Today I (v2):
Bikes: Handsome Fredward, Trek 1.1
Quoted: 481 Post(s)
Liked 131 Times
^Loctite per directions and past prior success. Works as an anti-seize agent as well.
Quoted: 399 Post(s)
Liked 274 Times
https://www.amazon.com/Loctite-19269.../dp/B00FKFGSHE
Quoted: 481 Post(s)
Liked 131 Times
I had some difficulties installing my own Phil Wood BB recently...no matter how well I thought I'd cleaned the threads, and even using a pretty generous amount of the blue thread locker that they include - the damned cups kept backing out after a few hours of use. When I asked the owner of my favorite bike shop about my problem - he gave me some of his "Loctite Primer" to use, and Voila - everything is fine now and I love my new bottom bracket. BTW, it comes in a spray too
As a side note, I think every shop where I live would look at me sideways if I asked for help with a $120 square taper BB requiring proprietary tools.
Quoted: 399 Post(s)
Liked 274 Times
Yup - in my zeal to do everything right, I let it sit a full 24 hrs every time. I had Frame-saved my frame while it was broken down so maybe that had something to do with my problems, and cleaning the shell a 3rd time was the charm or maybe it was the primer - but finally everything clicked and now I am quite happy with it
Quoted: 481 Post(s)
Liked 131 Times
I'm not saying you're wrong (haven't tried it), but having a locking compound to hold the cups in place seems completely necessary as there's nothing else keeping them in place. I don't see how antiseize alone would do that, especially over months of use?
Your cog is slipping.
I didn't use thread locker on my Phil cartridge BB and have never had any problems. Are you sure both cups are pressed onto the cartridges properly?
Quoted: 481 Post(s)
Liked 131 Times
Bikes: Felt TK2, Felt Z5
Quoted: 943 Post(s)
Liked 20 Times
Today I sized down in a jersey. Took back the one I originally purchased but never wore or cut the tag off. It is a local shops club jersey and it was a bit flappy. The one I got today? Tighter than a second skin. Into my second month of a diet and lifestyle change and while I have lost weight and some inches, oof, this one makes me feel a bit self conscious.
Quoted: 481 Post(s)
Liked 131 Times
Quoted: 1332 Post(s)
Liked 398 Times
Took the GT out for its first ride today, just under 30 miles. Can definitely feel the extra weight on hills, but it feels super smooth on the road. Have to switch out the seat post though, since I can't get it low enough with the Thomson setback post I got. Swapping it with my track bike's post for now.
Quoted: 481 Post(s)
Liked 131 Times
Quoted: 481 Post(s)
Liked 131 Times
Calamari Marionette Ph.D
Repeated movement will push soft things away, like grease, anti-seize, etc.
As a "solid", Teflon tape will occupy the gaps and cannot be pushed aside, and will neither decompose, nor wash out. Think about why plumbers use it.
Wrap the BB with one spiral and screw it in. If it screws in easily, remove it and the Teflon tap. Apply two wraps (or 1.5 overlap) and try again. Repeat this process of increasing the overlap and thickness until it takes a good amount of effort to screw it in. Not enough to F things up, but it should require a firm effort to turn it all the way from the first turn to the last.
The C&V guys swear by this. When I think about a 40 year old bike that has seen a gazillion miles and had the BB replaced many times over the years it makes perfect sense to me.
Like I've said, I've never done a BB before.
But I have used it on motorcycles where the male/female threading interface felt poorly matched (sloppy) and I was worried about the fastener coming loose.
Bikes: stinner cx, paramount track
Quoted: 262 Post(s)
Liked 9 Times
was that green ss that replaced that surly chased and faced?
i think teflon tape is a bad idea and seems like a super huge pain to remove all that film out of your bb threads after the fact.
It's TEFLON after all. It was invented for "Non-stick" purposes.
Quoted: 481 Post(s)
Liked 131 Times
Easier than cleaning dried Loctite out of the threads, I can assure you.
Bikes: steel track
Quoted: 235 Post(s)
Silver anti-seize is the worst thing I've ever done to my bike. Bleeds everywhere and is an enormous pain to clean (especially from threads).
It's got its uses, but never again on my bike. Waterproof grease does the job just fine in most cases, and I'd go the teflon tape route to address the issue described here.
Quoted: 443 Post(s)
Liked 12 Times
today i got 4,000 miles for the year. took me 7.5 months to achieve this year that took me all of 2016 to do.
At any rate, I've never seen such over-thinking and over-analyzing in regard to installing a square-taper bottom bracket in my life.
THE STUFFED
Bikes: R. Sachs Road; EAI Bareknuckle; S-Works Enduro
Quoted: 361 Post(s)
Liked 20 Times
Grease is all you need unless you're dealing with a Ti frame.
