Conti Gatorskin Question
How much do you love your Continental Gatorskin tires? Any wild stories or mileage milestones? Anyone switch from them to something better?
Bikes: Novara Safari, CAAD9, WABI Classic, WABI Thunder
Quoted: 366 Post(s)
Liked 459 Times
I've had 4 sets, 1 hardshell. Still have 1 set of regulars. I've never worn a set out, but except for the 1 pair I still have they went with the bikes when I sold them.
I like GS a lot. I think the regulars ride fine and I don't worry about flats when I'm riding them. They are great all around tires that are good on road, and dry off road/bike paths. I have commuted on them as well. All of mine were 32c.
The set I have now is not being used. I have a couple pair of GP5000'S which are better pure road tires. Though whenever I am riding gravel I wonder if "this is the time" I will get a flat. I haven't gotten one in a few hundred miles, but the thought is there. I don't think about it when running GS.
Quoted: 18883 Post(s)
Liked 10,646 Times
Best expressed with a bag full of rocks and then gasoline.
Yes, and suddenly all was right with the world again. You couldpick design a tire blindfolded and wind up with better ride quality. I really liked Grand Prix 4ks back in the day, I've been enjoying IRC Roadlites lately.
Likes For Seattle Forrest:
Perceptual Dullard
Quoted: 957 Post(s)
Liked 1,224 Times
Likes For RChung:
Bikes: yes
Quoted: 1281 Post(s)
Liked 644 Times
No one hates gatorskins more than people who used to ride them and then found a better tire.
My theory is that back in the day finding a tire with half decent puncture protection was difficult and gatorskins were one of the few options for people tired of changing flats on the side of the road (see also Specialized Armadillo). But now that there's a wide selection of tires that have a nice ride and decent puncture protection people have decided that they don't actually like a tire that feels like riding a garden hose full of cement on a sheet of glass.
Likes For ksryder:
Bikes: yes, i have one
Quoted: 1152 Post(s)
Liked 1,197 Times
i've used them in the past and they were ok. from all the comments that they are a stinky ride i honestly cannot tell the difference. being flat resistant they probably are a harder ride. now using GP5000 and as happy with them as i was with the GS. and i wore the GSs out in a season.
Likes For spelger:
Bikes: Shmikes
Quoted: 10223 Post(s)
Liked 5,945 Times
The nicest thing I can say is they might be good for weather so cold there would be no hope of fixing a flat and walking would be to risk death from exposure.
Likes For HTupolev:
Quoted: 1467 Post(s)
Liked 1,495 Times
Gatorskins probably made more sense when everyone was riding 23mm tires pumped up to 120psi and all road tires felt like frozen ropes.
Liked 10,646 Times
So, how much does everybody love root canals?
5700 miles on mine so far, still have about 2mm of tread left on the wear indicator, swapped front and back at around 3000 miles
Likes For Chi_Z:
Quoted: 833 Post(s)
Liked 1,979 Times
If you ride on crappy roads with debris fields that are hard to avoid, Skins make sense.
I have rotator cuff injuries and arthritis. I'd rather not deal with flats on the side of the road.
I have tried Armadillos - meh! And, Michelin Power All Seasons - Good so far.
Likes For CAT7RDR:
Bikes: Shmikes
Liked 5,945 Times
Quoted: 114 Post(s)
Liked 120 Times
There are both Gatorskin and Gatorskin Hardshell. I’ve always used the latter. For my rims, the Gatorskins are a bit tough to mount when new. However, I’m always able to mount only using my hands after using tricks like warming the tire in the sun first. They are easier to mount subsequently. I probably get one or two flats during the tires life, say 3500 miles. I’ve used Gatorskins for 8 years.
Recently, I switched to Specialized Armadillo Elite All Condition tires. The Armadillos are much easier to mount, and the flat rate is the same as Gatorskins. I’ve used the Armadillos for the past 2.5 years. The tread seems a bit softer than the Gatorskins and I get micro cuts and nicks on the tread. The Armadillos seems to ride a bit better, but that’s purely subjective. I have a slight preference for the Armadillos, although they cost a bit more. Armadillos are not as available as the Gatorskins, although my local LBS stocks them.
