Thomas DeGent no fan of hookless…
#151
Fat n slow
Quoted: 3261 Post(s)
Liked 2,087 Times
IME, deflations on lower pressure tubeless tyres with sealant are slow and benign. Also very rare. I’ve had 1 in the last 4 years, from a large cut that was too big to self-seal. What happened to TdeG was due to the tyre suddenly coming off the rim, which fortunately I have never experienced on any tyre. I’ve run tubs, clinchers and tubeless setups over the years and tubeless have been the most reliable ie virtually no flats and the easiest by far to repair roadside with a plug kit. I haven’t used “pool noodles” and I don’t think many riders on tubeless use them either. Also never used hookless rims.
#152
Quoted: 4571 Post(s)
Liked 5,110 Times
Also occasionally had the tell-tale sealant spray on my seat tube from minor punctures at the end of a ride.
#153
Bikes: Time Scylon, Lynskey R350, Ritchey Breakaway, Ritchey Double Switchback, Lynskey Ridgeline, ICAN Fatbike
Quoted: 479 Post(s)
Liked 564 Times
We must have more crap on the roads here in the lesser white north. Last year I had two major cuts and I hit a sugar beet that burped the tire. Sugar beets are the same color as the pavement and they are hard to see at times.
All went flat quickly, leaving me riding at 20 MPH or more on a completely flat tire. None of the cuts left me with a rideable tire. No tube and boot. They went in the bin. None of them came off the rim. The burped tire was reinflated and I finished my ride.
And I have had several punctures that sealed up without going completely flat. Some have been rideable, some needed to be pumped up.
Yes, Dave is a bit of a crank. He doesn't understand physics or math, and he loves his tubular tires. Maybe if I rode on tubulars I would be carrying a spare tire... nope, not going to do it. I bet they can come off the rim in some situations.
#154
Liked 5,110 Times
I've had several. Three of the original GP5000 TL tires had catastrophic sidewall failures. All of them had a couple thousand miles on the clock. One was a front, the other two were on the rear. None of them came off the rim.
Likes For PeteHski:
#155
Quoted: 1466 Post(s)
Liked 1,492 Times
Zipp and Vittoria both make tubular options that are available to De Gent’s team and would still be “sponsor correct”. Teams aren’t running tubeless as a marketing ploy. They’re running tubeless because they think it gives them the best chance of winning bike races.
It’s weird to me that the same people claiming tubeless tires are dangerous also think pros railing hairpin corners down rainy alpine descents are totally fine running cork rim brake pads on carbon wheels.
#156
Here:
Tubeless/hookless for performance road cycling is for marketing, manufacturer cost savings and creating proprietary tire/wheel combos that attempt to lock the consumer to the original sale vendor. Just because the marketing propaganda says they are on a certain trendy tire/wheel combo doesn't mean that they are actually being used in competition. Particularly during the critical climbing stages.
And it helps keep a few of the shrill industry influencers on this forum in beer money.
I have 50 bikes to get ready for a spring opening, including hydraulics and di2. The misery of feeding hydraulic lines and mechanical cables/housing though an integrated frameset explains part of the Youtube video question as to why modern high-end so bikes so expensive. It takes a lot of time to set up this stuff. Adding pool noodles and slime and inflating tubeless just adds even more time and costs.
It also helps lock the consumer into a shop because your average weekend warrior used to be able to replace rim brake pads and shift housing and fix a flat. No longer. We have an increasing influx of folks coming into see us to: "borrow an air compressor".
#157
Liked 5,110 Times
Meanwhile the pro teams are only interested in whatever is actually fastest. Of course they have individual sponsorship obligations but the top teams are usually sponsored by top tier brand gear anyway. Being forced to ride the latest S-Works or Cervelo on Conti or Vitoria tyres is very unlikely to be a major compromise in performance! As you point out, they are free to use tubulars if they prefer them, but they rarely do now. We see them occasionally on high mountain stages, but less and less each year.
