Go Back  Bike Forums > Bike Forums > Fitting Your Bike
Man what a difference 1 cm can make
Fitting Your Bike Are you confused about how you should fit a bike to your particular body dimensions? Have you been reading, found the terms Merxx or French Fit, and don’t know what you need? Every style of riding is different- in how you fit the bike to you, and the sizing of the bike itself. It’s more than just measuring your height, reach and inseam. With the help of Bike Fitting, you’ll be able to find the right fit for your frame size, style of riding, and your particular dimensions. Here ya’ go…..the location for everything fit related.
Old 06-17-13, 07:36 PM
GeneO
GeneO's Avatar
Bikes: 2018 Roubaix Expert Di2, 2016 Diverge Expert X1
Liked 152 Times in 106 Posts
After long rides my quads were hammered but nothing else. Hurt to walk up steps. After some research here and elsewhere on fitting, I moved my cleats back 1 cm so the ball of my (size 13) foot was > 1 cm in front of the pedal spindle. Man what a difference! I had more power and my legs were less tired and more evenly tired after the ride and my quads didn't really hurt the next day. It is amazing what 1cm can do for you!
GeneO is offline
Old 06-18-13, 10:31 AM
zandoval
zandoval's Avatar
Liked 1,870 Times in 1,200 Posts
Agreed - Some riders get so carried away with the math of fitting that they fail to just make simple adjustments here and there - Looks like you found a good one...
But when making adjustments be sure you can get back to the original setting... Just in case...
zandoval is offline
Old 06-18-13, 03:01 PM
wheelreason
Liked 1,098 Times in 631 Posts
Sometimes its the mere act of changing that causes the perceived improvement. Keeping track of where you started, and being able to go back is important. Also I'm not a fan of changing several things at a time, but hey, whatever works, I gotta pay off this Guru thing, next....
wheelreason is offline
Old 06-18-13, 04:21 PM
DannoXYZ
DannoXYZ's Avatar
Liked 10 Times in 6 Posts
My wife says the extra 1cm really makes a difference too!
DannoXYZ is offline
Old 06-18-13, 09:14 PM
GeneO
GeneO's Avatar
OK, I will be nice and not try to guess what % that is LOL
GeneO is offline
Likes For GeneO:
Old 06-18-13, 09:18 PM
GeneO
GeneO's Avatar
Yeah. But not suggestion here. It really did make a big difference. I know where you are coming from though - I try and change one thing at a time and my bike has rules along the seatpost and rails. So there I can easily go back.
Cheers
GeneO is offline
Old 06-22-13, 01:41 AM
Lenton58
Lenton58's Avatar
Location: Sendai, Japan: Tohoku region (Northern Honshu))
Bikes: Vitus 979, Simplon 4-Star, Woodrup, Gazelle AB, Dawes Atlantis
Liked 76 Times in 43 Posts
I cm can mean a lot for me. I can spend a large part of an evening moving stuff around — carrying Allen wrenches in my teeth and riding up and down my block. Sometimes I think even .50 cm makes a difference, but some people might think I'm weird for thinking so. Well maybe I am, but then maybe they are not 65 years old yet.
Vitus 979, Simplon 4 Star, Gazelle Champion Mondial, Woodrup Giro, Dawes Atlantis
Lenton58 is offline
Old 06-23-13, 09:25 PM
joejeweler
You must not have been "clipped" as a youngster!
joejeweler is offline
Old 06-22-19, 05:48 AM
VeeBee
every minor change helps. Somethings the pro bikefitters get things a little wrong, so you still have to adjust until feeling 100%
VeeBee is offline
Old 06-22-19, 10:36 AM
ChinookTx
Bikes: Lynskey GR270
Liked 69 Times in 49 Posts
Isn't the term "clipless"? ;-)
ChinookTx is offline
Old 06-22-19, 10:50 AM
catgita
catgita's Avatar
Bikes: Fitz randonneuse, Trek Superfly/AL, Tsunami SS, Bacchetta, HPV Speed Machine, Rans Screamer
Liked 5 Times in 5 Posts
Over the last 20 years I have done an almost blank slate refit on each new bike. I set the saddle position the same, but the bar height, stem length, and cleat position I did just from feel. Ride a few weeks, see what hurts, tweak, repeat. Then I compared my dimensions from 1993, and the biggest deviation was 3mm, in stem length, and that was probably because the hoods changed shape over the years. Even did a new pro fit recently, and all he did is move my cleat back about 2mm, but I could not feel the difference.
catgita is offline
Old 06-22-19, 04:03 PM
fietsbob
Bikes: 8
Liked 1,367 Times in 871 Posts
It's less than 1/2 " (12.7mm)
fietsbob is offline
Old 06-24-19, 05:11 PM
berner
Liked 496 Times in 299 Posts
I'm a big fan of adjusting the bike here and there. You might think that after a good many miles or years, bike fit would be dialed in for all time. Not so. just as the Universe has been changing from the first moment of it's existence, we do to. Recently I've lost some weight and suddenly the saddle, which has been comfortable for thousands of miles, has been causing discomfort. After several saddle adjustments to no avail, I figured out the problem was the loss of weight. My fix is simple. Just become accustomed to the new norm.
berner is offline
ldarlee
Fitting Your Bike
6
09-22-16 11:15 AM
pakossa
Fitting Your Bike
2
06-18-16 07:07 AM
greenbubba
Fitting Your Bike
26
07-29-14 05:55 PM
Dragonguy83
General Cycling Discussion
2
05-08-13 08:35 AM
