Minimal Rear Rack for a 29er?
Bikes: Nature Boy 853 Disc, Pugsley SS
Quoted: 251 Post(s)
Liked 8 Times
It's winter touring time!
Trying out some deep-winter bikepacking again this year. I've got the wide tires and sone good snowboots. My girlfriend got a rear rack for a pair of Ortliebs, since frame space is low on a small.
I know I can fit everything I need on my Large without racks (did it last year), but with cold hands, I am thinking about using a pair of Ortlieb front-rollers on a rear rack for ease of packing/unpacking with gloves on.
So, I'm looking for the following:
-Rear rack
-Disc Brake Compatible
-Lightweight, Minimal (will carry 20lb load max)
-Wide enough for a 2.4" tire*****
I think my current front-runner is the Old Man Mountain rear rack, but I would love a less expensive option to explore, too.
-Rear rack
OMM is the way to go. I have the front rack on my Troll, and small Ortleib panniers fit fine, so you may want to consider using the front rack on the rear. Strength to weight ratio and quality of OMM racks is high. I dealt directly with the folks at OMM for getting all the hardware needed for a custom fit.
Nice bars, BTW.
Nice bars, BTW.
Arkel seat post rack Arkel Randonneur Rack - Seat Post Rack - Carbon Seat Post Friendly
What determines rear rack disk brake compatibility?
I know with my Ogre (with disks) I could use either the Tubus Cargo or Cosmo.
I went stainless Cosmo (I live coastal) and can vouch for a 2.35 tire fitment with ease.
I put on Big Apples initially in 2.35 before dealing it back to 2.00 Mondials.
I'd bet both the above racks could handle 2.4 ok with some room to spare.
I'll try to find a pic to show the clearance....
Sorry nothing suitable showing a close up of the gaps.
Just had a quick squiz at the Tubus site.
They suggest a conservative 60mm/2.35" max tire for their large fitting racks which include the Vega (375g hauling 25kg)
Not sure if Wiggle.com is competitive price-wise for those in the States but they stock the Vega.
The others that handle 60mm are larger and heavier due to larger carrying capacity.
I've not mentioned them due to your stated low load.
I spotted in the Tubus info:
"Information:
With our adapter set for QR-axle-mounting (Art. 71500) you can also make any other Tubus-carrier ready for a bike with disc brakes."
Another to possibly consider might be a seatpost rack?
Whoops, already mentioned above.
"Information:
Bye Bye
Relatively cheap:
Journey Disc - Journey - Racks - Products - Axiom Cycling Gear
We have one of their narrow road versions on my wife's Casseroll and I've been impressed at the quality.
So long. Been nice knowing you BF.... to all the friends I've made here and in real life... its been great. But this place needs an enema.
Bye Bye
Also check out the Salsa HD wanderlust. $$ not sure if it will work with the brake mount but it does fit Disc Truckers
Salsa Wanderlust Rear Bicycle Rack
Quoted: 3523 Post(s)
Liked 1,500 Times
One of the disc brake compatable options from Toppeak?
I do not own one of their racks, but friends of mine do. I think the design is pretty solid looking.
