Ask the Community
#951
Fresh Garbage
As previously said, any road lever will work just fine. The only issue I can see with some brake levers, such as the ones you want, is that the clamping bolt can extend past the nut and dig a little into the bar. I know I have seen marks left behind on my aluminum bars.
Meanwhile, higher end levers avoid this issue with a different nut/bolt arrangement.
#952
Clark W. Griswold
Liked 4,564 Times
As far as brake levers, go out and get yourself some SRAM S-500 levers and be happy, they are extremely comfortable and urklenomically designed and will work fine on a carbon bar and won't have the issues of the bolt digging into the bar as others mentioned. Yeah they do cost money but for a nice place to keep your hands a nice functional piece of equipment that allows you to slow down or stop, they are worth it. I have had them on 3 bikes and will continue using them till Shimano comes out with something similar or better in the ergo department.
#953
My answer was real but it had some comedic elements because you called it a "fixie" which I have to keep deleting and re-writing because it doesn't believe it is a word either and you also claimed that a fixed gear bicycle goes through more stress somehow. If a part is broken don't use it, simple as that. Also as stated earlier don't use carbon bars if you are unsure of them. No point in riding being nervous all the time that your bars will break just to save a smidgen of weight and get a possible small bit of added comfort. The seat posts and stems and such I listed are all perfect ways to add comfort.
Dave
#954
Clark W. Griswold
Liked 4,564 Times
Thanks. I wasnt aware of the bolt issue. Will have v to check my tektros to see what that is like. Going to put swapping the bars and stem on hold and decide if my current stem is the right length. I might swap seat posts too as previously mentioned. The Thomson layback seatpost has 16mm offset, and my current one has 25mm offset. If I get the Thomson, should I get a stem that is 10mm longer to make up for the difference in offset?
Dave
Dave
If you are looking to add comfort, again, go with the eeSilk seatpost.
#955
A fitter is a good idea. Had my old LBS look at my road bike after I built it, and they figured out what stem to use. That is my most comfortable bike. I looked up that eeSilk seatpost, apparently it only comes in 27.2mm (my seatpost is 26.8mm).
Dave
Dave
#956
dumb
Depending on the inner diameter which determines your wall thickness... you don’t want to go too thin... you can always have a machine shop turn it down to 26.8. I’ve done this to several seatposts for my Kilo TT. You can do this by hand as well with high grit sandpaper and a lot of time, or with a bench grinder and a softer wheel which can be had for cheap at harbor freight. I have a lathe and would be happy to turn down a seatpost for you no labor charge, just S&H if you were ever interested.
#957
Dave
#958
Clark W. Griswold
Liked 4,564 Times
I should have had you turn down my Thomson from 27.2 to 27.0 would have saved me all the hand sanding I did. It was a good workout. They really just shoulda made their 27.0 post silver and saved me the trouble but they didn't!
#959
Dave
#960
Clark W. Griswold
Liked 4,564 Times
#962
Clark W. Griswold
Liked 4,564 Times
I really like my Gore gloves all of them but I think I had some power gloves (I cannot remember as I bought them so long ago) I would give those a try if you can. I prefer foam to gel because they gel can deform over time and get lumpy which ain't good but foam seems to go and go.
#963
- Soli Deo Gloria -
Liked 738 Times
https://www.giro.com/us_en/strade-dure.html
Some vendors call them Strate, with a T instead of a D. I don't know why.
I have ulnar nerve damage in my right arm and the thick gel padding help quite a bit. Shop around for significantly cheaper prices.
-Tim-
#964
dumb
While we’re on the topic. Does anyone wear the Cinelli Giro DND gloves? I’m looking at these because I like Cinelli and Mike Giant is my favorite artist and bike enthusiast. But $45 is a lot if they are no bueno. Hell, my motorcycle gloves didn’t cost that much.
#965
Giro Strade Dure Supergel
-Tim-
-Tim-
Dave
#966
- Soli Deo Gloria -
Liked 738 Times
I couldn't say but my brother and I were constantly in the emergency room for broken bones, stitches, or some other crazy injury.
Bike ramps over garbage cans, rock fights, hitting trees on our sleds...
My brother pretty much has a glass wrist and I think some kind of nerve damage was inevitable for me. My guess is that cycling sometimes exacerbates the damage I've already done.
-Tim-
-Tim-
#967
THE STUFFED
Bikes: R. Sachs Road; EAI Bareknuckle; S-Works Enduro
Liked 20 Times
I had a pair years back when the Mike Giant collab was fresh off the block. Good gloves, they're a bit on the thin side though and not really insulated if you're looking for warmth.
#968
1) Archetypes or A23s?
2) almost opposite of #1, but since I'm already here...
Am I crazy to even be considering trying some ultra-light, and judging from the disclaimers pretty darn fragile, deeply discounted racing skinnies (that I accidentally found while I was shopping for bigger tires ) for JRA?
#969
- Soli Deo Gloria -
Liked 738 Times
Light, supple tires are a joy to ride. They spin up fast, climb like a squirrel and love to be ridden hard.
But they will spoil you and make it difficult to go back. Durability is an issue too, especially in the bigger northern cities where the roads aren't good.
I get only 1200 miles out of a Vittoria Rubino G+ Speed mounted on the rear. Longer on the front. It can get expensive but I found them for $27 each and bought a bunch.
It is an emotional commitment and you have to be willing to not get pissed off if they get destroyed. It's part of the cost of doing business when rolling on high end tires.
#970
Anyway this whole dilemma is kinda your fault
I've been contentedly riding my Veloflex Masters for years after being converted from an older Vittoria Corsa model - maybe it was Open CX or SC? It was one that when they updated it, they stopped making it with tan walls.
Since I've been riding on the Veloflexes(flexii?) so long that I was feeling the need to change, just 'cos - when I heard about the G+ Corsas when they came out I planned on getting some when I needed to restock on tires. Strangely my, once pretty vulnerable, Veloflex Masters suddenly stopped flatting right around that time. Fast forward a couple years, and now that I finally need some tires - Vittoria is making too damn many varieties of G+ tires now for me to decide.
I read, and reread, your recent analysis of them in the "Great Deal" thread. But when I went shopping I ran into models and descriptions you hadn't mentioned like Competition, Control, 4C, etc. and it just got to be too much.
So upon further consideration, taking into account that I am content with the way they perform and love the way they ride, that lately mine have become seemingly flat-proof, that they are lighter than comparable Vittorias, and with a little shopping are generally cheaper too - I decided to stick with Veloflex. I was shopping for some 28s when I bumped into the racy tires I mentioned. They are nominally 23s, but all the reviewers I found, who universally praise the supple ride and easy rolling as long as you accept their short lifespan and zero puncture resistance, also say they run small, and if I told you the claimed weight you would freak.
I want them - but...maybe not enough. And I still haven't bought any "normal" tires yet...
#972
Fresh Garbage
I don't know, but I bet a bad fit that puts too much weight on the hands can do damage. I remember in my early days my first road bike was too small and I would start to get pain and numbness in my hands, among other places, after a few hours of riding. No bueno
#973
Thinking about a new frame.
option 1: 2019 wabi special moss green. $600 minus fork and headset (already have a wound up fork that perfectly matches wabi's fork specs)
option 2: surly cross check mint green. Only $500 plus I like the color a bit better. This is also more versitile than the wabi (tire clearance, fenders, running it geared at some point etc.) BUT my wound up fork, which I'd like to use, is a full 20mm shorter than the stock cross check fork...
Thoughts?
Thoughts?
