Someone explain to me these handlebar bags that I keep seeing
#101
Liked 9,462 Times
#102
stole your bike
I'm sure the bag is useful; fanny packs worn with the bag facing the front are pretty useful too.
I like pie
I like pie
#104
On Your Left
Liked 2,435 Times
#107
cowboy, steel horse, etc
Bikes: everywhere
Liked 8,551 Times
Likes For LesterOfPuppets:
#108
stole your bike
And aren't "fanny" packs need to be on your fanny?
I like pie
I like pie
Likes For guadzilla:
#110
The dropped
Bikes: Pake C'Mute Touring/Commuter Build, 1989 Kona Cinder Cone, 1995 Trek 5200, 1973 Raleigh Super Course FG, 1969 Raleigh Superbe: 1960/61 Montgomery Ward Hawthorne "thrift" 3 speed, by Hercules (sold), 1966 Schwinn Deluxe Racer (sold)
Liked 1,019 Times
Likes For Unca_Sam:
#111
Low-rider type racks that put weight close to the hub of the front wheel can actually improve handling and stability.
Likes For Bostonwheeler:
#112
The dropped
Liked 1,019 Times
#113
I imagine something to repair a flat, first aid kit, and phone? Maybe pain pills. Or necessary items. I mean if your going out for many miles and your alone don't you take some necessary items along? At the least you need chapstick. Or a power bar?
#114
Again, as low as possible. And the only reason to use front panniers is if you've got the rear loaded up - the front lowriders will help balance front-to-back weight. There's no circumstance where adding weight to the front wheel by itself improves handling. And handlebar bags are the worst.
#115
Occam's Rotor
In addition to it possibly being more carbon-bar-friendly (I have my doubts, but this is what I was told), there is a valid concern that conventional handlebar bags won't stay mounted correctly when bouncing around on very rough off-pavement trails. The stuff sack mounting mechanism is a bit more robust in that sense.
#116
Occam's Rotor
#117
Guilty as charged!
I have a Specialized Roubaix endurance bike and I bought a small Arkel handlebar bag to hold my rain gear and a few nut bars. It beats stuffing your jersey pockets, at the expense of looking less aerodynamic.
#118
I eat carbide.
Bikes: Lots. Van Dessel and Squid Dealer
Liked 1,324 Times
I'm sure there's lots of great information about all sorts of bags over in the Touring Forum - might be worth checking out if you like the loaded up look.
PSIMET Wheels, PSIMET Racing, PSIMET Neutral Race Support, and 11 Jackson Coffee
Podcast - YouTube Channel
Video about PSIMET Wheels
#119
That bike would handle much better if that weight were evenly distributed, and without the handlebar bag. Nobody who has done any significant amount of bicycle touring, me included, would suggest setting up your load that way. I'm not sure it's even safe. Can you imagine needing to do a full-on panic stop, especially on a downhill? Weight distribution is everything when it comes to loading a bike.
#120
Liked 9,462 Times
#121
Bikes: everywhere
Liked 8,551 Times
I personally don't think 50/50 is ideal for a bicycle, but...
#122
Bikes: everywhere
Liked 8,551 Times
Well I'll be damned, it's actually not that bad on my Lemond using the cheap and dirty bathroom scale method has it at 45 front/55 rear. Probably not that accurate, however.
#123
The dropped
Liked 1,019 Times
Silca's ideal tire pressure guesser uses 48/52 that distribution for road frames, with the 50/50 being used on Tri/TT frames, and 46.5/53.5 for mountain frames. Did you use two scales?
#124
Bikes: everywhere
Liked 8,551 Times
If I wasn't so cheap and dirty, I'd run out and get a couple of matching scales, attempt to calibrate with a bag of concrete and then collect the data again.
#125
Live Healthy
