View Poll Results: Are you a weight weenie
Voters: 68. You may not vote on this poll
Are you a true Weight Weenie?
Likes For spelger:
#77
Quoted: 4416 Post(s)
Liked 4,872 Times
I wasn't talking down to anyone. It was a comment on how much lighter modern bikes have become. Yes my MTB is a blast to ride, but it's a total pig on the road compared to my road bike - which is not particularly lightweight either.
#78
Liked 4,872 Times
#79
Tragically Ignorant
Quoted: 8186 Post(s)
Liked 9,098 Times
Likes For livedarklions:
#80
Liked 4,872 Times
That's an interesting angle. I would suggest it's because cheap low-end steel tubing weighs the same as it did 40 years ago.
#81
Dirty Heathen
Quoted: 889 Post(s)
Liked 906 Times
Cheap bikes are heavy. Good bikes are light. A cheap aluminum bike will be lighter than a cheap steel bike, but heavier than a good steel bike, or a good aluminum bike.
High quality, lightweight steel tubing is expensive. You can build a good quality aluminum bike that is as light as the expensive steel bike, but costs less. See how that works?
#82
Liked 4,872 Times
Any bike that weighs no more than 10% of your bodyweight has so little effect on your climbing that unless you're a professional rider that is riding at 40+ kph (25 mph English) it makes no difference at all. I'm 77 and 6'4" and can't tell the difference on hard, long climbs between a 16 lb bike and a 22 lb bike.
#83
Dirty Heathen
Quoted: 889 Post(s)
Liked 906 Times
Aluminum bikes are so common now, that it's easy to forget what a real game-changer the early KLEIN and Cannondales were. They figured out the big-diameter / thin-wall tubes and TIG / heat-treat process to get bikes that were as light as the high-dollar Italian stuff, but at prices more in line with TREK and Specialized.
There's cheap steel, expensive steel, and middle-of-the-road steel. There's cheap aluminum, high-end aluminum, and middle-of-the-road aluminum.
The kinds of high-grade thin-wall steel tubes to make a very light bike are going to be very expensive. Aluminum is roughly 2/3 the weight of steel, strength for strength, so a less-expensive thicker-wall aluminum tube will be the same weight. Or, you can go like KLEIN/Cannondale and make big-diameter, super thin tubes, that are even lighter than the steel tubeset.
That's why you pretty much only find steel bikes at the bottom of the bike market, and in the boutique / specialist builders. For cost and weight, AL pretty much has the middle 2/3 of the market to itself.
#84
Quoted: 4227 Post(s)
Liked 2,488 Times
#88
Liked 2,488 Times
#89
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2585 Post(s)
Liked 5,648 Times
If you are really concerned about weight, give yourself an enema before you head out, if you are able to head out after that.
Road 🚴🏾♂️ & Mountain 🚵🏾♂️
#90
Quoted: 1279 Post(s)
Liked 1,393 Times
since taking up road cycling earlier this year, I lightened myself by 15 lbs, i lightened my bike by 4 lbs, and my gear (helmet shoes clothes etc) by maybe 4 lbs. 23 lbs represents around 10% of the total load, but combined with getting a bit stronger and better gearing it feels more like 33% easier to ride up a hill. and 50% more fun.
so while I agree that only a pro could “feel” a pound or two here or there, it all adds up and compounds with other factors.
Likes For mschwett:
#91
Dirty Heathen
Quoted: 889 Post(s)
Liked 906 Times
The bottom end models I'm finding locally are also aluminum, including $120 adult size MTBs.
The only exceptions in the bottom end (using cheap Hi-Ten Steel frames) are fatbikes, cruiser styled bikes, and ladies bikes.
They're all heavy. Weighing around around 30 lbs, except the fatbike which can weigh over 40 lbs
You're arguing from the specific to the general: " There are cheap, heavy aluminum bikes; therefore, all aluminum bikes are cheap and heavy"
See if this makes sense:
Cheap aluminum bikes are heavy, but not as heavy as cheap steel
Better bikes are typically lighter than cheap bikes.
Very light aluminum bikes are (more) expensive, but not as expensive as very light steel bikes.
Bottom-end bikes will still be bottom-end. Just because Cannondale got the light-weight-big-tube design figured out 40 years ago, doesn't mean that tech is going to trickle down to a $200 bike in the Philippines
Likes For Ironfish653:
#92
Liked 4,872 Times
Likes For PeteHski:
#93
My intent of providing my bike weights was to show that a low-mid-grade bike (My '75 Fuji S-10S) weighed only 4-5 pounds heavier than a high-end bike of the day - a (Schwinn Paramount on tubulars!
Forward ten years - and the triple-butted CrMo '86 Miyata 710 was still ~23.5 pounds. Still relatively light for it's day. CF and AL were not popular yet. Yes, by then some bikes were getting down to under 20 pounds, but not many... and certainly not popular with casual riders.
OK, now I'll address that 10% bike-to-rider-weight malarkey. Back in '76 when I started getting serious about cycling, my bike was the '75 Fuji at 26.5 pounds. I weighed 135. 10%? There were NO 13.5 pound road bikes back then. The Fuji was closer to 20% of my body weight. More than 20% if one considers as-ridden weight including water bottle, spare tube, toolkit and pump/inflater. Even if you were to use the tubular-equipped Paramount and add the extras, you'd still be getting close to 20%.
In the intervening 45 years, I've packed on over 70 pounds - an additional 50% of my initial weight - actually at one point I was 219 but I'm down to ~203. If I were to really consider weight weenie-ism, I'd lose a greater percentage of weight off myself than I could ever take off the bike (or get a 'more modern' 10-pound lighter bike...
