Opinions on Racktime vs. Topeak rack/bag ecosystems?
Quoted: 56 Post(s)
Liked 14 Times
I am considering adding a rear rack from one of these two ecosystems that has the proprietary connectors for trunk bags, baskets, etc. Topeak seems to be far more popular in the U.S. (REI, some local LBS, etc.) and I already own one of their bags and a non-touring rack and it worked reasonably well for the time I used it on a bike that I no longer ride. However, I don't consider this a strong reason to stay with Topeak, especially since I cannot use the rack I already have for panniers. Both make touring-oriented tacks ("Super Tourist" line for Topeak, "Tourit"/"Addit" from Racktime that I could use when I only wanted to use a trunk bag for light touring but put rear panniers on later if I want to. Both racks are aluminum instead of steel. Tubus makes the Racktime racks IIRC.
Anyone have any comparitive experience or thoughts between the two? It seems that Specialized has started including Racktime-compatible racks on some of their newer e-bikes so the availability of Racktime stuff in the U.S. will probably be improving.
LBKA (formerly punkncat)
Quoted: 2208 Post(s)
Liked 960 Times
I cannot comment on Racktime.
I first dealt with the Topeak "track rack" some years ago with our trikes. I still have one of the bags from that time and it's as sturdy as ever if a bit more purple than black now. I have never had a rack break on me outside of normal usage issues that would be common to any rack, and even then was only related to a lower screw that was easily replaced. The racks themselves have never failed me. I use one on each of my and wife "cruiser" bikes. One is the GIANT trunk bag that she puts all manner of goodies in. Mine is a bit smaller with some (mostly worthless) little panniers that fold out of pockets on the side. I have not found anything wrong enough with them to consider going to a different system. With that said, I also utilize an under seat bag they have that clips on and off. It works in wonderful concert with the smaller of the two rack bags, given my seat height.
The smaller of the bags would likely be good as a small front rack bag, but probably not worthwhile taking up a whole rack for touring with unless CC. The larger bag is of a useful size for an overnight bag, a day of food, that manner of thing.
Quoted: 3523 Post(s)
Liked 1,500 Times
I never used a Toppeak rack.
I have a couple AddIt racks, very happy with them. Well made. Addit is rated for 30 kg which is over 60 pounds so they are built to be solid.
I picked up a hard sided bag that attaches to the Racktime racks at a swap meet, it was really cheap. But I have never found a reason to use it. But it appears to attach and detach quite easily, but I never tried it in adverse conditions.
For a while there were no RackTime dealers in USA, it will be nice if the brand comes back. A few years ago REI sold a couple of their racks.
I know that you can't see the AddIt rack in the photo, but I included anyway because it shows that the rack will carry a load. I use the AddIt rack on that bike for touring.
And, yes it was chilly that day. Thus the long pants, rain jacket, rain cover on helmet.
Jedi Master
I have two MTX trunk bags (one with expandable panniers and one without) two MTX rear racks (Explorer and Super Tourist) and the beam rack with the side-frame. It's a pretty good system if you are taking the bag on and off the rack all the time and using a few different bikes. I used it a lot when I was mostly-car-free for a few years, removing the bag several times a day, and riding different bikes depending on the distance and weather. It's not exactly delicate, and I haven't had any problems with it, but it doesn't seem to be as durable as things designed specifically for touring. I only use my bikes for leisure these days so don't use them at all anymore.
Mad bike riding scientist
Quoted: 6276 Post(s)
Liked 4,306 Times
You don’t have to choose. Nor do you have to use Topeak racks. Topeak is making an add-on called the Omani Quicktrack adapter for their bag system. It bolts onto other racks so you can use the Topeak bag on just about any rack. I’m not a fan of Topeak’s racks because they use flat metal upper stays. They work but they aren’t very adjustable. Tubus Racktime and Tubus racks have round stays that have more adjustment ability with less fuss.
I use a Racktime bag and have for about 15 to 20 years. It’s a very good bag but I also have Tubus racks which won’t work with the AddIt system. My solution was to use an Ortlieb trunk bag adapter on the rack and a basket adapter on the bag. It took a bit more work initially and the Ortlieb rack adapter isn’t cheap but it works extremely well. I even use on for my micropanniers on my bikepacking bike
Untitled by Stuart Black, on Flickr
Topeak hasn’t made their adapter until just now. If I had to do it again, I’d use their adapter since it is a little cheaper and their bags already have the fittings.
Stuart Black
Stuart Black
Bikes: A few older US made Cannondales, a modern Soma Saga (no longer made, alas!), and one gifted crabon Specialized. Never enough.
