Does anyone else have "moto"/European-style brakes + rear shifter on the left?
Bikes: Bianchi Volpe, ANT 3-speed roadster, New Albion Privateer singlespeed, Raleigh One Way singlespeed, Raleigh Professional "retro roadie" rebuild, 198? Fuji(?) franken-5-speed, 1937 Raleigh Tourist, 1952 Raleigh Sports, 1966 Raleigh Sports step-through
Quoted: 248 Post(s)
Liked 27 Times
I use what I think is an unusual combination, especially for the US. I have an old 3-speed, and I've completely reversed the hand controls. I have my right brake lever controlling the front brake, left controlling the rear, and the shifter for my Sturmey-Archer 3-speed hub is on the left as well.
The reason for moving the shifter to the left was that I use my front brake primarily, and prefer to not have my shifting and braking done by the same hand, so that I can more easily do both at once, such as when approaching an intersection.
I've been looking at some new 3-speeds, like the Breezer Uptown, Giant Via 1, Raleigh Classic Roadster, etc., and all of them have a twist shifter, on the right. I'm curious as to whether anyone has swapped the controls around, and how difficult that is with a twist shifter.
Bike Sorceress
Bikes: Yes
Quoted: 66 Post(s)
Liked 125 Times
With a twist shifter, I think the only issue would be the shifting seeming backwards. I know that when I ride a bike with an Alfine/Nexus hub, the reversed shifting drives me crazy. If the bike you pick has a Sturmey Archer hub, you have a number of options if you want to swap, or with Shimano you just have the twist shift, or maybe the old thumb shifter.
Quoted: 239 Post(s)
Liked 7 Times
I use euro style brakes, but the shifters are default orientation. Front brake primary, rear derailer primary, both on right hand. Hasnt been an issue.
One bike uses bar end shifters, so its easy to shift across the cassette fast before moving hand to brake lever when approaching intersection.
The other uses ergopower brifters, so one hand can do everything...
No reason you cant put your gripshifter on the opposite side.... you'll just have to read the display upside down.
Membership Not Required
Bikes: Giant Excursion, Raleigh Sports, Raleigh R.S.W. Compact, Motobecane? and about 20 more! OMG
Quoted: 70 Post(s)
Liked 16 Times
I haven't moved any shifters. But all of my bikes are set up (with one exception) with the front brake on the right. FWIW I drove a RHD car for several years and had no problem shifting with my left hand, then getting into a LHD car and shifting with my right.
Aaron
Aaron
Webshots is bailing out, if you find any of my posts with corrupt picture files and want to see them corrected please let me know. :(
ISO: A late 1980's Giant Iguana MTB frameset (or complete bike) 23" Red with yellow graphics.
"Cycling should be a way of life, not a hobby.
RIDE, YOU FOOL, RIDE!"_Nicodemus
"Steel: nearly a thousand years of metallurgical development
Aluminum: barely a hundred
Which one would you rather have under your butt at 30mph?"_krazygluon
Thread Killer
Quoted: 3270 Post(s)
Liked 1,810 Times
I run front brake on the right on all of my bikes, two of which have Sram twist shifters. I don't have any trouble braking and downshifting at the same time, which is accomplished by angling my hand the right amount before starting to brake/shift so that I'm sure to have enough range of motion to twist down through a couple of gears.
One thing to consider in all of this is that some shifters twist forward to downshift, which makes maintaining (and increasing) pressure on the brake lever while downshifting clumsy and awkward. It's much easier and intuitive to twist backwards to downshift and brake at the same time because you're pulling the brake lever into the bar at the same time.
Bikes: 80's Marin, 90's Dawes, ALAN & various unicycles.
For me it has to be front brake on the right & always has been, in the 30 odd years of riding bicycles I've ridden motorbikes as well so the front brake has to be the same on the right, the other way round would be plain dangerous.
It's a shame the R/H/side isn't a standard for the front brake on bicycles.
Quoted: 239 Post(s)
Liked 7 Times
But it is the standard. Along with driving on the left side of the road. And the Metric system.
Location: Beaufort, South Carolina, USA and surrounding islands.
Bikes: Cannondale R500, Motobecane Messenger
Quoted: 11 Post(s)
The first time I made this modification for a customer, he promptly flipped over testing the bike, breaking his collarbone and suing the shop. That shop refused to perform this modification after that incident.
Quoted: 248 Post(s)
Liked 27 Times
Why the hell would he sue the shop if it was something he requested? It did definitely take me a little time to get used to the switch when I did it, but I was already anticipating the need to modulate the brakes, so I didn't flip over the handlebars.
Quoted: 70 Post(s)
Liked 16 Times
Aaron
I have my brakes reversed such that the right lever is for the front brake. The only reason I did this was because I didn't know buying a brake from Chain Reaction in Ireland meant that it would be reversed.
At first it did annoy me having to shift the rear derailleur and brake with the same hand, but it's been 6 months and I've gotten used to it. I have Shimano trigger shifters if it means anything.
Quoted: 551 Post(s)
Liked 278 Times
I have always put my front brakes on the right. That's just from my motorcyle riding days.
Really, who shifts and brakes at the same time?
I used to put my mountain bike front brake on the right because I used to race dirt bikes and was used to that. Now I just leave it the way it comes and have no problems adjusting.
Yea have several, my loaded touring bike, taking on get off and push routes,
it came in handy.. holding the rear brake, and catching my breath..
IDK, about the particular 3 speed,[ un stated] you are not stuck with the grip shifter,
just because it comes in the box the brands contract, assembly line put it on/in the carton.
SA has 3 lever choices.. + Sun-Race NIG redesign eliminated the in-between 2-3 error ..
so a friction lever will work.
IDK maybe the left for FD on a triple crank goes click with adequate cable pull..
2 cable grip shifter, like Rohloff , you just swap what each cable is attached to on the other end.
Formerly Known as Newbie
Nothing "European" about it. All the bikes I've seen over here have the "right-rear", "left-front" setup.
And regarding braking and shifting at the same time, I do it daily during the commute. When I approach a red light, or busy intersection, slow down and prepare to accelerate again - I have to downshift at some point during braking. IGH users needn't bother, they can shift while standing still if they want to.
To err is human. To moo is bovine.
Who is this General Failure anyway, and why is he reading my drive?
Become a Registered Member in Bike Forums
Community guidelines
Moto is often the label.
motorcycles use one hand-lever for the Clutch. the other the front brake ..
rear brake, is operated from a foot pedal, gear shift is on the other foot.
Raiden
Bicycle Mechanics
4
05-10-15 09:09 PM
FreakyFast
Bicycle Mechanics
26
03-02-12 03:35 AM
SouthshoreMIL
Bicycle Mechanics
16
07-19-10 11:09 PM
