Why use taillight in day time?
I still don't understand why some of you think it's so important to use tailight (and some also using headlight) in bright day time, like it's better than hi-viz clothing. Is a small flashing taillight really more noticeable by drivers than large sized hi-viz clothing/bag? Any drivers can share opinions?
Lights are especially valuable early in the morning and late in the afternoon when the sun is low. Drivers looking thru a dirty windshield into the sun really can't see cyclists very well. And if a rider is in a shadow or under a bridge, as a driver moves from bright light into a darker area their eyes do not adapt quickly enough to the lower levels of light and it is easy to not see a rider.
Last year I was stopped at a light on a road heading west about 30 min before sunset. A driver pulled up beside me and told me he was able to see my flashing taillight despite the sun straight ahead. I have a Cygolite Hotshot, btw.
I'm probably going to add a white flasher on the front. I've had several instances of drivers turning left in front of me or pulling out of a driveway on my right. No crazy close calls yet, and I don't know for sure that it was because they didn't see me, but it can't hurt. The flashing itself helps attract a driver's attention in my experience, because it is out of the ordinary. If my flashing light catches the attention of a driver glancing up from his smartphone, hopefully that makes me safer.
Fred E Fenders
Bikes: Jamis Aurora Elite
I use a Cygolite Pacer 800 front on flash during the day and even in bright sunshine the reflection off road signs is noticeable. In the rear I use the hotshot along with a bright vest with a flashing cheap red led to attract attention.
I hope to attract as much attention as possible riding in bike lanes on high speed 4 to 8 lane feeder roàds designed to get traffic to the Interstate quickly.
I have noticed drivers giving me more room and actually yielding to me where appropriate verses not using the equipment and not being treated the same. Of course this is by no means scientific, but in my experience it seems to help.
Still keep an eye out for drivers making lefts at intersections or to smaller streets. They can't be trusted to yield.
F Thomas
"Life is like riding a bicycle. To keep your balance, you must keep moving."
Albert Einstein (1879-1955)
F Thomas
You gonna eat that?
I think tail lights help at times in bright sunshine if there are any shady areas. When a driver first goes into a shady area (tunnel, under some trees, etc.), their eyes might not pick out the form of a cyclist readily, but a flashing light will help alert them that there's something ahead.
Quoted: 4560 Post(s)
Liked 2,804 Times
This, among other scenarios:
Often the only opportunity I get to ride, either for errands or pleasure, is early morning or late afternoon. My rides usually head straight eastward in the morning or westward in late afternoon. The flashing white front and red tail lights on the bike gives drivers a little more help in noticing me amid the usual traffic and glare from the sun.
I also wear flashers on my hat band or helmet. Turning my head alters the intensity, which drivers seem to notice. Several times I've seen drivers preparing to enter the road from parking lots, looking both ways for a clearing, then noticing my flashing lights and pausing.
Thirty-something years ago when I cycle commuted daily there were few options for effective lights. The lightweight lights that were available weren't noticeable in daylight. I lost track of the number of times vehicles pulled out in front of me from parking lots, crossed my path at intersections even when I had right of way, or right hooked me. Wearing bright colored cycling clothing didn't seem to help at all, and I don't bother any more with dedicated cycling clothing or dayglo vests. My bike is already dayglo red/orange. Maybe that helps a little.
Since resuming cycling a few weeks ago and using bright LED flashers, I've had only one minor encounter, an impatient driver who honked at me from behind. But I can see drivers suddenly notice me and get an eyelock at complex starfish intersections, parking lots and intersections.
I'm using a combination of flashers on the bike and on my headgear:
These can all be attached/detached easily via clips or elastic bands. But I'm convinced enough of the effectiveness of flashers to consider adding some bolt-on lights to the bike, although this might make it tougher to recharge USB rechargeables unless I use a detachable battery pack.
"...I was stopped at a light on a road heading west about 30 min before sunset. A driver pulled up beside me and told me he was able to see my flashing taillight despite the sun straight ahead."
- A Vivo-Bike Illuminati on the handlebar, on flasher in early morning/late afternoon; and on steady at night.
- Whatever red light came with the Illuminati, on the rear rack or trunk bag - usually in fast flash mode.
- An older Energizer red flashing LED on the back of my hat band or helmet.
- A Blackburn 2'Fer in white flashing mode on the front of my hat band or helmet.
Señior Member
Bikes: Windsor Fens, Giant Seek 0 (2014, Alfine 8 + discs)
Quoted: 446 Post(s)
Liked 8 Times
Because low sun, and because cell phones. With the distraction level I see in drivers these days, if you want to live you have to practically punch them in the face to get their attention. I figure I've got 1 second every 5 when they're actually looking at the road, and during that 5 seconds they'll travel 200 to 300 feet. I need to not just be visible, but DEMAND the attention of someone who's glancing at the road for one second.
