Addiction 2024.2
#3226
Klaatu..Verata..Necktie?
Liked 12,426 Times
From what you've said, it sounds like the air there could work like an air fryer all by itself.
#3227
Liked 12,426 Times
Everything is coming together for the LeMond project. I have all the bits but one - well, two really. The cable stops for the shifter bosses should arrive today.
Yesterday I got the tool for removing and installing Shimano cartridge BBs, so I pulled the old one, which came with the bike back in 1997. I was pleased that the cups came out pretty easily - a bit of grunt to get them unstuck, but then they came out easily. a little surface rust on one side, presumably on the bottom of the BB. Luckily only surface rust in the shell that mostly came out by wiping with a paper towel.
I tested the threads with the new BB's cups, and boy, I can see how you could really screw up! I did the usual "turn backwards till it drops into the threads on the NDS, and it spun in a turn or so and stopped. Not being an idiot, I backed it out. Third time it engaged the threads right, and just spun in with very little effort.
The last tools I'm waiting for are for the headset. I didn't realize it but changing a headset requires 4 tools - one to remove the lower cup and upper race from the head tube; one to remove the fork crown race; a press to insert the new lower cup and upper race; and one to install the new fork crown race. I went with "cheap and cheerful", figuring this isn't my profession and I didn't need to spend $400 on the top-of-the-line Park Tools version. I tried to source them from the US, but it turns out that at least one of the sellers is a Chinese company, even though the listing says the item is in St Louis. I'm curious to see where it arrives from. Of course, I do expect cheap-and-cheerful tools to come from China originally, but I didn't want to wait on the vagaries of international shipping.
Likes For genejockey:
#3228
Bikes: Time Scylon, Lynskey R350, Ritchey Breakaway, Ritchey Double Switchback, Lynskey Ridgeline, ICAN Fatbike
Liked 572 Times
The M-Deities here wouldn't believe that she had formerly been an RA patient, but it was in her records... Yes, we spent a lot of money on it, and our insurance spent even more. But it did work for her.
Likes For DangerousDanR:
#3229
Liked 572 Times
From what I've read, in order to work on an induction stove, a pan has to be magnetic, i.e. it's not enough that it be stainless. I tested all my stainless skillets, and only one was magnetic. It's also got a copper core, so it should be perfect for induction. The others, a magnet wouldn't stick to at all. All my saucepans and stockpots are aluminum, and I have some heavy copper saucepans and sautoirs, which absolutely won't work. ![Frown](images/smilies/frown.gif)
Our induction stove can make a wok glow red hot to make wonderful stir fry. Boils a tea kettle faster than anything I have seen before, and on the lowest setting with the correct pan can melt chocolate and hold it at under 120F.
I firmly believe that people should be able to buy whatever type of stove they want. I have a wood fired oven in the back yard. But inside my house I am not wild about an open flame, unless you can arrange a way to suck all the combustion gases outside.
#3230
Bikes: 2022 Gt Avalanche
Liked 1,957 Times
A question:
I have the mountain bike up in the stand , looking for an intermittent rotational click. While attempting to pull the nds crank arm I found this plastic gizmo. When it comes out, this nice steel cap screws in. On the ds I don’t know how to get the plastic thing out, but it appears to be only a thread protector.
Another question:
When I get the bolt out, does the crank come off with a run of the mill peanut butter wrench?
And another.
Checking all bolts for tightness,I’m finding movement in many places. Is there a torque value on the bolts that fasten the stem to the fork tube? Or can I just crank them down? Surprisingly the four chainring bolts were less than fully tight. And the handlebar bolts. I was gonna change the pedals for the second time, but that wouldn’t be much of a scientific test. Vamos a ver.
Another question:
And another.
![](https://cimg0.ibsrv.net/gimg/bikeforums.net-vbulletin/2000x1504/img_0339_c4163d8c4fea349ef82b99d4895ddfb3022f8ce1.jpeg)
#3231
Liked 12,426 Times
Yes, to work correctly the pans used on an induction stove must be magnetic. We packed up the ones with copper or aluminum bottoms and sent them to our daughter. One was the Cuisinart griddle that has a couple of pounds of copper in the base. I bought is as a gift for my mother, then inherited it from her. Now her namesake grandchild has it.
