How to mount TA bottle cage
Fuji Fan
This question is for those who worked in bike shops back in the day. What is the trick to mounting a TA bottle cage while using the original bolt? Do I just need to apply a more liberal use of foul language to get it to reach?
Likes For beech333:
Bianchi Goddess
Quoted: 2954 Post(s)
Liked 2,987 Times
Try holding everything together and pinchig the "ears" with a pair of pliers and see if that give you a few threads to work with.
Sugar "Kane" Kowalczyk
Likes For Bianchigirll:
Quoted: 1836 Post(s)
Liked 3,434 Times
A slightly more productive method might be to use a longer bolt to get everything "settled" into place, and then replace it with the T.A. bolt. This will help get the "ears" properly bent into the final shape.
I've struggled with this myself, especially with the handlebar cage.
While there aren't really issues with just using a longer generic bolt, it is nice to use the intended bolt.
I do like the T.A. Criterium cage. Very simple mount and very effective. No plastic bits to get old and brittle either.
Steve in Peoria
Likes For steelbikeguy:
Fuji Fan
I did some digging around and also found out that some came with some sort of plastic insert to presumably protect the frame. I imagine those being even worse. So far, I think I have mounted 4 of those cages, and I got a longer bolt for all of them.
Bikes: Several
Quoted: 207 Post(s)
Liked 1,048 Times
I suspect some of these clips were made for French diameter tubing. The difference in circumference (28mm vs 28.6mm) is about 3mm. I had to use a longer bolt to fit mine.
My collection: 1947 Ciclo Piave, 1955 Liberia, 1969 Colnago Super, 1972 Legnano Olimpiade Record Specialissima, 1980 Mercian Vincitore, 1983 Gitane Interclub, 1985 Peugeot PGN10, 1986 Bianchi Vittoria, 1987 De Rosa Professional, 1989 Vitus 979, 1990 Bianchi Axis, 1990 Specialized Sirrus, 2001 Colnago Dream B-Stay, 2007 Trek 1000
Likes For Brad L:
Ride, Wrench, Swap, Race
Quoted: 1566 Post(s)
Liked 1,303 Times
I've always just started with a longer bolt and then refitted the original bolt, same as with most clamps for two-bolt cages.
My favorite by far is the REG cage with spring latch and two integral clamps, which seem easier to install.
Likes For dddd:
aged to perfection
Quoted: 852 Post(s)
Liked 1,282 Times
get a longer bolt and use that to squeeze the ears of the bracket together
then re-install the original if you can make it fit
I do not care for this type of clamp.
you might line the inside surface of the clamp with clear tape trimmed to shape
/markp
/markp
Likes For mpetry912:
Crawlin' up, flyin' down
Quoted: 1054 Post(s)
Liked 2,604 Times
I use a longer bolt and then leave the longer bolt place because (1) I'm lazy and (2) by the time I've managed to install the cage I've had enough fun for one day.
As for the appropriate language for cursing, French won't get it done because, even if you are calling someone the most unholy of unholies seven times over, it sounds like suave dinner conversation or a smooth seduction when said in French. Anglo-Saxon has always worked for me. The trick is to come up with new combinations and variations.
Thread derailleur
Bikes: Croll '94 & Cannondale Supersix '15
Quoted: 378 Post(s)
Liked 477 Times
I use one of these on my vintage rides. Never leaves a scratch.
Those old TA and Reg cages mar frames endlessly.
Universal Cycles -- SKS Anywhere Velocage Strap Mount Bottle Cage [11569]
Fuji Fan
I recommend cursing in French... although I haven't really tried that myself.
Thread derailleur
Quoted: 378 Post(s)
Liked 477 Times
Works well for the occasional vintage ride. Then, off it comes. Gotta hydrate!
vintage motor
Bikes: 48 Automoto, 49 Stallard, 50 Rotrax, 62 Jack Taylor, 67 Atala, 68 Lejeune, 72-74-75 Motobecanes, 73 RIH, 71 Zieleman, 74 Raleigh, 78 Windsor, 83 Messina (Villata), 84 Brazzo (Losa), 85 Davidson, 90 Diamondback, 92 Kestrel
Quoted: 166 Post(s)
Liked 103 Times
Kind of like strap-on LED lights: they work great, on and off in seconds, plus you only need one set for your entire fleet. The only problem with that cage is that it will be visible during the daytime.
Thread derailleur
Quoted: 378 Post(s)
Liked 477 Times
No modern lights, clothing, helmet. Must ride toeclips and Detto Pietros.
Plus, old leaky water bottles and Silca frame pump.
All in jest, of course, but one must draw the line somewhere!
