Bikes: Trek CheckPoint SL7 AXS, Trek Emonda ALR AXS, Trek FX 5 Sport
Liked 2,049 Times
Picked up another pair of Magped and some new MTB shoes to go with the pedals as I work with my wife to get more comfortable with clipless. Also picked up some Shimano GE5 shoes.
Liked 5,580 Times
Liked 2,049 Times
Yea, they are fantastic. I had some Time ATAC's that were not on a bike, that I put on my Stages Bike and when my wife wanted to start riding more, I got her some gravel type shoes and put some cleats on them. She had such a hard time clipping in and out, might take her 5 to 10 mins to get both feet in. With these, there is a metal plate that attaches to the shoe that the magnet clips on to. Has a ton of float and versus rotating your heal to unclip, you roll your foot to the outside and the lower magnetic attraction will allow you to pull your foot. Its a very sweet system. The magnets I have on the gravel version of the pedals I currently on the stages bike, the 200nm type, super strong, and maintain a very strong pull. I tried to pull my foot out and just could not do it. She was able to use these without issue within 30 seconds once she figured out how to place her foot to have the magnet attach to contact plate. She told me best purchase ever. If I did not like my ATAC's so much, I would not hesitate to put the Gravel versions on my bikes. I decided to go with the flat pedal version this time as she already has flat pedals on her bikes and is comfortable with them, so I bought these to get her used to them, then I can pick up another pair later to put on her bike. The down side is I needed to pick up a couple pairs of shoes with the flat bottoms. She has some flats she uses now, but, they do not have the ability to put cleats on them and I do not have any flat shoes.
They have a few different version, they have double side flats as well, but I did not think we needed that inside, but when I put some on her bike, I will get the double sided versions.
Brian | 2023 Trek CheckPoint SL 7 AXS | 2016 Trek Emonda ALR | 2022 Trek FX Sport 5
Liked 5,580 Times
Liked 2,049 Times
Mojo31 Did you ever pick some of these up for your wife?
Here was my original review when I got the Gravel versions.
Likes For Mojo31:
Liked 5,580 Times
Correct question for Mojo31
Did you buy that madone SLR yet???!!!!!!!
I had to go tubeless because I can't afford tubes.
Liked 5,580 Times
Liked 2,049 Times
I have two boys, two years apart, it was touch and go there for a while whether there was enough food on the planet for them. We finally started just buying food we knew they would not eat and that seemed to do the trick. It was a great day for our wallets when they moved out.
I have two boys, two years apart, it was touch and go there for a while whether there was enough food on the planet for them. We finally start just buying food we new they would not eat and that seemed to do the trick. It was a great day for are wallets when they moved out.
Perspective is everything.
Likes For Mojo31:
Liked 2,049 Times
Decided I did not really like the Zipp Service Course XPLR bars for my Checkpoint, so picked up the Ritchey WCS Carbon Streem II bars. I have them on my Domane and Emonda and they are very nice.
Likes For jaxgtr:
Liked 5,580 Times
Picture please. I’ve been debating back and forth on those bars. I’m terrible at looking at bars naked and making a desicion weather or not I like them. The Ritchey stream II just look ugly naked but it doesn’t mean they are.
My FSA A wing pro bars mounted on my bike look nothing like the naked picture. I feel like I am using the work “naked” out of context.
climber has-been
Liked 4,058 Times
3D-printed tennis ball rocker feet for my Zwift Hub trainer:
Clever design, and not that expensive. It makes the fake riding a bit more comfortable.
Purchased from Etsy: Zwift Hub One or Classic Rocker Feet
Liked 3,302 Times
I looked into the WCS SII, however, the Enve Carbon Road has my attention too. 0 degree flare is preferred.
-YMMV
-YMMV
Liked 2,049 Times
Likes For jaxgtr:
Liked 5,580 Times
I am running SRAM AXS on my Domane, Emonda, and Checkpoint, so no gear cables, but the brake lines routing for the Gen 4 Domane and the Checkpoint in the future is\will not terrible with them. On my Emonda, which is rim brake, the brake cables are a piece of cake. They bars come with a small cable sleeve which you can use to run through the bars easily as running cable housing (jagwire) was a bit tight, but it will fit, but I thought it was just a bit awkward. They fit my hands nicely and are super comfy, even if I need to get small to stay out of the wind more and ride on the tops with my forearms. I highly recommend them. And the bar tape on my Domane is Cannondale Knurltack, really like it.
Likes For bampilot06:
Liked 5,580 Times
Liked 2,049 Times
Yea I looked at those, but the reach is a bit too long for my liking.
Liked 3,302 Times
Liked 2,049 Times
I am not a huge flare person either, but the 1% of the Ritchey bars are just enough to keep my arms off the underside of the tops. Too much flare make me very uncomfortable in the drops on my shoulders. So running a 40mm means the drops are right around 40.5 on the drops. The Zipp bars however, are 40 up top and 42 in the drops. 42 is too wide for me for comfort which is why I decided to get rid of them.
Likes For jaxgtr:
Grupetto Bob
Bikes: Bikey McBike Face
Liked 6,608 Times
Road 🚴🏾♂️ & Mountain 🚵🏾♂️
climber has-been
Liked 4,058 Times
It works fine, nothing to complain about. Simple to set up, and it just works.
Likes For terrymorse:
Fat n slow
Liked 2,105 Times
A lot:
Force AXS D1 Groupset 48/35 crank, 10/33 cassette.
Cervelo Soloist frameset, Embers, Size 56
Repente Quasar 2 Saddle
Deda Superbox DCR stem
Deda headset cover for Soloist/R5/Aspero
Prime Primavera carbon aero handlebar
Sram bleed kit
Ride wrap tailored kit
Sram bleed kit
Likes For phrantic09:
I realized that with winter rain I needed a way to work on my core muscle strength and the best way to do this was to get a power rack for weight training. It takes up a 6x6 foot space in my garage which is all I had available.
On the hills it is my back and core muscle strength that is being utilized and weight training should minimize the time needed to get into shape when the weather improves. It also is important as my torso is what takes the hit in installing my 50 lb bike rack in the hitch or lifting our two bikes into the bed of my pickup truck.
Most places around my home are no longer safe for cycling with so many motorists in essence DUI as they focus more on their phones than on the road ahead.
Likes For Calsun:
