012 Masi Speciale CX : 2013 Ghost 29er EBS
But there are downsides to using a disc.
If you travel a lot, you may have a chance to bend the rotors. Once the rotor is bent, it's a pain to get it true. Disc pads are a bit more expensive than traditional v-brakes or cantis. Disc squeaks. Also disc wheels are dished even for a front wheel (more on the rear) to accommodate the disc rotor, so they are slightly weaker than traditional wheels. If you break a spoke at the rear, you'll have to remove both the cassette or the rotor side if the spoke broke on either side in the field and because both sides are dished, both sides are likely to break. Whereas, a traditional rear wheel usually break on the cassette side as that side is dished to accommodate the cassette. Either way, carry FiberFix spokes repair kit on a tour or have someone hand built you both wheels to ensure the wheels are properly prepared, spokes are tensioned and relieved properly.
I've met a few female touring cyclists and almost half prefer discs due to its excellent stopping power without need a lot of leverage effort on the brake levers.
Bikes: Salsa Vaya
Quoted: 172 Post(s)
Another advantage to hydraulics -- and what prompted me to change -- is that they don't freeze up as cables can do if there's moisture in the housing.
Also, the very light touch of hydraulics is easier on the hands. They stop me very quickly and smoothly in traffic and are fade free going down a big hill with a big load. Not that I really want to use them going downhill!
Quoted: 33 Post(s)
Obviously mud for those guys is what governs it, and for road guys, weight and modulation. Touring is sufficiently different that it demands it's own solutions all of which are hand me downs.
Quoted: 33 Post(s)
To answer the OP's question, if by control you mean stopping power, which is normally the big scare when at some point it turns out not to be there, then discs are best. But discs are heavy, sometimes affect wheel integrity, racks, parts, and durability. They are also increasingly being added to bikes, but are currently not standard on most touring bikes sold here. I think that will probably change. XC will probably send some changes out way soon enough.
I don't live in the Rockies, but it is otherwise hilly in an Appalachian way. Around here cantis are my favourite and give me everything I need. I think cantis are the best brake relative to virtually everything other than stopping power. Their real breaking power with road levers is similar to what you can get for V brakes, and they are simple, light, easy to maintain, keep working if a wheel is out of true, etc... Some of them with really grab a wheel, like the Petersens.
Disks win because you don't wear out your rims. Dishing and spoke breakage will not be an issue if your wheels are built properly.
Hydraulic disks are the best, performance-wise.
They are really low maintenance, actually- bleed them once every year or two (maybe) and replace pads. Other than that, the settings and feel basically never change. Bleeding is easy, anyone who tells you otherwise has never bled hydraulic brakes. Yeah, you could tear the hydraulic housing in outer durkadurkastan, but you could also catch a ricochet or get hit by a meteorite. I wouldnt worry about it. Besides, you think you can get a decent canti in durkadurka either? Ha, good luck.
Avid BB7 road disks are pretty close (they feel spongier... until they grab), and can be used with drop bars and levers, a great choice for a touring bike - if they work with your rack. New frames put them in the right spot, lots of old frames did not. The pads last and they are tiny and can be replaced w/o tools. Carry a spare rotor when youre planning a trans-durka adventure, however, In ten years of using disks to more-slowly-crash my mtbs, Ive never bent a rotor. Cause I'm not an idiot who throws my expensive wheels around or drops my bike on sharp edges. If you're gonna fly somewhere, take the rotors off - pretty simple. (and yet, the claim never dies! the disks are going to bend!!) it happens, sure. Not often.
Paul touring cantis and neo-retro are pretty great cantilevers, I like them only slightly less than my machine tech zero-flex cantis from the mid 90's. High end cantilevers are great, for the most part. I used them until eventually switching to disks, largely bypassing v-brakes. But V brakes work great too, and are idiot proof, setup wise. Cantis get a bad rap because people are crappy mechanics, and they use cheap brakes with cheap springs that dont have equal spring tension side-to-side, and they use way too much cable housing and non-teflon, non pre-stretched cabling etc..
