Extended Barrel Adjuster Adapter (?)
Hi all,
If you're like me, you do your best not to replace (rim) brake pads until it's actually time to replace them. Normally, that means slowly unscrewing the barrel adjuster over time to keep one's preferred lever pull and then, eventually, loosening the cable at the brake and pulling more cable through to take up some of the slack.
I really hate doing that. You can only do it so many times before you ruin the cable and then need to replace that as well.
Does anyone know of a sort of barrel adjuster extension that would increase the range of the adjuster so that one needn't mess with the cable just to keep the same brake level pull through the life of the pads?
assuming this is V-Brake pads
how about you install them with the small spacers on the inside
then when you run out of barrel adjuster you swap them with the large spacers?
or maybe buy cartridge pads
they're a lot thinner so you replace them before this becomes an issue
Best bet is just to add another adjuster. You can get any number of inline adjusters that are spliced into the cable housing. Or you could add one at the v-brake noodle, v noodles are available with one built in. Or if it's a cantilever adding one at the cable stop on the frame/fork is possible.
Liked 5,404 Times
I've found the Jagqire ones on Amazon (https://goo.gl/ZCtWio). Would these suffice or would you advise toward another brand?
Liked 3,302 Times
I had never heard of inline adjusters. I'm sold!
-YMMV
-YMMV
Liked 3,302 Times
-YMMV
-YMMV
Thanks regardless.
They're the stock cantilever brakes on a 2012 Jamis Aurora. I already installed a barrel adjuster on my rear brake since, for whatever reason, it didn't come with one.
I have another bike that I use as a little commuter (Biria Citibike 8-speed) that uses v-brakes. I'll be getting these inline barrels for that as well. Maybe the tandem, too.
As you can tell, I really, really hate pulling brake cable through with every new set of brake pads.
Liked 691 Times
Liked 5,404 Times
Unless you are running some really wide tires on a narrow rim or have your pads adjusted very close to the rim it seems unusual that you are having this issue.
Do your brakes not have a quick release on them that opens the calipers for wheel changes? Many do, though many others do not. It's usually a little lever right by the cable hold down on the caliper. I have seen some that the cable was adjusted with the lever in the wrong position, so when it was moved the brake pads clamped on the rim.
This place has some adjusters 17.5mm long. (Scroll to near the bottom of the page. Just above the jockey wheels on the right side "M5 Aluminum Alloy Brake Adjustment Bolt") Jockey Wheels, Shimano Derailleur Parts, Derailleur Wheels
They really are. My canti brakes live in a realm of 70%-90% perfect through the lives of their brakepads and cables. If they drop below 70% perfect *anyone* can fix them (that's the only benefit). But on my next bike, I hope to go mechanical disc or caliper.