#3232
Liked 3,781 Times
First real money century in…4 years?
Planned for 85, on my way back down one of the climbs I ran in to some folks I know heading out on an 8 day bikepacking trip so I ended up riding with them for 3 miles or so going to opposite way I was headed.
Felt great up through mile 80 or so, decided to tack on another 6ish miles to get to the full 100. Legs and back blew up right at mile 90 so the last little bit was pretty miserable.
8/10 ride though. 6500 feet or so in the middle 80 miles. Would do again.
![](https://cimg0.ibsrv.net/gimg/bikeforums.net-vbulletin/2000x1504/img_4516_9ccb3d540e860d228391e3ef7dc5637b1f7ae540.jpeg)
![](https://cimg2.ibsrv.net/gimg/bikeforums.net-vbulletin/2000x1504/img_4518_bca9bbda6ccf687d1d0c83ce55124ad298d33256.jpeg)
Must have bought sweet instead of dill inadvertently. No other reason I can think to discard a full jar.
![](https://cimg4.ibsrv.net/gimg/bikeforums.net-vbulletin/2000x1504/img_4521_b6e4e142880a9407c0e5a60bc1568809e124d6e5.jpeg)
![](https://cimg5.ibsrv.net/gimg/bikeforums.net-vbulletin/2000x1504/img_4524_1f9ac839bc8548feeebdede126b8437c8d65f7d7.jpeg)
![](https://cimg7.ibsrv.net/gimg/bikeforums.net-vbulletin/2000x1504/img_4526_fdd16fe1a60fcf8aca8728e9eff1099a67ef3965.jpeg)
Big Trek Travel group at my water refill stop.
![](https://cimg8.ibsrv.net/gimg/bikeforums.net-vbulletin/2000x1504/img_4528_f625282474f722b31be861382c2cfe9854549bb8.jpeg)
#3233
Liked 9,456 Times
Did my friend's birthday ride. 5 of us, 3 e-bikes and 2 regular bikes. 76 miles with 5600 feet. Had some wind but got lucky with tailwinds for most of the long climb and more tailwind on a section of rollers where we expected head wind. Of course, we had vicious headwind on the 10% section which my friend said made it feel 4% steeper. 30mph gusts and swirling wind on the long descent. Long day.
#3234
It’s raining in camp. I’m bushed. I was the only on in the fastest group carrying their gear. My computer battery died before the start, so I can’t say for sure how fast we were going, but it was certainly more than the 12 mph it was supposed to be. I joined up with a slower group after the stop at mile 23, and even they weren’t exactly slow. And it was quite warm. 38 miles in all, with a couple of nasty hills at the end. It was nice to push myself to at least try to keep up.
#3235
Liked 1,957 Times
Pretty country.
#3236
VFL For Life
Bikes: Velo Volmobile
Liked 1,942 Times
I took Humira for a couple years or so. Stopped it not due to remission, but rather because it stopped working. Sad.
#3237
VFL For Life
Liked 1,942 Times
#3238
cowboy, steel horse, etc
Bikes: everywhere
Liked 8,021 Times
#3239
Silver Comet Fred
Tuesday is moving day. Yesterday the wife and I took 3 trips each to the new house with our SUV's loaded with totes full of junk. We will repeat the same today and tomorrow. With an almost 1 hour round trip it took 6 hours hauling that from our basement to the cars then up to the attic of the new place. After we were done we showered and ate pizza at about 3:30 PM. When I got back, I slept from around 5 until 7:30.
Just to confirm my suspicion, I got on the scale and I've lost 10 pounds in the last month or so. Back at 171 but I'd still need to lose 30 pounds before I wasn't too fat for this sport.
I hope I make it through today and tomorrow. I've got to cut the grass today at the new place, thank God it only takes 25 minutes. Rain 80% chance for tomorrow.
