Show us your vintage mountain bikes!
Old 11-02-23, 09:22 AM
  #8776
daywood
Quoted: 62 Post(s)
Liked 255 Times in 96 Posts
Originally Posted by mtnbud
I just saw this bike on CL and was wondering if it'd be a good frame for a touring bike conversion.
I don’t know anything about the quality of the frame but the geometry looks reasonably relaxed. The thing I’d wonder about is how well it’s set up to accommodate racks. I don’t see any bosses or eyelets up front (which could be addressed with a fork replacement or a rivnut tool) and I wonder if that rear fork design without bosses would affect mounting a rear rack. I have one like that but it has mounting bosses. Again, maybe rivnuts to the rescue?
daywood is offline
Likes For daywood:
Old 11-02-23, 09:27 AM
  #8777
daywood
Quoted: 62 Post(s)
Maybe never mind on that last bit about the rear rack. I see now that there may be a through bolt for the brake cable stop that could be used for mounting a rear rack.
daywood is offline
Likes For daywood:
Old 11-02-23, 09:33 AM
  #8778
mtnbud
mtnbud's Avatar
Bikes: 2019 Trek Stash 7, 1994 Specialized Epic 1986 Diamondback Ascent 1996 Klein Pulse Comp, 2006 Specialized Sequoia Elite
Quoted: 418 Post(s)
Liked 523 Times in 291 Posts
I currently have a 1986 Diamonback Ascent that's set up for touring. The chainstays are nice and long and it has the appropriate mounting points. It's a beast and bombproof, but very heavy. I've been looking for a lighter frame that would work as well or better. I expect this would be lighter, but am not sure about the glued carbon tubes. The price is attractive on this one. Truthfully, the frame is likely slightly smaller than I need. I could likely make due with the frame size if there is enough weight difference and the frame is sturdy enough.
mtnbud is offline
Likes For mtnbud:
Old 11-02-23, 11:43 AM
  #8779
madpogue
Quoted: 2364 Post(s)
Liked 1,751 Times in 1,193 Posts
I also see what appears to be a rack mount screw on the seat stay, below the monostay split, about where the canti mount is. That's a very low position, so it would require a rack with mounting rods that can be attached at a pretty steep angle.
madpogue is offline
Likes For madpogue:
Old 11-02-23, 12:26 PM
  #8780
gthomson
gthomson's Avatar
Bikes: 2013 Cannondale Caad 8, 2010 Opus Fidelio, 1985 Peugeot UO14, 1999 Peugeot Dune, Sakai Select, L'Avantage, 1971 Gitane Apache Standard, 1999 Specialized Hard Rock
Quoted: 548 Post(s)
Liked 473 Times in 302 Posts
I posted this bike earlier when I first got it and it looked decent as is but made a few upgrades to suit my needs, which I will call phase 1. New tires, needed new brakes, added an 8-speed cassette as it was set up as a single speed, new used shifter, new grips and new chain. Things to add are new pedals (an aluminum flat set I have on another bike) maybe a rack? and consider a new handlebar set up. I want to ride it for a bit and see how I like it before deciding on any other changes. Can't say it wasn't a challenge to source decent used parts and originally, I hoped for more gears but would then have to switch out the rear hub and expand the back frame which I didn't feel comfortable doing. My lack of bike building skills forced me to keep things pretty simple.
Still needs a lot of work as the tires are not seeding well in the rims, the shifter is not changing gears correctly and the brakes need adjusting. Overall I'm happy with how it looks and can't wait to take it out on some rides.
gthomson is offline
Likes For gthomson:
Old 11-02-23, 12:40 PM
  #8781
'02 nrs
'02 nrs's Avatar
Quoted: 804 Post(s)
Liked 2,986 Times in 1,499 Posts
1990 8900 Trek
as found-work in progress;
'02 nrs is offline
Old 11-02-23, 02:35 PM
  #8782
Weaselshark
Quoted: 9 Post(s)
Liked 17 Times in 10 Posts
[QUOTE='02 nrs;23059829]as found-work in progress;
nice canti brakes!
love the look of those Ringle skewers as well, though not necessarily their functionality…
Weaselshark is offline
Likes For Weaselshark:
Old 11-04-23, 06:03 PM
  #8783
gthomson
gthomson's Avatar
Quoted: 548 Post(s)
On the topic of tires, has anyone had any experience with installing those Billy Bonker tires that I have on my bike above? I am having big problems with getting these tires seated on these original rims and not fitting correctly on a specific part of the tire and creating a hop on rotation. I've taken the tire off, massaged, changed the tube, used water and soap and nothing works. I finally took it to my LBS and the head service mgr. worked with it for about 20 minutes and he was able to stabilize but admitted it was not perfect.
