#7426
ambulatory senior
Quoted: 1957 Post(s)
Liked 3,673 Times
Adjustable reamers are available in many sizes. My dad had one for some reason. It will go from an inch all the way to 27.2mm. I've used it a bunch but it's a slow process by hand. Probably faster and I think more accurate than honing. Sometimes you notice how loose the seat tubes are once you get farther in.
Likes For 52telecaster:
#7427
ambulatory senior
Liked 3,673 Times
I got wrenched on yesterday.
Five screws and a plate. I have no idea how many stitches I got. I'm stuck in this soft cast for two weeks, then six to eight weeks in either a hard cast or back in the boot. With Mrs.Bikamper's attitude towards me these past couple of weeks, I may sell our tandem that she's only ridden once.
#7428
Quoted: 4548 Post(s)
Liked 6,504 Times
Took advantage of the good weather....before the rain started. Almost got this wrecked Lejune stripped, I forgot a headset cup apparently and got hung up on the fixed cup. The crankset was a cottered Sugino and the BB spindle was English, I think TDC? I think the cups are also TDC and need a 34mm wrench, which I don't have. I also haven't figured out which way it's threaded.
I also have a couple of cheater pipes I use in place of the extension wrench.
Whatever way it is supposed to turn, this method will do it.
If you go the wrong way the first time, it will crack loose anyway with the solid leverage this has, then you just reverse direction and spin it out.
If you are going the right way then you're almost done after it cracks loose.
Likes For merziac:
#7429
Had to order a few things to get this finished. Shorter stem, cable stop for the front brake and a Brooks.So far so good!
Semper fi
Semper fi
Likes For sloar:
#7430
1991 PBP Anciens
Bikes: 1954 Robin Hood, 1964 Dunelt, 1968 Raleigh Superbe, 1969 Robin Hood, 197? Gitane, 1973 Raleigh SuperCourse, 1981 Miyata 710, 1990 Miyata 600GT, 2007 Rivendell Bleriot
Quoted: 74 Post(s)
Liked 353 Times
Likes For bikamper:
Likes For BTinNYC:
#7432
Quoted: 755 Post(s)
Liked 741 Times
Likes For bark_eater:
#7433
Quoted: 755 Post(s)
Liked 741 Times
Here is a method that doesn't care which way it turns, the setup in the pics is backwards for the Raleigh but shows it pretty well.
#7434
Liked 6,504 Times
And since they would not have been used on any truly remarkable to me bikes, I didn't take note.
Likes For merziac:
#7435
Liked 6,504 Times
I've got the Stien tool dohicky but with out the correct 34mm wrench I was going to break something trying to stabilize an adjustable wrench with tapered jaws. The wrench ended up deforming before the cup, so there's that... I shifted over trying fix a vise to use out doors but need to buy a thread die to get that together.
I also have to be careful not to tighten it down too tight or it will bind too much.
The easy clamp seems to work very well in that regard, pretty darn tight but still with some give.
I have done plenty on the ground which can be necessary to get good leverage but the hardest ones have been zip tied into the stand in the pics that supports the BB.
I never use the fit all or hammer on bikes, especially when push comes to shove where they often come out, no good has ever come of it for me.
Likes For merziac:
#7437
Quoted: 341 Post(s)
Liked 632 Times
I posted about this build elsewhere but wanted to show it off here as well.
Got this frame and fork from the Bike Exchange that had some significalt corrosion under the paint on the aluminum frame.
Rather than throw it in the dumpster as suggested I took it home, cleaned the rusted areas, and treated it to this custom paint job.
It looks like a fancy easter egg and I love it. Hope you all do too.
As with all my creations , it will be sold(probably for much less than it's worth) by the Silicon Valley Bicycle Exchange (bikex.org) to help keep the lights on at our non proffit.
Likes For capnjonny:
#7438
Picked up a faggin built around the mid 1980's. Seller had 35 bikes but I saw the headtube badge so I went out for it. Both chainstay chrome was roached. Used the old 0000 steel wool to get some of it off, but the pitting was so bad I went back to bare steel. Hope I can find some ivory/pearl white paint that's close.
#7439
1991 PBP Anciens
Quoted: 74 Post(s)
Liked 353 Times
I can't get out to the Man Cave so I did a solder repair on Mrs.B's laptop on the dining room table.
I replaced the charging port on the lower left of the motherboard.The replacement is on the right of the board by its lonesome. I hate having to take out motherboards but this was a pretty straight forward repair. No stress.
