Tried Riding Gravel ... Meh
Bikes: SuperSix Evo | Revolt
Quoted: 733 Post(s)
Liked 815 Times
I just bought 30 TPI tires which I run at 60 PSI. Will dropping to 40 really make a difference? I also wonder whether a higher TPI tire will help.
Rides4Beer Totally agree. The lack of traffic is a huge plus.
caloso I see your in the Sacrmanto area. I am there for work and did these rides on the West Sacramento Levees (River Rd). I did notice there are some "forest" trails along the American River Bike Trail but it seems most are off limits to cyclists (limited to horses and hikers). Any suggestions for forest style trails in your area?
Thanks!
Thanks!
I ride gravel like this at high speeds with no issues at 38psi, totally comfortable.
Likes For Rides4Beer:
Quoted: 18596 Post(s)
Liked 16,096 Times
I remember climbing Sherman Pass in WA for the first time and stopping at an old burn area from a large fire. There were interpretive board explaining the benefits of fires. Burning away the old trees allows new ones to start growing. The new vegetation that springs up from the no longer canopy covered ground provides food for creatures such as deer. And woodpeckers and other types of birds thrive off the insects that that set up home in the brunt trees. Pretty neat. Neat enough that I stopped in a light snow to check it out.
Likes For indyfabz:
Quoted: 5234 Post(s)
Liked 3,609 Times
fwiw - on my MTB w 2.25" tires I run 21 psi front 25 psi rear w/ tubes
Gravel riding is a lot like mtb. The bike logs most of its miles in or on your car or truck. There is no gravel where I live, unless folks are calling mtb trails gravel. You might find a short stretch somewhere, off a paved road, but it won't be very long and may be a private path to someone's home, where you are not welcome.
Quoted: 18883 Post(s)
Liked 10,646 Times
Like it or not, gravel is an ambiguous term - what you describe as "actual gravel" is no more of a standard than a dozen others. Aggregate size and uniformity as well as composition will vary from region to region and application to application.
Around here, the most common would be limestone Class 5 gravel. Class 5 has chunks up to ~1" along with smaller stuff that serves as a binder and will eventually pack down well. Limestone is sedimentary and the bigger chunks will break down the more it's traveled upon. It can be exceptionally smooth and fast, but you'll also hit washboard sections and plenty of loose stuff.
Any gravel without a sufficient binder, like what you describe, is a pain in the ass.
Quoted: 8445 Post(s)
Liked 9,402 Times
Some friends have started doing gravel type rides and I was thinking about putting some fatter tires on an old touring bike I have and joining them to see if I like it.
Do the All Around type tires wear faster when you ride them on the road? I was thinking of trying some regular road tires on the dirt. I've ridden my road bikes on dirt on 23s before.
meh
Quoted: 1112 Post(s)
Liked 1,013 Times
That said, nearly every gravel race has an issue with parking, most people will not ride to the race or car-pool.
Quoted: 529 Post(s)
Liked 255 Times
Gravel is a loose aggregation of rock fragments. Gravel is classified by particle size. ISO 14688 grades gravels as:
fine - 2 mm to 6.3 mm
medium - 6.3 mm to 20 mm
coarse - 20 mm to 63 mm
Likes For alo:
Liked 16,096 Times
Likes For indyfabz:
Liked 16,096 Times
15 miles. 3,300' of elevation gain. Four vehicles.
Former Milwaukee Road right of way outside of Avery, ID.
Likes For indyfabz:
Gravel bikes may work on really smooth and compacted trails. Anything more than that and you need an MTB to have a decent comfort.
I don't know of any single trail that is as smooth as the ones pictured here that falls less than a hundred km from my house. No gravel for me.
Sunshine
Quoted: 11100 Post(s)
Liked 7,704 Times
Geography is for sure a consideration- if someone lives in a large metro, there may not be much need/use for a gravel bike. If someone lives in an area with no gravel roads and only has access to ungraded trails, then there may not be much need/use for a gravel bike. I live in a state with over70,000mi of gravel roads and only 3million people. Many can throw a rock off their porch and hit...more rocks on the road out front.
A lot of interest is geographic.
Liked 16,096 Times
I wasn't riding a MTB in any of my shots. Neither was my companion. I was on a Surly LHT with full cooking and camping gear. My companion rode the same bike pulling that trailer. Comfort was decent enough most times. Rockier and wasboardy sections were a bit of a pain, but worth it. The nice thing about riding on extremely low-traffic roads is that you can often ride anywhere on the road that you want, especially if there are good sightlines. That can allow you to find a smoother track. On the roads in my last two photos I spent some time riding what would have been against traffic if there had been any to speak of.
Likes For indyfabz:
Oldie but a Newbie
Bikes: Specialized Diverge Pro Carbon, BH Prisima, Bianchi Volpe, (previously Intense Spyder MTB)
Quoted: 5 Post(s)
Try to alleviate the vibration
As big a tire as your frame will accommodate is the first step. Lower pressure is the second step. Run the lower pressure listed on the side of the tire, or even lower. (Watch out for pinch flat causing situations though. Tubeless setup helps here.) A shock absorbing stem is a good, though pricey, next step. Shock absorbing seat posts can also help, but I would get one with pivots or flexures rather than one that depends on telescoping tubes, they stick.
Pretty sure its different for everyone. For YOU, a gravel bike would only work on really smooth and compacted trails. But for others, many others, a gravel road bike works well on...gravel roads. Many do quite fine riding on gravel roads and not just smooth trails.
