Drop bar vs flat bar tire clearance
In recent years there's been an increase in tire clearance for drop bar bikes. I've always viewed these massive clearances as somewhat unnecessary, because there's a tipping point where you're simply better off with a flat bar bike due to the improved handling a flat bar provides.
My question: What is the tipping point in regards to tire width where you're better off using flat bars?
Liked 5,005 Times
IMO, one is never better off using flat bars! So no tipping point. Just a personal preference of the individual for how they fit to their bike for their bar choice.
All that is going on with the widening of tires is that the benefits of skinny tires aren't as they were once thought to be. So now frames are being made to accept wider tires. Also riding habits are changing and many are riding gravel on what is essentially a road bike, but more special made for the purpose.
Likes For Iride01:
That said, for what it's worth: I'm a dedicated "flat bar" road cyclist and I don't for one moment believe that flat bars provide inherently "improved handling" relative to drop bars, and certainly not for road cycling. Nor, again for what it's worth, do I believe the converse. The choice, for recreational (i.e. non-competitive) road cycling is simply down to individual preference.
Likes For badger1:
Your 'question' is predicated on a massive and unsupportable unargued assumption. I'm quite sure that was intentional.
Liked 5,005 Times
Flat bars are usually much wider than drop bars. So they might be favored for rough off-road terrain as the extra width give you leverage advantage over the bumps that are trying to make the wheel go where you don't want it to go.
But I don't see where tire width is going to favor one bar type over the other. Terrain, maybe. But have you watched cyclocross?
Likes For Iride01:
But never mind, enough. I'm pretty sure this thread will reach multiple pages (so, well done!!) but I'm out.
Use some common sense. Any bike that would potentially reach the tipping point would obviously be ridden off-road. No reasonable person would assume I was referring to a road bike with 32mm tires. I'm referring to gravel bikes with clearances of 45mm+. I didn't think I needed to specify that, but apparently I did...
Liked 5,005 Times
Perhaps you thought you were in here.... Mountain Biking or maybe here... Hybrid Bicycles
Likes For Iride01:
OP's opening sentence (in General Cycling, mind you): "In recent years there's been an increase in tire clearance for drop bar bikes."
Show of hands: who immediately concluded the reference was to the recent increase of tire clearance for conventional (i.e., drop-bar) road bikes (and that the comparison was to flat-bar road bikes)? [Answer: everyone so far, and likely all or almost all to come.]
Who assumed the reference was to off-road bikes?
[Crickets. . . . ]
FWIW, "flat bar" is almost exclusively used in referring to road bikes that are configured as such. I don't think I've seen the term used to categorize off-road bikes.
[Crickets. . . . ]
Likes For Trakhak:
Habitual User
Liked 8,478 Times
Regarding your topic...
I don't know that you can draw a hard line between when a flat bar is better as it relates to tire width. "Better" is tremendously subjective, and varies a lot with terrain, as well. There is also the fact that some people enjoy the challenge of riding a less-than-ideal bike in conditions that push the limits of what it is capable of.
Likes For Eric F:
working on my sandal tan
Liked 2,579 Times
OP is bizarre. No matter how big my tires get (or how much room is around them), I never find myself wishing for flat bars.
Likes For ThermionicScott:
Liked 5,005 Times
But common sense should dictate that at some point you won't want the drop bars on your mountain bike....... <grin>
Liked 4,074 Times
Observation here. Drop bar bikes are just returning to the clearances used in the past. We had several decades of clearance dropping as roads improved and road races rarely saw non-pavement. But prior? Say pre-WW2? Much bigger tires and much more clearance on pure road bikes. And around 1900, when many roads weren't graded for cars, let alone paved, still more clearance and bigger tires. Granted in 1900 the drop bar shape was still evolving but by the '20s and '30s the shape was what we know now.
Likes For 79pmooney:
Liked 4,074 Times
Habitual User
Liked 8,478 Times
Part of the equation is industry fashion trends, too. Currently, 650 x 50+, drop bar bikes is a subset of the gravel bike category. Some people refer to these as "monstercross" bikes, among other made-up, mostly-meaningless terms. Would a regular flat-bar, hardtail MTB be better. Maybe, or maybe not. That goes back to what "better" means, and how the individual defines it. On a practical level, maybe the conditions are such where a wider tire gives the kind of performance desired over a specific type/mix of terrain, but a lower, narrower body position, with more options for hands positions is also favorable.