It works. I get treated differently when running high powered taillights in the daytime than with just hi vis clothing (which I also always wear)
Work: the 8 hours that separates bike rides.
Señior Member
Quoted: 446 Post(s)
Liked 8 Times
Here's the sort of thing that happened to me at least once a year before I started running front daylight flashers, and has not in the 2 years since.
(warning, airzound)
https://youtu.be/UOwv_IXZdIk
https://youtu.be/-hiZgxpWNlQ
(warning, airzound)
Bikes: 2011 Felt Z85 (road/commuter), 2006 Marin Pine Mountain (utility/commuter E-bike), 1995 KHS Alite 1000 (gravel grinder)
Quoted: 676 Post(s)
Liked 13 Times
I also wonder why people bother to run cheap, dim lights in daylight hours. That's just pointless. But I have been told by a number of people that they can see my flashing headlight (Cygolite Expilion 700), and taillights (dual Cygolite Hotshots), from as much as a mile away even during daylight hours. That's going to alert motorists of my presence far earlier than high-vis stuff will.
Galveston County Texas
Bikes: 02 GTO, 2011 Magnum
Quoted: 1355 Post(s)
Liked 1,251 Times
Most drivers passing by only have 3-6 Seconds to see you on your bike.
The Bright Strobe Lights work Good to attract the drivers attention.
Fred "The Real Fred"
Bikes: Gilmour road, Curtlo road; both steel (of course)
Quoted: 273 Post(s)
Liked 10 Times
I recently had a woman in a car pull alongside me while I was waiting at a red light and told me my flashing headlight made it much easier for her to see me when she was stopped at a corner I had just passed.
That's all I needed to hear; I will never ride without blinkies again...
Today, I believe my jurisdiction ends here...
Bikes: ...a few.
Quoted: 2012 Post(s)
Liked 410 Times
I ride with both hi-viz and blinking front and rear lights. Not sure which is more effective during the day, but not much of an investment to do both.
I see, I agree in shady areas lights are very useful, more than hi-viz. I think it makes sense if much part of your ride is in such areas, or it's overcast. The dilemma for me is, since I rarely pass dark/shady areas during day time, if I have a taillight on all the time, by the time I pass such an area, much battery charge has been wasted before the moment it's really needed, by which time the light may not be as bright as it needs to be.
My God, you almost got your second life! Definitely need a intense headlight with long beam in that case.
The other day while driving, I saw a guy several blocks ahead of me with a really bright flashing taillight. I'm sure I would have seen him anyway, but the more awareness the better. I use my headlight on low on the MUPs during the day for oncoming bike traffic. It helps to keep them off my side, especially where there are shaded areas and in the evening.
Tortoise Wins by a Hare!
Quoted: 1549 Post(s)
Liked 942 Times
If you ever take the lane in front of high speed traffic like I sometimes do, you'd quickly see the benefit of a bright, flashing taillight. The sooner the drivers see me, the sooner they prepare to change lanes.* This gives the tailgater behind them more time to see me and prepare.
*or slow to my speed.
Daytime front lights are for mitigating risk form crossing traffic, and in my experience, also work well. Especially when combined with a more assertive lane position.
Bikes: Huffy Sienna Cruiser
Quoted: 54 Post(s)
I run a flashing tail light in the day. I think that it helps traffic to see me sooner. It doesn't cost anything so why not do it?
So my guess is, one of the reasons lights are some times more effective than hi-viz clothing in day time is that, drivers on the road are more used to watching for lights from other cars than watching for possible cyclists in hi-viz?
Quoted: 676 Post(s)
Liked 13 Times
Battery charge has never been an issue for me to run my lights at all times, 24/7.
I use it to increase my chances of being seen in a direction that I don't give constant attention to. It's on when I am on the bike path as well as the small times I am on the road. When I AM on the road a flashing front light is also on. I want to increase my chances of being noticed with a reasonable effort.
Quoted: 1366 Post(s)
Liked 1,689 Times
Liked 942 Times
What drivers are, and are not, used to seeing is often tossed out as a reason cyclists are missed. I don’t buy it. Drivers are used to seeing other cars yet they smash into them all the time.
Drivers are not used to seeing UFO’s, yet if one landed in front of them you can bet your cycle shorts they’d likely see it and do their best to avoid it. (shock and awe factor)
Being well out of the ordinary garners attention. Be the UFO and don't be shy.
My own personal anecdotal reasoning is when driving I notice a bike with a rear flasher or front light much sooner than I see one without.
Simple as that.
Simple as that.
Quoted: 32 Post(s)
Me too. And to be frank, it's all about trying to catch drivers attention. How you do it is up to you. I ride a lot and drive a lot too and the ninja cyclists I never really see and the folks who use lights I pretty much always see. I'm very vidulant with cyclists in general.
Take a look at this simple example:https://www.youtube.com/watch?v=vs6YZk1QZdM
Quoted: 32 Post(s)