Quoted: 45 Post(s)
Liked 60 Times
I had the Addit on my commuter/tourer for a few years. Sturdy rack with round stays, as cyccommute notes. Before this I had an old Blackburn rack with flat stays and they definitely left something to be desired. The Addit works well with Ortlieb bags, which are sturdier than the Racktime bags, and don’t have quite the same price premium Tubus has over Racktime. I purchased a Racktime top bag that clips in the mount, but found it to be not well suited to my commuting needs. Too tall and not waterproof or as sturdy in construction as the Ortlieb bags. Clipping in and out was a nice feature, but not as useful as I thought it would be. About the only time it was useful was for small family outings to tote along drinks and snacks, that sort of thing. That’s my two cents worth.
Pretty sure I ordered the Addit from one of the German bike retailers, as I could not find it in the US at the time. The bags, oddly enough did pop up in the US, often on Sierra Trading post (also a good source for Ortlieb bags).
Quoted: 56 Post(s)
Liked 14 Times
Only Topeak I've seen, the LBS carries because it is integrated with a removable baby seat,,
Jedi Master
I wouldn't use the topeak racks or bags for actual touring. I don't think they're designed for that. The material on the bags doesn't seem that tough and the zippers feel like they are just waiting to fail.
Anyway, this is good news and a good recommendation for the OP.
Clark W. Griswold
Quoted: 4496 Post(s)
Liked 4,181 Times
Having seen and used both I much prefer the Racktime system as it is also compatible with bags for MIK (Mounting Is Key) which unlocks a ton of possibilities (granted you will need to swap the bottom plate). So far I have only seen Topeak bags for Topeak systems and they are fine bags and basket but I have seen more options for Racktime. Plus potentially I can get a Racktime adaptor and build a custom set of bags as well with two panniers or pretty much anything I could drill and put some screws into.
I do like the Omni system though that is a game changer and could allow one to use a nice rack from Tubus and if you already have the bag it makes sense.
I do love a lot of Topeak stuff though and use quite a bit of it on my bikes so nothing against Topeak at all.
I have an Addit on a LHT and an old hybrid. I also have a Racktime Frontit (I think that's the proper name) on the hybrid. Very sturdy and I've never had a problem. I don't use the clip-in stuff as I'm happy with the trunk bag straps and a cargo net. I'm always worried that a plastic piece will break rendering the clip-in system useless.
Liked 1,500 Times
https://www.rei.com/product/852184/r...ront-bike-rack
I am guessing you mean a Top-It, I bought one from REI when they sold them.
I’ve been using Topeak racks for years and never had an issue. Just the standard Explorer rack with Ortlieb panniers. Use a Topeak bag for commuting, but not touring. It is not waterproof.
Quoted: 56 Post(s)
Liked 14 Times
Thanks for the advice, folks. I am about 98% sure I am going to go with the Racktime Addit coupled with an Odin bag (w/ rain cover just in case) for 1-2 night trips.
Likes For jfoobar:
Bikes: Surly Big Dummy, Priority Classic Plus Gotham-Edition
Quoted: 12 Post(s)
Liked 14 Times
Sorry if this thread is too old to resurrect, but I just ordered an Racktime Addit, a spring clamp, and a basket trunk large that has the Snap It adapter built on from Bike24. I was mostly decide on a Soma Rakku alloy, but the only one available online is going for 99.99. This Racktime rig looks like a much better value, at least if ordered from Germany. According to their site, their is only one US Racktime distributor, and that company doesn't have a dealer listing on their site. ModernBike.com has some stuff, but the prices are crazy compared to bike24, even after accounting for shipping. I don't understand. I remember reading Tubus products sell much higher over here. Strange stuff. Anyway, these comments were helpful, as were the technical drawings Racktime provides for their products. I wish Soma were as helpful, but it looks like I am ending with a much better product overall. I like your photo Tourist in MSN. I noticed the fire number and wondered if it was WI before seeing it was your post. Where is that? I'm also in MSN.
Liked 1,500 Times
Addit rack is now rated at 25kg, but mine were rated at 30kg. I have no clue if they had some break and lowered the rating or if they changed the design or alloy specifications. But I doubt that I have ever put more than 15 or 20kg on it. I use the Addit rack on my light touring bike. If I have a ton of gear to carry I use a Tubus Logo on a different bike.
One of my Adddit racks also came from Bike 24. I am quite happy with buying stuff from them.
Racktime had a distributor in USA for a while, then none. Not sure what is going on now but it sounds like one of the major bike brands is selling their stuff now. But I do not know if they are selling wholesale to other retailers or not.
Since you are in Madison, if you are looking for any used bike parts or other bargains, put this on your calendar. I carry a large daypack when I go, never know if I will get lucky and find a lot of bargains.
2022 Bike Swap ? Brazen Dropouts
But with Omircron, I would not be too surprised if it is canceled, so double check their website before you go.