Which brings me to a final point: if you use shoddy cables and too much worthless cheap-ass housing without those little metal ends for the cut surfaces of the housing, your braking will suck. To anyone who says _______ brand brakes of ______ design are no good, I call BS. You just dont know how to make them work. Ive worked on waaaaaaayyyyyy too many crappy bikes with crappy brakes to believe those claims. Working on crappy brakes is tedious and annoying, but nearly always possible. 1970's crappy centerpulls even work great if you take your time with them.
summary:
dont buy crappy brakes. The rest is pretty much mox-nix.
disks- the best because you dont have to rebuild your wheels when your rims dont wear out.
hydraulics- the best performance. rim or disk. Pretty much flat bars only at the moment.
everything else- just fine too, whatever just dont buy crap and use good housing and cables.
PS, youre way better off buying whatever brakes are a good deal and spending more on your tires.
That is, if you care about safety and performance.
/thread
summary:
/thread
Quoted: 1182 Post(s)
Liked 833 Times
Go to a cyclocross race, and see what type of brakes they are most widely used-- cantilever. Disc brake usage might increase now that the UCI rule change regarding disc brakes has been in place for a year, or as the older non-disc frames need replacing.
dorstour, Plainly "best" is a different thing to different people.
Disk brakes are going to become more common, on more types of bicycles as time goes on. Generally they're better when wet and presently they're a marketing tool. Most modern brakes, rim or disk, can deliver more stopping power than a tire can cope with and can put you on your head if not properly used.
Brad
Brad
Quoted: 33 Post(s)
Discs would easily rise to the top if someone just made a perfect set for drop bar touring. And there isn't a really nice option for a NAHBS lever show bike.
Still get good service out of the Mafac Cantilever brakes I bought new in 1976.
a design that was initially produced in France right after WW2..
Newer TRP Euro X brakes are pretty similar ,really ,
2 L shaped plates joined at the pivot and brake pad post clamp and cable mount ends.
in aluminum, magnesium and carbon fiber composite sheet.
Quoted: 671 Post(s)
Liked 49 Times
Mud as in cross racing is super slippery but OTOH they don't have additional weight of touring bike + luggage. Even tourists riding in rain get dirt on rims though I suppose it's usually more road grit than fine mud particles.
Quoted: 671 Post(s)
Liked 49 Times
summary:
/thread
summary:
/thread
Tires are of course a huge part of the equation. I've been riding Schwalbe Marathons for a couple of years & before that Continental touring tires. Marathons are very durable but apparently not too sticky. Sort of like with cars where even expensive Mercedes & BMW's get stuck in the snow despite "all season" tires. Now when I need auto tires I call Tire Rack 'cause their reps know their stuff. Once rented a Mercedes 300 in Germany & slid into a ditch on an icy road. Was going very slow but amazed at the low grip...I guessed that rental cars are equipped with harder high-mileage tires.
Quoted: 19 Post(s)
Liked 7 Times
The problem faced by tourists but not race or MTB riders is integration of the brake with all the other stuff: racks, fenders, lights etc.
Disc brakes can integrate well if they are placed correctly, ideally on the rear chainstay and at the front on the driveside, leading edge (ie opposite to a normal front disc). This gets stuff out of the way of fenders and reverses the forces on the axle so braking forces the axle into (not out of) the dropout.
Disc brake units are not designed for chainstay mounting so the cable run is at the wrong angle. As this mount becomes more common, I imagine that Avid will make a road version for this location.
Is there any debate regarding ISO vs post mount?
Forks need to be stiffer on a disc-equipped bike; how does that affect comfort?
I use Shimano centrelock disks but for travel, I think 6-bolt are better, you dont need a vice or long wrench to replace them.
Pads are easy to carry and can be quite cheap. In the UK we have a "no-brand" brand called Superstar who sell pads from the same Chinese factories as everyone else, at a fraction of the price of Shimano/Avid.
My canti setep drives me to distraction. Nothing plays well together and I cant buy the bits that I need to make it work. Cantis are going out of fashion and sooner or later, will drop out of the market altogether.