#158
Quoted: 4010 Post(s)
Liked 7,517 Times
Likes For tomato coupe:
#159
Klaatu..Verata..Necktie?
Quoted: 10551 Post(s)
Liked 12,131 Times
Here:
Peak Torque on Bike Marketing, Real World Aero Savings and Hookless Dangers (youtube.com)
#160
Liked 5,110 Times
Yeah if they were all secretly racing tubulars then there would be no backlash against hookless rims. We know that a few riders still use tubulars occasionally on big mountain stages, but it’s getting pretty rare now. Tubeless is now by far the primary choice.
#161
Quoted: 479 Post(s)
Liked 564 Times
The original GP5000 TL did have a reputation for fragile sidewalls. Something they improved with the current spec S TR. But if you are looking for something much less fragile and only a little slower, then I can recommend Pirelli Cinturato Velos. Those are pretty bombproof and ride well.
I keep coming back to GP5000 tires because... because I like them. Haven't tried the Pirellis yet. I hope I have tires lined up for 2024, 28mm GP5000 S TR are on the shelf ready to go on the Scylon and 32mm GP5000 TL are on the tandem. Only the 25mm had failing sidewalls under me.
We wore the first set of 32mm GP5000 TL on the tandem down to the cords with no problems. Put a second set on and have a third on the shelf in the cold dark garage.
One aside, when I put the GP5000 tires on the tandem, the first ride Mrs. Dan wanted to know what I had done to make the bike so much more stable in corners and comfortable to ride. Easy answer; I put the Marathon on the shelf and put on GP5000.
#162
Fat n slow
Liked 2,087 Times
Here:
With a hookless compatible tire I can seat just about anything with a crappy Blackburn track pump I bought in 2012.
Also, as a relatively mechanically inept idiot I was able to build up a fully internal bike, bleed the brakes, etc watching a few YouTube videos. It actually took longer to get the FD set up than to run brake hoses through the frame, stem and bars. It can’t be that bad for a trained mechanic.
Likes For phrantic09:
#163
Liked 5,110 Times
One of the cut tires was a Vittoria Corsa, as was the burped tire. The other cut tire was a Goodyear Eagle. The Corsa just isn't as nice as the GP5000. The Eagle seemed like a good tire.My riding covers a lot of roads that are crossed by gravel roads and I suspect that one of the cuts came from a sharp piece of gravel. The other was definitely a broken dark brown beer bottle.
#164
climber has-been
Quoted: 3551 Post(s)
Liked 3,714 Times
BTW, the UCI is now looking into hookless rims with tubeless tires, "with a view to reaching a decision".
If the UCI bans their use, watch hookless road rims disappear quickly from the market.
Good riddance.
Good riddance.
#165
Liked 7,517 Times
#166
climber has-been
Liked 3,714 Times
#167
Liked 7,517 Times
#168
Good riddance.
Good riddance.
#169
Liked 2,576 Times
So if the UCI bans them, does that mean that hookless is "getting the hook?"
Likes For seypat:
#170
Quoted: 9664 Post(s)
Liked 6,377 Times
Wait you run / work in a shop? I bet your customers love you… you think so highly of them.
There is nothing on a disc/internal routing bike that requires a degree in rocket science. It just takes some patience and a little time to learn some tricks. Bikes, no matter how expensive and trendy are not F1 cars or moon shots.
#171
I subject this to my 50mph razor.
If I was going downhill at 50mph, would I wish my rims were hooked or hookless? And I am going to go with hooked, but looking forward with safety data from early adapters.
#172
Fat n slow
Liked 2,087 Times
Have you ridden that bike yet? I'll bet it falls into pieces the moment you leave your garage.
#173
Fat n slow
Liked 2,087 Times
50+ downhill on a dirt road with hookless wheels and 28s pumped to 60 PSI. Never once were wheels the concern.
#174
Liked 6,377 Times
#175
Liked 2,576 Times