Our older rims not compatible with these tires?
gthomson is offline
Old 11-04-23, 07:22 PM
  #8784
2cam16
2cam16's Avatar
Bikes: TRIMMED DOWN THE HERD
Quoted: 1092 Post(s)
Liked 936 Times in 601 Posts
I have the same problem with the Maxxis High Rollers I have on one of my mtb's. Tried everything but the same spot still giving me the problems. I'm just living with it.
2cam16 is offline
Old 11-04-23, 07:58 PM
  #8785
curbtender
curbtender's Avatar
Quoted: 1612 Post(s)
Liked 2,594 Times in 1,225 Posts
curbtender is offline
Old 11-04-23, 09:17 PM
  #8786
JoeBass
JoeBass's Avatar
Quoted: 88 Post(s)
Liked 296 Times in 93 Posts
Just had this ‘87 Stumpjumper out on the El Dorado Trail today-
JoeBass is offline
Old 11-05-23, 10:22 AM
  #8787
mixteup
mixteup's Avatar
Bikes: A Few
Quoted: 156 Post(s)
Liked 63 Times in 27 Posts
Not anything really special, but I think it's going to be a nice bike, and in the right size for me for a change - For sure, no extreme trails here, so I think it'll do fine.
I saw this for $110, with a bad photo - When I went to look at it, it had a Wallmart type nutted front wheel on it, and I thought I was going to either walk, or try and talk him down radically, which probably would have amounted to the same thing.
But when I mentioned the wheel, he said "Oh, you want the original front wheel?" - He went in the house, and I expected him to bring out a real potato chip, but he came out with a front wheel that was absolutely pristine! Go figure - Why would he think the original wheel wasn't of any value?
The bike was actually in pretty good shape, but it had been "maintained" with white lithium spray grease, and I mean everywhere, and it was a real mess.
I believe the bike is a 1996.
So here it is, after I cleaned it up.
I actually had most all the parts on it now, stashed away, including new Panaracer tires, Microshift thumbies, and a nice Jim Blackburn rack.
I did decide to put in a new BB cartridge, and buy a new shorter stem. Oh, and new tubes, since it has Presta rims.
And I'm going to have to get a new cassette, as after a brief trial ride, I think the original one has a problem.
The paint (powder coat?) deserves a mention - I believe the color was called "Ice Violet", with a matte finish.
It was really chalky and streaky-looking, and even after cleaning, it looked pretty bad to my eye.
They make special cleaners, etc for this kind of finish, to preserve the matte look, but I was wary of spending money, and not knowing if they work.
So, I just bit the bullet, and wiped it with Penetrol (a paint additive), which I've used on chalky fiberglass gel coat, before - The result looks excellent, to me anyway.
After it dried, it really made the color pop, got rid of the chalkiness and streaks, and although I guess it has a little more sheen, I like it much better!
mixteup is offline
Old 11-05-23, 03:23 PM
  #8788
katsup
katsup's Avatar
Bikes: 1995 ParkPre Pro 825 2021 Soma Fog Cutter v2 and 2021 Cotic SolarisMax
Quoted: 607 Post(s)
Liked 560 Times in 318 Posts
No issues whatsoever with Billy Bonkers on my Mavic M261 rims. Haven't had them on any of my other 26in rims.
katsup is offline
Old 11-05-23, 03:47 PM
  #8789
Oldsledz
Quoted: 66 Post(s)
Liked 185 Times in 80 Posts
3 I picked up this summer. The Mongoose is the only one I will be keeping. I put street tires on it for riding with my wife they will ball short easy rides.