The fact I took a three hour nap in the EZ chair with no chemical assistance afterwards had nothing to do with it. BTW, the nap was fabulous.
Likes For bikamper:
#7440
Quoted: 7392 Post(s)
Liked 2,553 Times
Haha, @52telecaster, yes, sometimes you get an honest workout wrenching on a bike. And we used to ream seat tubes regularly at one shop I worked at. In fact, it was required when we built up a high-end bike. Most would feel that policy is over the top, and I suppose it is, but the owners wanted us to be sure that everything was 100% right, so we did it proactively. We also faced the BB shell and chased the threads.
Likes For noglider:
#7441
ambulatory senior
Liked 3,673 Times
#7442
Edumacator
Quoted: 2523 Post(s)
Liked 3,318 Times
Organization complete mostly...
Looks like a bike shop. At least now my 5’11” self no longer bangs into wheels and forks/drops.
And Bella Basso has new clothes.
I have too much stuff...
Keeper frame gallery. Lots of projects. But each in its own safe hook-hovel.
1987 Crest Cannondale, 1987 Basso Gap, 1992 Rossin Performance EL, 1990ish Van Tuyl, 1985 Trek 670, 2003 Pinarello Surprise, 1990ish MBK Atlantique, 1987 Peugeot Competition, 1987 Nishiki Tri-A, 1981 Faggin, 1996 Cannondale M500, 1984 Mercian, 1982 AD SuperLeicht, 1985 Massi (model unknown), 1988 Daccordi Griffe , 1989 Fauxsin MTB, 1981 Ciocc Mockba, 1992 Bianchi Giro, 1977 Colnago Super, 1971 Raleigh International, 1998 Corratec Ap & Dun, 1991 Peugeot Slimestone
Likes For jdawginsc:
#7443
Bikes: Cuevas Custom, Cimmaron, 1988 "Pinalized Rockma", 1984 Trek 510, Moulton custom touring, Raleigh Competition GS, Bridgestone Mb-2 & 3, 1980's Peugeot - US, City, & Canyon Express (6)
Quoted: 1153 Post(s)
Liked 3,950 Times
Likes For SoCaled:
#7444
Liked 3,950 Times
Was just reading the recent thread on fitting a Pletscher rack on a Technium and it reminded me the rack on my Trek 510 had a bad lean.
Cut a couple of small lengths of some tubing I had laying around to protect the frame
Better, but looking at this pic, I think it is still needs a small tweak to bring the front up a tiny bit more. Just getting around to giving this one some attention.
#7445
Liked 6 Times
Thank you! I've just been using the original Dia-Compe canti brakes, and original Sugino RT triple.
After thoroughly cleaning everything I found most all of the original components to be in pretty good shape. I don't think it was ever ridden much.
It's become my favorite ride for sure though! Many upgrdes to come in the future too.
#7446
Liked 6 Times
#7447
Ellensburg, WA
Bikes: See my signature
Quoted: 313 Post(s)
Liked 466 Times
The future wrenching project picked up free today from a friend. Thinking city commuter to be used after we move in a couple months. 1991 GT Karakoram. Pretty much original except for tires. Overhaul needed.
1984 Gitane Tour de France; 1982 Nishiki Marina 12; 1984 Peugeot PSV; 1993 Trek 950 mtb; 1991 GT Karakoram, 1983 Vitus 979; Colnago Super, 1989 Spectrum Titanium,
Likes For scozim:
#7448
Liked 3,950 Times
Here is a pic of the bracket. The seat stays get sandwiched between the 2 pieces of somewhat malleable metal, on the right side of the pic. Tensions in place with the 2 screws. I put the pieces of clear pipe, in my post, on the stays to protect paint/tubing from the bracket. I will take a better pic, of the actual attachment, when I am out in the garage again.
Likes For SoCaled:
#7449
Bikes: Fuji Touring Series V 1985, Motobecane Grand Touring 1982, Specialized Stumpjumper 1993, Raleigh International 1972, Raleigh Grand Prix 1972, Kuwahara Count 1983, Trek Cirrus 1987, Shogun 2001 1983, Cannondale SM700 1990
Quoted: 90 Post(s)
Liked 174 Times
2 interesting items of note when taking about a 1975 Super Course I picked up a while ago: not all the same brake pad and missing 3 bearings from the headset. I've read in this forum that the Workshop assembly line could get sloppy so maybe it was put together that way.
Likes For ZudeJammer:
#7450
Bikes: Motobecane C41, Matsu$hita Nashonaru
Quoted: 215 Post(s)
Liked 439 Times
