Totally Tubular
#1651
Quoted: 1814 Post(s)
Liked 923 Times
I'm a pretty aggressive rider, so I want some margin of safety. At the same time, I know how to ride carefully and wish to be able to remove the tire without damaging it (fixing flats). I also live in a pretty flat area with only a few short but steep hills. Basically old school racer dude.
If you want some margin of safety, then use glue. Mastik (prob the most used currently) does not prevent the tire from being removed without damage,
nor do others IME. The idea that one needs to ride carefully so as not to have the tires come off is unfounded and will mess up your results and enjoyment.
You are likely not as aggressive a rider as top pros, and they don't hold back, in spite of arguably skimpier glue jobs that those of the anxious amateurs.
#1652
smelling the roses
Quoted: 7081 Post(s)
Liked 901 Times
Like smantanaro, I find the hand brush works well except on fendered bikes. That rear wheel, already prone to more flats just being a rear wheel, never gets brushed. Tiresavers are a real plus there, (They always went on my fendered and tubular bikes. Front was not required but I did on my rain bikes to keep my gloves cleaner.
Trick to reducing the noise - ride rib tread tires, those tires with longitudinal parallel ribs. Those were common on training level tubulars 45 years ago and Vittoria has brought it back with their G+ and G2,0 tires. (Aside - also my favorite tread pattern ever, Thank you Vittoria for bringing it back! Best tread ever if you have to leave the paved road surface and climb back on.)
Ben
Ben
#1654
Bikes: many
Quoted: 1446 Post(s)
Liked 1,395 Times
I have a couple Challenge Strada tubulars (25mm) which I liked well, but which "delaminated" a while ago. I decided I would see if I could reattach the tread to the casing and stumbled on this web page
Cross Tubular Tread Repair
The author suggests this tread separation is fairly common with handmade tubulars. These Challenge sew-ups are the only ones which have suffered this way for me. I've not yet tried this repair. I'm still mulling over what sort of glue/contact cement I should use. I have a number of different things to try, Vittoria Mastik One, barge cement and cork renew (which is used for refreshing latex tanwalls). Or I can go find E-6000 at the hardware store.
#1655
Liked 923 Times
I'd use Barge. Stick some bits in to keep the tread separate from the casing while the glue dries.
No need for all that tape, etc. & you can see the result.
#1656
WGB
Bikes: Panasonic PT-4500
Quoted: 1800 Post(s)
Liked 2,334 Times
Bumping to ask about that CX-10 tape.
Note on the website said the tape is used to fill in over glue to ensure full adhesion. Is that just a cya example or should it only be used with glue??
Asking because can't find an online review anywhere for this tape but like the price as I have 3 sets of wheels to set up.
#1657
Quoted: 765 Post(s)
Liked 660 Times
www.redclovercomponents.com
--Ogden Nash
--Ogden Nash
Likes For jonwvara:
#1658
I purchased a set of used carbon tubulars from a local wheel builder for ny Cannondale. The set came with like new Vittoria Corsa tires already glued by the builder. They were team wheels but everyone switched to tubeless.
I got a blow out on the rear, sidewall from debris, had a spare, could not for the life of me get that tire off of the rim on the side of the road. I had to call the wife.
At home, it took me about 25 minutes of prying with a plastic lever to get enough tire off of the wheel to pull the rest. He glued them like you need to glue cross tires. A three day process he told me.
Glue overkill! I never had such a hard time getting a tire off.
Decided to replace both tires with a more moderate glue job.
My bikes: 1970`s Roberts - 1981 Miyata 912 - 1980`s Ocshner (Chrome) - 1987 Schwinn Circuit - 1987 Schwinn Prologue - 1992 Schwinn Crosspoint - 1999 Schwinn Circuit - 2014 Cannondale Super Six EVO
#1659
How many tires to buy?
Wondering how many tires y'all experienced tub riders purchase when you find a good deal. I guess the short answer is "more than 2". Is it 3 or 4 or multiples of 2?
Being of thrifty Scots descent, I usually try to rotate clinchers to get the most miles possible out of a pair, which may not be practical with tubs. Any advice on that?
#1660
Liked 923 Times
Not more than two. Have to resist buying when the sales come by as it would take ten years to wear out what I have mounted or on hand.
Mostly it's just replacing the back tire- the front doesn't wear much.
#1661
Liked 923 Times
That sucks. Maybe needed a knife in the kit to cut the tire off.