Oldsledz is offline
Likes For Oldsledz:
Old 11-05-23, 04:01 PM
  #8790
mixteup
mixteup's Avatar
Bikes: A Few
Quoted: 156 Post(s)
I have a Haro Vector - Yours looks to be in much nicer shape than mine :~)
mixteup is offline
Old 11-05-23, 07:21 PM
  #8791
Miradaman
Bikes: 1987 Schwinn Mirada, 1989 Trek 420, 1995 GT Timberline, 1979 Schwinn Super Le Tour, Co-Op DRT 1.3
Quoted: 103 Post(s)
Liked 85 Times in 49 Posts
Originally Posted by curbtender
Love your Timberline. here's mine.
Miradaman is offline
Old 11-12-23, 10:35 PM
  #8792
ElGenerale
Quoted: 14 Post(s)
Liked 19 Times in 7 Posts
Originally Posted by Hproduguidon
the first mountain bike sold in France
Peugeot crazy horse vtt1 1982/83
Well, I've seen a few Peugeots that I kinda liked, but this one changes the game. Wonder if I'll ever see one for sale.
ElGenerale is offline
Likes For ElGenerale:
Old 11-13-23, 08:09 AM
  #8793
swissycle
swissycle's Avatar
Bikes: ~1982 Mondia Halbrenner, 1989 Giant Sierra ATB, 2021 Schindelhauer Siegfried Road
Quoted: 9 Post(s)
Liked 27 Times in 13 Posts
Until this was posted, I had been wracking my brain to remember exactly what I was riding in the mid to late 90s (green w/ bullhorns, purchased new in '95, was as far as I had gotten). Thanks for jogging my memory, and enjoy the ride!
swissycle is offline
Old 11-13-23, 09:51 AM
  #8794
curbtender
curbtender's Avatar
My neighbor has gifted me some nice bikes, 84' Stumpy/Trek 950, so this one just went to his grandson.
Likes For curbtender:
Old 11-16-23, 09:27 AM
  #8795
curbtender
curbtender's Avatar
Charlie still struggles.
https://www.gofundme.com/f/charlie-c...ource=facebook
Old 11-16-23, 10:51 AM
  #8796
clarkbre
clarkbre's Avatar
Bikes: 1993 Trek Antelope 830, 1996 Trek Singletrack 930, 1995 Giant Innova, 2012 Surly Pacer
Quoted: 13 Post(s)
Liked 105 Times in 22 Posts
A new project has fallen into my lap!
Talking with my coworker about a recent Trek Antelope 830 build, he offered me his old MTB but couldn't remember what it was. He brought to work and its a fairly stock, '97 Gary Fisher Hoo Koo E Koo. From looking at the catalogs, online pics, etc., it appears to be a large frame. The stem and handlebars have been swapped and the stock bar-ends are gone. The original 3x8 drivetrain is complete and the hubs and rims run smooth and true. The headset is wobbly and appears to be missing the top cap (I've got a new one ordered). My plan is to dismantle, clean, lube and reassemble.
clarkbre is offline
Likes For clarkbre:
Old 11-16-23, 11:05 AM
  #8797
bOsscO
bOsscO
bOsscO's Avatar
Bikes: 2024 Spec Crux, 2015 Norco Search S1, 93 Mongoose IBOC COMP
Quoted: 296 Post(s)
Liked 355 Times in 212 Posts
Looks rad; I think we need more photos of this bike.
Is that the original green paint colour?
Are your stem/bars gold anodized?
So many questions...
bOsscO is offline
Old 11-16-23, 11:26 AM
  #8798
curbtender
curbtender's Avatar
See a gap on that adjuster. Maybe just needs a spacer.
Old 11-16-23, 11:33 AM
  #8799
clarkbre
clarkbre's Avatar
Quoted: 13 Post(s)
That gap doesn't close up. I tried snugging it down with the star nut but there is a missing piece. Specifically, the top piece that fits on top of the bearing. For less than $12 I can replace it with a new unit.
clarkbre is offline
Old 11-16-23, 01:07 PM
  #8800
Vintage_Cyclist
Vintage_Cyclist's Avatar
Bikes: yes
Quoted: 512 Post(s)
Liked 409 Times in 176 Posts
Looks like the same size as mine.
Size specs from the 1997 technical manual
Vintage_Cyclist is offline
Likes For Vintage_Cyclist:
