Tubular Rims (polished silver)
Wheelman
Bikes: 1982 Holdsworth Avanti (531), 1961 Holdsworth Cyclone
Liked 732 Times
Looks like eyelets to me.
However it's a bit confusing:
https://ccmflyte.wordpress.com/2013/...isi-sludi-290/
Image from Velobase:
I'll add them with a note
No eyelets
https://cicli-berlinetta.com/product...622-20mm-290g/picture seems to show eyelets
but "We advise using rim washers as there are no eyelets."
https://www.bikeforums.net/4230905-post5.htmlbut "We advise using rim washers as there are no eyelets."
I have a pair of 290's on my Gios. Nice lightweight rim (290g). They use washers under the nipples.
https://www.bikeforums.net/4471644-post2.htmlIf they are Sludi 290's they are a nice lightweight rim. But they do not have eyelets and need to be built with washers under the nipples.
.Image from Velobase:
Likes For chain_whipped:
Wheelman
Liked 732 Times
Here's my final (probably) version:
It looks to me like the best options are
around 400 g
around 375 g
around 350g
Obviously other rims would also work, these just seem to be the most common / well known / trusted.
And here's a couple of adverts I found:
Super Champion
Wolber
around 400 g
Mavic Monthlery Pro (and possibly Route)
.around 375 g
Fiamme Sprint
Fiamme Strada (red label)
.Fiamme Strada (red label)
around 350g
Super Champion Arc en Ciel
Araya 16B (road version)
.Araya 16B (road version)
Super Champion
Wolber
Wheelman
Liked 732 Times
Mavic Monthlery Route 399,402,403,404,404.
.So it looks like Monthlery Route are about 402g
Bikes: 1972 Motobecane Grand Record, 2022 Kona Dew+
Liked 154 Times
Good thread this'n.
I've been (admittedly intermittent) riding my 1972 Motobecane Grande Record since I bought it on Easter Sunday in Chicago, 1972. Was 'new' to road bikes then, so unaware it should have been equipped with clincher rims & tires rather than the Mavic tubulars I'm still riding on... at least once the outdoor biking season begins where I live.
Tires have changed (several times!) since then but the rims are still true, show little brake surface wear.
Did recently build a clincher rear for this bike that I mounted a trainer tire onto so I have the confidence now to take on a pair of tubulars. I'd heard street tires don't play well with 'in-contact' trainers, hence the urge to make the change.
I've been pondering building a new pair of wheels around more 'modern' hubs & new tubular rims so the info being put up here is of great interest to me.
Seems tubular rims are kinda few & far between?
And can get really pricey as well? I'm a recreational rider, unwilling to pay more for a rim than the entire bike's worth at this point. By this rule US $150 is about all I want to spend per rim.
Wheelman
Liked 732 Times
Good thread this'n.
and the clincher rims are on top of a cupboard.
If you look at vintage tubular rims they're actually fairly common (UK anyway) and quite a few are relatively cheap.
Example:
Pair of Mavic Monthlery Route
£15 in Cambridge
https://www.gumtree.com/p/bicycle-ac...ims/1462730954
(it's not local to me or I would have them)
.£15 in Cambridge
More usually a pair of Mavic Monthlery Pro is around £50 on Ebay.
And Ebay has approx 335 matches for "tubular rim" in the UK.
You could pick up some half decent Normandy hubs for £30 each.
If you're after some new rims I'm not really the person to ask, but Mavic Reflex were mentioned and they're current for around $40 each.
There are probably many more anodized rims since that seems to be the modern fashion.
Wheelman
Liked 732 Times
Hmmm, having an issue with Fiamme Red Label - it doesn't exist.
By that I mean it's not a catalogue description of Fiamme rims.
Velobase seems to have two entrys:
There's also this thread: https://www.bikeforums.net/classic-v...ease-join.html
It shows Fiamme red labels from 1950s to 1980s.