Here in southwest IA "gravel" roads are really crushed-rock roads and can be almost as fast as paved roads when they are compacted. That can suddenly change when the dump trucks roll in and unload another top coat of rocks. Then, they become a nightmare to ride on with anything less than 50s. Even then, I just avoid them if I can or just pretend I like it and plow through to a better path.
meh
Liked 1,013 Times
"smooth"? Are you talking about gravel roads or dry creek beds? Gravel grinding is about riding on rural gravel roads and MMR (Minimal Maintenance Roads), mixing in a little single-track and bushwhacking.
I use my gravel bike for single-track trails - Breezer Radar Pro (pic below). I'm very comfortable (see post above about dialing in your tires and pressure). But this Toad also built a drop-bar Pugsley for the Almanzo 100 because of the deep/soft gravel with high-speed descents (I love that rig and ride many gravel races with it every year).
BTW - The joy of gravel grinding, run what you brung. At nearly any gravel race in Minnesota, you see gravel bikes, rigid MTBs, full-suspension MTBs, fatbikes, commuter bikes, tandems, road bikes with 'wide' tires ... hell, I was riding with a guy on a 167-mile race and he's on a comfort bike with grip shifters - Scroll up to post 20 and watch the videos, hard to name a bike that's not on these races (ok ... no recumbents, no unicycles, and not penny-farthings)
Likes For Hypno Toad:
Bikes: No. 22 Bicycle Great Divide, Lynskey R260, Salsa Colossal Ti, Litespeed T5, Lynskey Peloton, Bianchi Vigorelli, CAAD 10, Giant FastRoad CoMax 1, C-Dale Quick 1
Quoted: 50 Post(s)
Liked 36 Times
Where I live in northeast Indiana, the scenery (cornfield or soybean field) riding gravel roads is the same as "paved" chip and seals roads. I'd rather ride the smoother road, never more than one or two miles parallel.
Quoted: 941 Post(s)
Liked 319 Times
I can relate. was having fun on unpaved rail trails until I reached large gravel for about .5-1 mile. quite unpleasant. I think the term "gravel riding" is quite broad. I've since found more pleasant places to ride, mostly dirt or smaller gravel w/ dirt mixed in. I also switched from a rigid fork hybrid type bike to a 29er w a cheap sus. fork
stuff like this is easy enough
this stuff is a lot less fun
keep looking until you find the really fun trails
Liked 3,609 Times
Likes For rumrunn6:
Liked 3,609 Times
another rail line was just abandoned & over the 100 or so years since has filled in w/ debris. parts of it are rideable, but it's no speedway. there's talk of paving it for "bicycles" yuk yuk
the old bridges are a gas
power line gravel can be fun if it's compacted
Likes For rumrunn6:
Quoted: 1975 Post(s)
Liked 232 Times
I think it's a little unhelpful that we refer to anything that isn't pavement as "gravel." I hate riding on actual gravel - pea sized rocks, bunch of them, especially when it's deep. We have a lot of hard packed dirt roads here, and these can be fantastic to ride on.
Like others have said, it's about scenery and traffic. For me it's also about having more places to ride, and about being able to make a loop out of what would be an out-and-back otherwise. I think we only have 5 (?) roads that cross the Cascade Range, and we have a lot of roads (that mostly serve hiking trails) that are paved for about 10 miles, then turn to dirt. We also have a maze of dirt roads throughout the mountains, so I can ride those first 10 miles, and instead of just turning around, I can keep going. Lot of beautiful paved roads, but eventually you get to the point where you've ridden most of the ones that appeal to you.
Quoted: 833 Post(s)
Liked 1,981 Times
The fire and SCE roads near me are hardly inspiring compared to the pics in this thread. For me better scenery is more accessible by asphalt roads then dirt/gravel. I admit I'm just a little envious of the majestic gravel rides I see here.
I do not race. That being said.. I have easy access to a lot of gravel nearby, no car needed to get there. I view the paved sections of my routes as a necessary evil to get to the non paved sections. I have three sets of "gravel" tires mounted that are different and respond differently to changes in pressure and I use each of them for different conditions. Even on a century that may be 50 miles asphalt, I choose the tire and pressure of the day strictly on what I expect on the non paved section. If you pick the wrong tire on the road it's no big deal (assuming no stopwatch involved), you pick the wrong tire for the non road and it can be a literal pain in the... or maybe you just have to be extra careful when you turn ALL DAY. Gravel and trail can mean a lot of different things. Even a single one mile long gravel road can be totally different at one end from the other and be totally different a week later. I enjoy that, constantly finding the right line, hardpack rollercoaster bumps or thick gravel next to it, go through, lift front over, or go around that. Looking ahead and around. It adds a constant mental component and tasks to the physical one. On the road, I just stay glued to the edge of the road, head down and go. It's just a physical challenge at that point and only a mental one to remind the physical one there's more gravel and trails ahead, keep going!!!
This is typical for roughly 1/2 of my 40 mile routine workout, the other is asphalt in random smoothness. The rain actually smooths it out a bit, as it dries the fines settle back down and the gravel pops back up and it gets loose.
Likes For u235:
Quoted: 4079 Post(s)
Liked 7,666 Times
Liked 3,609 Times
https://www.bikeforums.net/cyclocross-gravelbiking-recreational/1098455-gravel-ride-pics.html
