Rear Derailleur Mounting
Quoted: 2496 Post(s)
Liked 739 Times
Hi. Have a new bike that is minimally assembled from the factory. Supplied rear derailleur is a long cage Shimano Deore. The frame has a replaceable hanger. Derailleur appears to have a removable hanger of its own. When I remove that and mount the main body of the derailleur to the hanger the B screw does not make proper contact, the micro adjust hits the hanger at the back, and the holes to thread the mounting bolt through don't quite line up. With both the frame hanger and derailleur hanger installed everything fits but it just doesn't look quite right. I've checked with other bikes I have and all of them have the derailleur body bolt right up to the hanger. Thoughts? I'll focus on other aspects of the assembly in the meanwhile... its going to be a long day.
Quoted: 1438 Post(s)
Liked 1,092 Times
A couple of clear, well-focused photos will help immensely, to understand your problem.
Old fart
Quoted: 3590 Post(s)
Liked 3,401 Times
How about a picture showing the inner face of the dropout, so we can see where the B-screw lands? Take the wheel out for a clearer view.
Liked 739 Times
In the picture above the B screw is fine. It is integral with the lower of the two silver pivots seen. The upper silver screw is fixed, it does not pivot. The short hanger that connects to the hanger on the bike can be oriented to any direction while the screw is loose. I have it oriented as in the picture because wheel insertion is affected with it any other way. My question is with the derailleur as pictured, will the shifting be normal once the cables are attached. Thanks.
Don't make me sing!
Bikes: 2013 Specialized Crosstrail Elite, 1986 Centurion Elite RS, Diamondback hardtail MTB, '70s Fuji Special Road Racer, 2012 Raleigh Revenio 2.0, 1992 Trek 1000
Quoted: 308 Post(s)
That looks a lot like the "wolf tooth" link that is used to drop a RD far enough to allow it to engage very large sprockets, like those in your cassette. I think it's going to be fine, once you get it all put together.
Liked 739 Times
Thanks! I wondered about that too. That is a 36T big cog. But they sell it this way, I have to assume they know it works. I will put everything together (40 years of cycling and I have never used a chain breaker...) and see what happens.
Bikes: Voodoo Hoodoo, Linus Libertine
Quoted: 106 Post(s)
Liked 15 Times
That is a built-in roadlink/goatlink that drops the body mounting pivot lower than the frame's derailleur hanger. I also have one like that.
Note the cable angle of entry which is backward. Normal rd have the angle of entry forward.
SE Wis
Quoted: 2747 Post(s)
Liked 3,401 Times
Quoted: 714 Post(s)
Liked 800 Times
That integrated hanger is necessary when using the Shadow type derailleur on a bike with a normal derailleur hanger. It can be removed for use on a frame with a "direct mount" hanger.
Liked 739 Times
Thanks to recent posts I've cracked it. Thanks. The link to the 'Shadow Mount' product release were especially helpful. WRT post #11, the 'b-link' is indeed horizontal in some models (like pictured) but for mine the angle that is shown in my picture is correct, and there is a 'stop' built into the body of the link that sets it that way. Unfortunately before I knew better (i.e. before I started this thread). I attempted to remove the link and mount the derailleur body directly to the frame hanger. I've put it back of course, but it was held in by a thin 'circlip' that was destroyed as the mounting screw was backed out. It isn't really necessary, but... I'm anal that way. I assume everything exists for a reason. I probably will never check to make sure the screw remains tight, so my first warning of anything amiss will be when the derailleur tears loose from the mount and is mangled beyond repair, taking out the chain and several rear cogs with it...
Quoted: 184 Post(s)
Liked 67 Times
When shadow derailleurs are attached the b-link should be in a near horizontal position, these derailleurs can also be attached where the b-link is in a more vertical position but this is a incorrect setup.
What model Deore derailleur is this?
Liked 739 Times
Post a photo showing how you've attached the derailleur, with the bike standing upright on the ground.
The photo I took in post #3 is of the bike standing upright on the ground, and the photo has been rotated so that what you see is exactly what I saw when I took the picture. I don't know what model of Deore, but clearly it is of the new 'Shadow Mount' variety. Everything I've read suggests that it is a mountain spec RD, but this is a road bike that it is mounted on. The bike is a Performer Saki 26" USS Highracer, if that helps. I intend to back out the mounting screw and loosen the 'b-link' and see if the 'stop' that is limiting its rearward sweep will clear the hanger and then allow it to reach a more horizontal aspect.
You have a Mountain multipivot rear mech.. the engineers have confused you. did you want a Road Triple RD instead, ?
Quoted: 184 Post(s)
Liked 67 Times
Page 12 shows correct mounting: https://si.shimano.com/pdfs/dm/DM-GN0001-20-ENG.pdf
Liked 739 Times
The b-link should be able to rotate clockwise on the derailleur hanger if the derailleur takes a hit.
Quoted: 239 Post(s)
Liked 7 Times
It's really weird that your's is angled down so far.
Possible that the tooth on the tip of the hangar, versus the tooth on the end of the b-link are on the wrong side of each other?
maybe take a photo of the derailer hanger by itself, nothing mounted on it.
Liked 739 Times
Thanks to the link in post #17 I was able to not only sort out the b-link problem but cut the chain to length as well. Thanks also to everyone who offered advice. You guys rock.
Liked 739 Times
Yes, I already realize the housing is too short. Man you guy's don't miss a trick... maybe I should post the whole bike so you can tell me what else I've done wrong before I kill myself in traffic...