I think my working assumption is:
Can anybody confirm that ?
Fiamme Sprint: early 50s - late 60s https://www.velobase.com/ViewCompone...=107&AbsPos=16
"the labels on these rims changed from black and gold on red in the 1950s to black and yellow on red from the 1960s"
Fiamme Strada (red label) 1970s https://www.velobase.com/ViewCompone...=107&AbsPos=11
More robust than the yellow label tubular, these were a popular rim for road use.
.There's also this thread: https://www.bikeforums.net/classic-v...ease-join.html
'Red Label' includes Fiamme Sprint and the later Fiamme Strada.
Fiamme Strada may be an Ergal verion of the original Sprint (red label)
.Fiamme Strada may be an Ergal verion of the original Sprint (red label)
Wheelman
Liked 732 Times
Here's the history of Red Label: https://condorino.com/2017/12/30/s-a-fiamme-of-milano/
I'm now certain that the Velobase Fiamme Sprint entry is the actual Red label.
The Velobase Fiamme Strada (red label) is not directly related although the original red label probably didn't exist when that launched.
This is from a 1974 Cyclopedia (11th edition):
Likes For Aardwolf:
Wheelman
Liked 732 Times
It turns out there were road and track versions of Fiamme red label and yellow label.
Road versions have a brake track and are slightly heavier.
Then Fiamme adopted Ergal around 1976 and all the models changed.
Here's a great archive of rim related catalogues: https://www.velo-pages.com/main.php?g2_itemId=32690
Liked 154 Times
Seems Mavic Reflex sell for anywhere from US $52 (used) upwards to $80 - 150 new.
The Mavics I'm still using:
I bought a used pair of 700c Ukai clincher rims as built wheels, intending to build a pair of wheels to use on the roads here. Closer inspection revealed a small crack at a spoke hole in one rim so I changed my plans, used the other rim to build a trainer wheel.
Expensive lesson that, even before mis-calculating spoke lengths needed (my first attempt) for a 'no returns' order.
I'm not near any major metro area so the 'Net is my substitute for supplies & stuff. Be super having selections available to look at & maybe handle locally, so the Forum members here fill in the knowledge gaps nicely. LBS here in town's mostly MTB-oriented, be awesome were 40 years younger!
Standard Member
Bikes: 1948 P. Barnard & Son, 1962 Rudge Sports, 1963 Freddie Grubb Routier, 1980 Manufrance Hirondelle, 1983 F. Moser Sprint, 1989 Raleigh Technium Pre, 2001 Raleigh M80
Liked 980 Times
Not sure I can see the difference with "single eyed"
https://www.pedalpedlar.co.uk/produc...0c-tubular-rim
From ebay seller Art-bikes
"In every job that must be done, there is an element of fun. You find the fun, and - SNAP - the job's a game!"
Likes For Aardwolf:
Standard Member
Liked 980 Times
Yes, thanks for letting me know about the double-eyeleted ones.
Wheelman
Liked 732 Times
Issue resolved I think.
It looks like you could have eyelets or washers.
Nisi 1985 catalogue:
Sludi Mod 290
Sludi Mod 290
Countersunk, smooth, with fitted up washers or eyelets
Hard anodizing may be required for all our articles
https://www.velo-pages.com/main.php?g2_itemId=24644Hard anodizing may be required for all our articles
Wheelman
Liked 732 Times
And the next issue
From the 1985 Nisi catalogue (page 8) Track:
It looks to me like the eyelet version is 30g heavier than listed.
However this one is listed at 418g - catalogue value
https://www.pedalpedlar.co.uk/collec...0c-tubular-rim
Anybody have a Nisi rim with eyelets they can weigh ?
Wheelman
Liked 732 Times
Ok, definitely the final version.
Weights updated according to where I found the value.
I'm assuming Nisi rims with eyelets would be 30g heavier than the catalogue value.
Grey background is the ones I'm thinking I could use and are fairly common on Ebay.