My overall point is that making rigid judgements about how bikes should be one way or another way - or should fit into specific boxes - is usually a mistake. From what I've seen, there are ALWAYS counter-examples with reasonable and practical justifications for why it suits the rider's needs. I got my eyes opened to this very issue on a recent thread about hybrids.
Likes For Eric F:
Liked 5,005 Times
Though we'd have to decide if his tire widths were the tipping point or were they optimum size for a drop bar over a flat bar?
Habitual User
Liked 8,478 Times
cowboy, steel horse, etc
Bikes: everywhere
Liked 7,995 Times
Use whatever you like.
#nolimits
#nolimits
![](https://scontent.fphx1-1.fna.fbcdn.net/v/t39.30808-6/324741296_504987645079765_6995050527922663233_n.jpg?stp=cp6_dst-jpg&_nc_cat=106&ccb=1-7&_nc_sid=5cd70e&_nc_ohc=ep5ghNOzIbgAX_U9jQI&_nc_ht=scontent.fphx1-1.fna&oh=00_AfCD-lKtSdv2094JpNygpdOiHG9-Kq_Q4VoAuHN4c11Iaw&oe=63C2071A)
Likes For LesterOfPuppets:
Bikes: everywhere
Liked 7,995 Times
I don't recall Ned running drops BITD, several folks did though.
Ned did rock these badass Profile bars though
![](https://thebodymechanic.com.au/wp-content/uploads/2015/04/Profilebars.jpg)
I have both flat bars and drop bars, several of both, and for maximum control I'd always rather have drop bars. When we are out riding the hardpack dirt/gravel roads and come to a stretch where there's washboard, ruts, potholes, loose gravel, whatever, I sometimes wish I were riding drops instead of the flat bars that I usually ride on these roads. You can get more even weight distribution front-to-rear, it gives you a lower center of gravity on the bike, and your grip on the handlebars is more secure and natural. Dirt drops are popular for a reason.
Guest
I see no correlation between tire width and handlebar shape; I could ride drops with 2.8" tires or flat bars with 25mm. It all depends on the terrain and riding surface, and there’s no tipping point.
Likes For Rolla:
I have a strong preference for drop bars if I need maximum control - I just feel more secure on the bike riding the drops. Same reason that when I need maximum control, I get off the hoods and down into the drops. Don't most people do that? You're riding along on the hoods or the ramps enjoying the ride and all of a sudden you see something up ahead that makes you go "Uh-oh." And you know you're going to need a combination of good bike handling and possibly powerful braking. Don't you drop down?
Likes For Jeff Neese:
Clark W. Griswold
Liked 4,234 Times
Use whatever bars you want and whatever width tires you want. Up to a point wider tires are better on the road and generally fat bike tires are going to be really slow and sluggish till you hit soft and loose stuff like sand and snow.
I say bring on more tire clearance on all bikes and bring on more road and gravel tires in wider widths and also more fun handlebars. Koga Denhams, Velo Orange Crazy Bars, Surly Molokos, ultra wide gravel drop bars, Scott Drop Ins, whatever just bring us more fun stuff with different hand positions.
Bikes: 1974 Masi GC, 1982 Trek 728 (aka 720), 1992 Trek Multitrack 750
Liked 237 Times
It is interesting to be around long enough to see the pendulum swing from generous tire clearances to ultra, ultra tight back to generous.
Likes For HelpSingularity:
Live not by lies.
I purchased a (I think, zero braze-ons and twin plate crown) 1974 Masi Gran Criterium brand new in 1975 (750 bucks), a top of the line racing bike back then. I still have it. It can fit 32x622 tires on it with lots of clearance to spare. I watched (in amusement and amazement) in the late eighties and beyond as the clearances got tighter and tighter. Now I look at those bikes and consider them almost useless (not really, but sorta) as the last thing I want to do is bounce around on our (sometimes horrible) roads with 23-622 tires (or skinnier) at 120 psi.
But I definitely want bigger tires around most working class LA neighborhoods.
PV? Beverly Hills? Probably get away with wrapping your rim in electrical tape.