#1662
If I own it, I ride it
Quoted: 591 Post(s)
Liked 663 Times
#1663
Quoted: 2338 Post(s)
Liked 2,827 Times
#1664
It's MY mountain
Bikes: Klein, Merckx, Trek
Quoted: 4338 Post(s)
Liked 2,982 Times
#1665
Some Weirdo
Bikes: '86 Schwinn Prelude, '91 Scott Sawtooth, '73 Raleigh "Grand 3"
Quoted: 223 Post(s)
Liked 141 Times
I did my first glue job this past weekend with Tubasti and a hard anodised rim. Way too skimpy! The glue didn't properly bond with the rim and left a couple 3" chunks completely de-bonded. Sanded the rims a bit today; will glue tomorrow. TubAsTI!!!
Somewhere, a village is missing its idiot.
#1666
Quoted: 4806 Post(s)
Liked 3,932 Times
I never trust new rims. Wouldn't race them until I'd pulled off a tire and the glue stayed on the rim. Sanding isn't necessary but I doubt it hurts. But sanding the surface oil into the scratches means its still on. Clean all those bare spots. Then you can fill them and let that harden. Then you can re-glue and mount the tires.
Once you have a good base and little glue pulls up with a pull-off, you will have what I loved - a good reliable, secure system where pulling the tires isn't impossible and can be done on the road and spare tires mount and stick plenty well enough to get you home. (Some glue pulling up happens. Not a big deal. This isn't like clinchers with their wire beads that MUST be very close to exactly the right diameter or mounting is completely impossible or the tire slips off and blows. Glue is VERY forgiving of discrepancies and once you've forgotten, it doesn't matter.
Ben
Likes For 79pmooney:
#1668
Quoted: 5888 Post(s)
Liked 3,471 Times
Have you been using those taped on tubulars going down the mountains near you?
#1669
Quoted: 765 Post(s)
Liked 660 Times
Somehow I ended up with more sets of tubular wheels (and rims) than I've ever wanted to own, . I keep thinking it's time to start riding them again because I love the way they ride but gluing them is no fun. Tape is the way to go. $10 for 2 wheels which is what Jantex runs isn't bad. The Effeto Mariposa Carogna gets good reviews but it's $20 for 2 wheels.
Eugene Sloane mentions Jantex tape as an alternative to cement in my 1969 copy of The Complete Book of Bicycling. So the stuff has apparently been around for awhile.
--Ogden Nash
--Ogden Nash
#1670
Liked 3,471 Times
Well, they're not exactly mountains, but I'm on the height of land between the St. Lawrence and Connecticut Rivers. There are a lot of long steep climbs. I don't have many miles on the new wheels, in part because I'm recovering from a shovel wound on my shin several weeks ago (don't ask.) I'm also not an aggressive cornerer on steep descents. But I have a lot of confidence in the tape just from trying to shift the tires with my fingers--they seem to be really stuck on there. And as you say, the price is right.
#1671
Quoted: 1858 Post(s)
Liked 606 Times
Tufo Hi-Composite Carbon Tubular Road Tyre
From Wiggle...I've run a set of these for awhile. Didn't really like them at first but once you get the pressures right they are excellent. So I just ordered a second set at $55 Cad each. But when I check the price in US funds they are $62.21 odd but still a good deal. If you don't mind black walls.
https://www.wiggle.com/tufo-hi-compo...rr=USD&dest=18
#1672
Freewheel Medic
Quoted: 1453 Post(s)
Liked 2,196 Times
Speaking of Tufos, I got a great deal on Tufo Tubular Clincher C S33 PRO 24 tires from BikeInn back in June, and they arrived last week. Yesterday I had time to mount them on my mid-90s Mavic Cosmic Expert wheels. My thumbs still hurt from stretching them onto the rims. Took a good 15-20 minutes each, plus time to adjust the ribs on the tires into the lock edge on the clincher rim. They look great. It might be a few weeks before I have a chance to ride them. I'm in the middle of a house sale and have no time for riding.
For those who are curious, these really are tubular tires which fit on clincher rims.
Bob
Bob
Likes For pastorbobnlnh:
#1673
#1675
Veteran, Pacifist
Quoted: 3900 Post(s)
Liked 4,843 Times
Have been recently experiencing some slow leaks on tubulars mounted a few years ago. The kind of leak that doesn't interrupt a ride, but the next morning a tire is very low or flat. Only the Specialized Turbo shows a lot of wear. The 30mm Schwalbes (my preferred gravel road tire) have many small tire 'cuts', that might let in grit.
I hate uncertainty. So yesterday I spent a couple of hours (including the check rides) adding liquid latex to 3 sets of wheels. I think it's time well spent. Will do the rest of the tubulars over the next month.
Likes For Wildwood:
