Rear derailleur & fender mishap
Liked 3,610 Times
2.3 miles from my car. ugh. pulled the junk down & out & was able to pedal back as a single speed. loosened the fender nuts & straightened that out too. wasn't pretty but it got me back. if I bend the fender stays back, I can salvage the fender but the derailleur is toast
Liked 2,006 Times
Pretty impressive! Did a stick get into the chain and you pedaled it into the derailer?
The fender is pretty simple, bending the stays should be fine. I suspect you'll need to do a proper derailer hanger alignment, as well as inspecting drive side spokes, before you finish the derailer replacement.
Liked 644 Times
That's not an expensive derailleur so I'd probably replace it too. If pushed, however, I think I could probably bend it back straight enough to work with just my hands. 7-speed isn't too picky about perfect alignment.
Liked 3,992 Times
Don't forget to check that axle for straightness. The freewheeled hub makes this possibility greater then a cassette one.
Across my office is a Campy NR rear der that I wrapped up above my frame late one night. In my case the dropout was still good but the rack, fender, der, chain, wheel/axle all took a hit. In my case I rode into a pot hole and the collapsed rim allowed a spoke to bow out and catch the cage. Not the first or last time this has happened. Andy
Liked 3,610 Times
re: hanger alignment, so those parts are separate?
Liked 3,610 Times
Liked 3,610 Times
Liked 2,006 Times
Not knowing the bike, and guessing a bit looking at the pictures, I think the derailer hanger is part of the frame on this bike. It's the tab hanging down and behind the wheel dropouts. Eyeball it when you take the old derailer off, and if it's obviously bent in (or out) take a big adjustable wrench and try to straighten it. If shifting can't be tuned in with the new derailer by adjusting cable tension, take it to your LBS to get it checked out.
Liked 3,610 Times
trying to figure out the correct replacement part. found these two any opinions?
TX75
https://www.amazon.com/dp/B003ZMDJSK...XFURGNTS&psc=0
TX55
https://www.amazon.com/dp/B003ZM9RDQ...XFURGNTS&psc=1
TX75
TX55
Liked 644 Times
I doubt there is any performance difference between those two derailleur offerings.
Liked 3,610 Times
thanks. just gave the wheel a better look after washing it. all spokes are intact (attached at both ends) & feel like they all have the same tension. but I did find one with a dent. also when I spin the wheel it has an irregularity at one point so that it taps a brake pad. guess I'll get the spoke replaced & wheel trued. I guess the offending stick broke & flew away. it's all my fault completely. the muddy trail was like glue so I was riding the edge over some leaves to avoid the mud in this spot
Liked 3,610 Times
Liked 3,610 Times
took the wheel & derailleur down to our LBS. owner says go get the bike & I'll set you up while you wait. not kidding you. an hour later & $90 I'm good as new. told him he robbed me of my street cred by fixing my bike for me. he just smiled & said but now he has piece of mind
he had what looked like a no-name unit in a drawer out back
left the spoke & just tweaked a few spokes
left the cable just trimmed it & shortened some excess cable at the top & replaced the small section of housing at the derailleur
also he was able to tweak the alignment of the new unit (incl hanger) which I think was his main interest. the old hanger looked fine but his replacement had a hanger attached, so ...
of course we had to listen to ea. others stories, but it's all time well spent.
good upgrade
the logo's are scraped off but it resembles an Altus derailer
main point being, the main body pivot is thicker aluminum vs the stamped steel plate on your dead one. Less wiggly, more precise shifting
Liked 643 Times
Yipes! I have yet to have this happen, reason: Pure stupid luck!
I'd agree this looks to be an altus, so you even got an upgrade!
Ironically I purchased a new in package tourney RD today for my beater. The older style then yours. I'm curious because the majority of nasty failures I've seen like that have been Tourney derailleurs. Is there something about them that causes this, or are they just not as forgiving if you put a lot of miles on them?
Liked 3,610 Times
Liked 3,610 Times
I don't think sticks play well together with spokes & derailleurs regardless of brand. btw mine did not have a lot of miles on it
Liked 2,622 Times
Your noname derailleur may be better than the one it replaced.
No need to change spokes. Slightly bent spokes are OK, as they can still maintain tension.
Liked 3,610 Times
Caliper
5
09-06-18 01:59 PM
Thulsadoom
Bicycle Mechanics
2
08-21-11 11:47 AM
