Sinking seat post Giant Revolt Advanced 2, D-fuse.
Hello mechanics! I have a 2020 carbon Giant Revolt Advanced 2, with the infamous D-fuse system. The bike rides fantastically provided the seat post doesn't drop down.... Which unfortunately does happen every time lately. I have not yet contacted Giant and first wanted to see if I could learn some trics via this forum to solve the problem. I have tried all the known greases but still have a sinking seatpost.
I look forward to your response and hope there is a definitive solution!
Have you tried something like Finish Line Fiber Grip Paste?
2011 Trek Madone 5.2 WSD
2009 Trek 2.1 WSD
2009 Trek 2.1 WSD
2-Wheeled Fool
Bikes: Surly Ogre, Brompton
Quoted: 1385 Post(s)
Liked 677 Times
Ruben, have you tried cleaning the seatpost very well, perhaps using some mineral spirits? Twist up a metal coat hanger to resemble a giant needle's-eye, and insert a piece of cloth and use that contraption to swab it all out nice and clean, and start fresh. This technique has worked for me quite a lot, and has become my standard operating procedure for any carbon bike that comes into my inventory. Maybe this will work for you.
However, because the seatpost has sunk down so many times, I can also imagine that the scratches this has caused on the seatpost do not contribute to the grip on the clamp or the frame....
Keep in mind the collar is the clamp and the slit in the seat tube allows the collar to pinch the frame and bind on the post.. Below the collar there is no clamping being done, however adding paste below the collar may assist in preventing seat post movement. Also be careful with over torque on the bolts as the carbon can crack. We ended torque at 8nm to get the thing to hold. It is rated at 6nm on the collar.
My apologies for this post as it has nothing to do with the wedge binder used on your frame!
Quoted: 863 Post(s)
Liked 1,106 Times
I can't remember where I heard this from but one person with the same problem mentioned that his DF clamp had a 3 piece wedge system and he just used some light grease on the wedge clamp surfaces where they contacted each other allowing them to move freely and put a little stronger and even pressure between them.
Quoted: 574 Post(s)
Liked 615 Times
Been there, had valve grinding compound in the shop and it worked great but is too inexpensive for cycling.
Slipping seatpost on Revolt
Did you find a solution to the slipping seat post?
I've been going crazy because of this problem. Even after the mechanic coated every possible surface with grip-sand (to the point it's almost impossible to manually insert the seat); still.. still it sinks. I notice the primary reason it sinks seems related to how the metal plate in back interacts with the post whenever there is flexing. It's like the metal plate creates a slip-zone and with every tiny bounce of the seat it works it's way down. I'm super frustrated by this; is there any hope??
I did clean it with a cloth but nothing like you describe. Going to try it tomorrow right away. Thanks!
Quoted: 1637 Post(s)
Liked 1,855 Times
My standard answer for all slipping seatpost threads: rack mount clamp
They even make one for the D-fuse seatpost.
Sr Member on Sr bikes
I’m not familiar with the seat post system in the OP. But if the binder has more than one bolt…I think you have to make sure they are both torqued sufficiently AND EVENLY. My CF Specialized Venge has an aero seat post with two binder bolts. Although the bolts were torqued to spec, I was having the same slippage issues that even the grip paste wouldn’t solve. Finally…although both bolts were torqued to specs…they weren’t even. The space on one side of the clamp was wider than the other one. Once I loosened, re-clamped them with even spacing, and torqued to spec the problem went away.
Dan
Dan
Likes For _ForceD_:
Quoted: 114 Post(s)
Liked 120 Times
Dan
Dan
I may to thru three or four iterations of increasing tightness until I reach final torque. For example, I'll do "finger tight", then "tool tight using fingers" then "tool tight using palm" then final "torque wrench tight"
