Anyone tracking gear usage?
Quoted: 800 Post(s)
Liked 512 Times
Garmin Connect has this feature/component that allows you to track gear usage. As I've been replacing components on my bike (brake pads, rotors, saddle, power meter battery) I am tracking their usage/life using GC. No real reason I suppose. I'm more curious to know how long I get out of a pair of brake pads, for example. I'm just curious to know if anyone else is tracking their gear too. Cheers.
Quoted: 942 Post(s)
Liked 527 Times
Edit: I see what you are talking about now....gear as in "stuff", not gear as it relates to shifting.
Bikes: Specialized Ruby Sport
Quoted: 318 Post(s)
Liked 314 Times
My bike is new, so I haven't had to replace anything yet. Strava is keeping track of my mileage and all miles are on the new bike. I would like to find a way to keep track of new components once I have to start replacing things.
Quoted: 2604 Post(s)
Liked 1,933 Times
OCD perhaps, but I log significant maintenance for all my bikes with a pen in a notebook.
It doesn't warn me when something's wearing out, but it makes me feel a little better when the chunk out of my tire came when the tire had 3,000 miles on it.
Since you say you have a new bike, it might not be that much work to go back and add your bike for each of your existing rides. When you add a component to the bike, you have the choice of selecting 'Since New' or a specific date that it was installed, so once you have the bike defined, it's pretty easy to add components after the fact and still keep track of mileage.
Likes For ted_major:
vespertine member
Bikes: Yes
Quoted: 687 Post(s)
Liked 220 Times
I started using this feature on Strava fairly recently.
I ride a lot in the summer months and do not always realize that it's time for maintenance until a cable snaps halfway through a ride, so I'm hoping to prevent that.
Quoted: 318 Post(s)
Liked 314 Times
You can do that in Strava. From the Settings page, click the My Gear link on the left side menu. You can add a bike, and then once you add a bike, you can add components, and Strava will keep up with mileage, both for the bike, and for all the components you add.
Likes For Wilfred Laurier:
Been Around Awhile
Bikes: Vaterland and Ragazzi
Quoted: 12 Post(s)
Liked 1,536 Times
Likes For I-Like-To-Bike:
Likes For NomarsGirl:
Life Feeds On Life
Bikes: Too many Motobecanes
Quoted: 4426 Post(s)
Liked 4,533 Times
gxb is gravel bike
I use a notebook to track time/mileage and then I use abbreviations to determine what route I took. Like county road numbers.
Int- intersection
456- county road number
543e- eastward
Stuff like that heck let me take a photo.
Quoted: 152 Post(s)
Liked 173 Times
I use Garmin Connect to track most of the consumables on my bike. The reason I started this is because I wax my chains and wanted to setup a distance limit so I would know when it's time to swap out to a freshly waxed chain. Since it is easy to add additional components I went ahead and added tires, cassette, shoes etc., etc. and let it track them all automatically. I like Garmin Connect because I can setup a card on the Dashboard that gives me a numerical as well as a graphical display of the chain miles ridden and miles to go without having to navigated down to other pages.
Quoted: 550 Post(s)
Liked 325 Times
Sometimes that yields interesting patterns. The last batch of OEM Campagnolo shift cables I bought have half the life of the ones which came before them.
Gone Biking!
Bikes: Orbea Gain, Lynskey, Redline Conquest Disc, Bike Friday, Cannnondale T2 Tandem.
Quoted: 42 Post(s)
Liked 50 Times
Access Database
About 20 yrs ago I built a database in Access that tracks all parts and accessories on each of my bikes.
Quoted: 800 Post(s)
Liked 512 Times
As I am replacing items I start tracking them in Garmin Connect. Battery on the powermeter, brake pads, etc. I am also tracking items for interest. For example I bought a new helmet, so I'm tracking how many KMs I end up using it for. Purely for interest sake.
I have been using this app
https://play.google.com/store/apps/details?id=com.probikegarage.app&hl=en
It takes data from Strava, you can track multiple bikes, and each component on each bike. You can set up maintenance intervals for each component. You can tell it for example if you swap set of wheels, or switch tires, or a chain. Then when you put the item back in service it knows where to start tracking from again. You can get as detailed as you want with the components. Once it is setup it pretty much just does all the work. You do have to enter your bikes in the Strava "Gear" section, and then make sure you edit your Strava activity to reflect the bike you used that ride.
I keep receipts (heh .. another old school method.) Unfortunately, some of the receipts fade over time and end up being little blank pieces of paper.
I'm inbetween doing it with the help of Strava, Garmin etc. and a notebook: I have a Google spreadsheet for that.
Bikes: Lynskey GR270
Quoted: 115 Post(s)
Liked 69 Times
Anyone else using Rubitrack? It's a standalone Mac app that is awesome for tracking gear and activities. You can set maintenance reminders (every x km, after x many days, x many uses, etc). I've been using it for many years and have only good things to say. Great support in their forums too.
Quoted: 663 Post(s)
Liked 496 Times
Just like I-Like-To-Bike, when I wish to keep track of maintenance items I write it down in a bike log. This marvelous technical innovation tells me when a new chain or speedo batteries, or new tires are due. This system has a long history as it was developed some thousands of years ago and continues to work even today.
Liked 1,933 Times
Quoted: 18420 Post(s)
Liked 15,564 Times
I don't care how long I have had a set of brake pads. I am not going to replace them until they are worn. My eyes can tell when that is. Same with tires. And saddles. And bar tape. Chains can be measured. When a hub starts feeling crunchy it gets overhauled or replaced. When rims wear down they get replaced. Again, my eyes (and fingers) can tell me when that is needed.