#NoRestForTheWicked
#NoRestForTheWicked
Likes For DougRNS:
#3240
Super Modest
Liked 4,801 Times
I'm a stress eater. Guess what I stress about the most? Gaining weight.
Keep the chain tight!
#3241
Super Modest
Liked 4,801 Times
Rain this morning. Rain starting again mid morning. Rain again this afternoon and again tonight. It's going to be one of those days where it looks like it's going to dry up enough for a ride and then it rains.
Errands and Netflix day.
#3242
Administrator
Liked 6,882 Times
Half sours are my preference.
#3243
Administrator
Liked 6,882 Times
#NoRestForTheWicked
#NoRestForTheWicked
#3244
So it is
Liked 4,924 Times
#vortextheory #DarrellWaltrip
#3245
Liked 3,781 Times
Looked to me like all the juice was gone. Nobody wants a dried out pickle.
Can't say I've ever had those.
#3246
Liked 1,957 Times
2.
Well well well. A deep subject. I spent the whole ride going through the list to try and isolate the noise. It, or the bulk of it is resonating through the frame. Getting out of the saddle doesn’t do it. Backpedaling either. Coasting stops it. And then in the last half km it dawned on me. I’m not clipped in and I have a steady tick tock on each down stroke. It has Truvative mtb pedals on it, with the spikes, so with effort and concentration I can pedal circles. And that silenced it. But it’s not a solution I can live with. It’s a start though.
#3247
Liked 3,781 Times
Oh dang that was sub 7h moving time. I felt really slow but that was by far the fastest 100 I've ever done, and the hilliest by about 3k.
![happy b-day](images/smilies/bday.gif)
Of course, those other long rides I did were back when I was all in on 650b mid-century constructeur bike cosplay. 20lb road bike is a bit easier to push than 30lb vintage steel with a lunchbox on the front.
Likes For abshipp:
#3248
Liked 9,456 Times
#3249
Not actually Tmonk
Bikes: road, track, mtb
Liked 3,485 Times
SCNCA district TTT champs, 4 man 140+ combined age division: 3rd/3 teams. Time for the 40k was 50:52, but that should have been 90 or so seconds faster.
We missed a turn while I was on front… oops. I’d raced it several times before too. No biggie, we recognized it quickly thanks to a No Outlet sign (lol) and got back on course. Checking Strava Flyby, it may have been up to 90 seconds. That might have been good enough for second, the first place team was just too fast with a 48:23.
This year was totally wild due to a 20-23 MPH prevailing wind from West to East. I knew that as well on the weather report… should have brought a different front wheel. I was on a 90 mm wheel and the lightest rider.
TBH I was only able to put out my full intended power on the tailwind stretch of the rectangle (which gets ridden twice); during the other three lengths I was mostly focused on not crashing haha. I felt pretty sketched out in our echelon on the crosswind lengths. A teammate rubbing against my disc wheel once didn’t help. On the final, second tailwind straight, I had tons of gas left and was doing 1 minute turns at 320-350 watts, not often you get to go 32 MPH up a rolling false flat! I heard “DOWN, DOWN” a couple times when I was trying to empty the tank
But most importantly – we had fun! Good energy and vibes out there and great communication, we were really in sync. This year, I was the team captain, strongest workhorse, and the only rider with prior experience in the discipline on our team. We now have three new TTT riders that are absolutely stoked on next year’s race – I call that a win in my book!
![](https://cimg6.ibsrv.net/gimg/bikeforums.net-vbulletin/2000x1504/2024_05_25_ttt_start_e6546bb64d128318bdb2a9fa5523cbd0853252e9.jpeg)
at the start line, I'm the closest rider (in the blue kit)
![](https://cimg8.ibsrv.net/gimg/bikeforums.net-vbulletin/562x790/2024_05_25_ttt_finish_f30a77a5dcd0056475e637b163e78d727c584351.png)
obligatory team photo on the box. I'm the smaller of the two on the top step with the blue socks
![Smilie](images/smilies/smile.gif)
"Your beauty is an aeroplane;
#3250
Not actually Tmonk
Liked 3,485 Times