Liked 10,646 Times
Bikes: '23 Poseidon Redwood, '07 Specialized Roubaix Comp Triple, '12 Gravity Fixie, '21 Liv Rove 4, '06? Giant EB Spirit
Quoted: 345 Post(s)
Liked 237 Times
I've been quite happy with mine. Probably have 1000 miles so far. Lots of hills and rear tire starting to square. No punctures. I have 28mm and run them at 65psi front and 70ish rear.
Traction is excellent dry or wet as is the ride. I hear the GP5000 perform better and may try them but I have been very happy with the Gatorskins.
Only thing that is kind of weird is I notice is some threads from the sidewalls are coming loose. I've been pulling them - I suspect it is due to the lowish pressures I run.
Gatorskins get a bad rap on this site but I love em at low pressures.
Likes For MudPie:
Bikes: Homebuilt steel
Quoted: 2213 Post(s)
Liked 429 Times
I've got some and like them fine. Took a chunk of road debris in the sidewall of a GP5000 on my other bike recently and had to call for a ride home for the first time in my 30 years of riding. Pretty sure that wouldn't have happened on the Gatorskin. Mind you one epic fail in 30 years isn't the best reason to switch but seriously, there is tons of glass and junk on the roads where I ride and I hate stopping to fix flats.
Quoted: 10303 Post(s)
Liked 5,276 Times
Keep them on my spare wheel set “just in case.”
I hope I never reach that “just in case.”
Gp5000 ride sooooooo much better.
Likes For bampilot06:
Gunther20
I put over 6000 miles on a set of 32mm gatorskins last year. Got 4 flats with them but I would not blame the gatorskins for any of them. Switched to GP5000 over the winter and instantly went from 16mph avg to 23mph avg on my rollers. Perhaps that was just the exuberance of a great feeling tyre. Out in the real world my average speed is the same or maybe +1 mph with the GP5000s. But the ride feels infinitely smoother.
Bikes: yes
Liked 644 Times
Well this is by no means a comprehensive list but I've had good luck with Schwalbe Pro Ones and Specialized S-Works Turbo. Pretty much the same amount of flats as I ever had with Gatorskins. I think it helps that I run lower pressures now; usually the only flats I get now are pinch flats when I hit a hole that I didn't see (fingers crossed.)
Full disclosure my first set of Turbos flatted immediately but I think I just had a bad batch. My LBS replaced them as a warranty and I've been using them for a couple seasons now with good results.
Likes For ksryder:
Quoted: 663 Post(s)
Liked 496 Times
Well, the Gatorskins certainly are long wearing but they rattle the fillings in your teeth, especially on chip seal. I have one with about 5000 miles on it with plenty of miles left but I only use it o the trainer. I've come to really like the Specialized Turbo Pro line available in several price and weight categories. The ones currently on the bike have up around 4500 miles with, maybe, another 1000 to go. https://www.backcountry.com/speciali...CABEgK38PD_BwE
Bikes: two blacks, a blue and a white.
Quoted: 446 Post(s)
Liked 849 Times
I run them on the distance bike because I end up on Western Jersey roads that have lots of construction debris on the shoulder. Unlike many here, I lack the refined sensitivity in the sitbones and gluteus maximus that inspires such invective commentary, but, well, I guess some cats just have issues. Not me. Yeah, the GP4000's are on the fastbike, and they're nicer, but not life changing. The Vittoria Corsas were stock on that bike but I pretty much flatted every 10 rides. Gators on the wife's bike because she has zzzzero interest in changing a flat and I don't have a yellow Mavic service truck. I ride 28's at about 75psi and I'm 155lbs.
Likes For blacknbluebikes:
Bikes: yes
Liked 644 Times
Despite being on record as disliking them (see above) I will say in all fairness that I have heard, anecdotally, that the wider versions of Gatorskins-like 32mm--are pretty good. My guess is that wider tires and lower pressures in general are a more comfortable ride. I don't have first-hand experience with them though.
I've also heard that Gatorskin tubulars are really nice but tubulars are a whole different world that we probably don't need to get into here.
Likes For ksryder:
