Immersive waxing / it should be more popular
#1126
he said member
Bikes: yes please
Quoted: 2789 Post(s)
Liked 1,951 Times
as i said, i'm a waxer. i am not going back to oil. in addition to finding the process therapeutic it also gives me a chance to better clean the drive train.
here is another if you like, i just put this chain on yesterday and had one ride on it. its like chain dandruff...no waxy flakes my a$$...
#1127
If oil is added to wax, make it a high quality lubricating oil like auto gear lube, not lamp oil. 20-30% by weight will not separate from the wax.
#1129
Quoted: 1172 Post(s)
Liked 449 Times
It occurred to me that hollow pin chains would not be good candidates for waxing since the dried wax would go to waste filling up the hollow pins. But then I also thought that if a hollow pin chain had tiny cross drilled holes that this would be potentially a great way to work more wax into the internals of the chain. AFAIK, no hollow chain has this, but I can't see why a manufacturer could not easily make a chain like this that is wax ready.
#1130
Quoted: 455 Post(s)
Liked 1,081 Times
Just curious how intensive is everyone's chain degreasing? I've been shying away from using chemical degreasing mainly because I don't want to dump chemicals in my backyard or ruin the plumbing by pouring abrasive liquids down my drain. I found using boiling hot water and dish soap in an ultrasonic cleaner, does an adequate job for my needs. I repeat the process 2-3 times and I also use a cotton swab to remove any left residue. Once done, the chain appears to be spotless and greaseless. I'm not really seeing any downsides to this method and it's cheaper and more environmental as well.
It might seem like overkill, but I find the whole process very rewarding!
#1131
he said member
Bikes: yes please
Liked 1,951 Times
It's the same as the wax, paraffin. It mearly softens the wax. Makes it less brittle at room temperature so it doesn't flake off. It makes ot stickier do it adheres to the plates too. Gear lube will attract dust. dirt, and debris. Exactly what you don't want.
#1132
he said member
Bikes: yes please
Liked 1,951 Times
#1133
he said member
Bikes: yes please
Liked 1,951 Times
#1134
Liked 449 Times
But spare wax in a hollow pin does nothing really but waste wax. My point is that if that hollow pin was cross drilled, it would permit improved wax penetration where you really need the wax. This potentially could produce a waxed chain that does not need any refresh for much, much longer intervals.
#1135
he said member
Bikes: yes please
Liked 1,951 Times
Edit; as far as waste goes it might waste .5 of a tablespoon filling in the pins on a chain.
#1136
Quoted: 455 Post(s)
Liked 1,081 Times
Do you use an ultrasonic cleaner? The moment I turn it on with boiling water and soap, I immediately see the grease dissolve off the chain. I find using boiling hot water really makes a difference. I use one of those quick kettle boilers in the kitchen, so it's a fairly easy process.
Likes For jadmt:
#1139
Liked 449 Times
ok. It's your chain. But the wax gets into the roller, actually the space between the roller and pin and the plates. The solidified wax isn't going to flow out of the hollow pin and into the space around it.
The solidified wax in a hollow pin chain would make a premium lightweight hollow pin chain not a great choice for waxing unless.... the hollow pin allowed the wax to flow better into the internals.
Are you going to drill through the roller and the pin? Or disassemble every pin drill it and the reassemble the chain?
Of course I'm not personally going to do such silliness, but I think there is room for a manufacturer to make some slight modifications to their chain that might make it more wax specific and potentially help it to keep all the great properties of waxed chains for longer service intervals before the wax needs to be refreshed.
#1141
he said member
Bikes: yes please
Liked 1,951 Times
#1142
he said member
Bikes: yes please
Liked 1,951 Times
Wax works the same be it hollow pin or not. A piece of wax 1/16th of an inch by roughly 25 " long would weigh ...? .5 of a gram? You really worried about the weight of some lube in the pins of a chain? Okey dokely
#1143
Method to My Madness
Quoted: 2052 Post(s)
Liked 1,545 Times
You can just bring the used solvent to one of the hazardous waste disposal centers: LA County DPW - Permanent Centers
I bring mine to the Irvine one along with my used motor oil.
#1144
Quoted: 455 Post(s)
Liked 1,081 Times
In my experience, Dawn and boiling water are insufficient for Shimano factory grease. Plus, as cyccommute points out, residual water may cause rust and deter wax adhesion. So I used two rounds of odorless mineral spirits.
#1145
Quoted: 7691 Post(s)
Liked 3,592 Times
I degrease with SimpleGreen ... which for all I know ids more toxic than molten phenol or something (I know nothing about toxicity .... huffed too much acetone as a kid, can't remember how to do online research .... Hey, I hear acetone works!) Gasoline works too .... or mineral spirits. I just use SimpleGreen so I can be a sheeple and buy the marketing.
I do recommend Completely drying the chain because I read somewhere that the wax will Not displace the water, rather it encapsulates it ... but because I don't know science (huffed to much SimpleGreen as a young adult) I have no clue if that is true .... but I did read it on the internet.
#1147
Quoted: 1145 Post(s)
Liked 1,249 Times
I just use two swishes in mineral spirits (two small plastic jars) It results in very, very little "waste" mineral spirits - just the tiny bit of sludge at the bottom which is so easy to decant off.
#1148
he said member
Bikes: yes please
Liked 1,951 Times
It's just to get ride of any trace of oil or grease. It's part if the process I learned to get a chain ready for wax. There is/was a belief that wax will not stick to the metal if there's oil on it. There's a residue on the chain after the mineral spirits dries. I don't want to blow that all over my garage when I dry the chain with compressed air.
#1149
Bikes: SL8 Pro, TCR beater
Quoted: 1026 Post(s)
Liked 594 Times
1) Overnight soak in fuel
2) A few hours in rubbing alcohol
3) Then shake it in hot soapy water, rinse with hot water and let it dry
