50+ Thoughts on going tubeless.
#176
Quoted: 4406 Post(s)
Liked 4,857 Times
The tube just seems redundant once you go down the sealant route. Except as a last resort backup for roadside repair when all else has failed. Which for me has never happened ever.
#177
Liked 4,857 Times
The one reason I'm avoiding going tubeless is I never ever want my bike or myself sprayed down with sealant, or have it all over my hands, wheels, tires or garage. Or take on the extra maintenance of adding/cleaning goop. Running tubes is not a hassle in the least. Okay, at least three reasons.
#178
Quoted: 8279 Post(s)
Liked 9,036 Times
A friend had a flat with a tube which had sealant in it. While he was installing his spare tube I put some air into the flat to see if I could locate the leak. I couldn't find a leak and then couldn't deflate the tube because the sealant had sealed the valve. Oops. Didn't have a removable core.
Likes For big john:
#179
climber has-been
Quoted: 3430 Post(s)
Liked 3,566 Times
#180
Liked 9,036 Times
Some years ago our group was riding in the mountains on a cold day and some of us stopped at the only cafe on route while others kept going, heading for a descent known for causing flats with sharp rocks and holes. A guy in the lead group who happened to be running tubeless double flatted, cutting both tires.
Those of us who had stopped to eat were running nearly an hour behind them but when we got there they were still struggling to put tubes in his tires. Now I know some rim/tire combinations are worse than others and many riders are inept when it comes to fixing things but this was ridiculous.
I have tubeless ready tires/rims on my mtb but they have tubes in them. I might go tubeless but haven't yet. I ran over a huge nail and had to dismount the tire during the ride. What a giant pain! I think it took me 30 minutes. It was more difficult than my old motorcycle tires, the front one anyway.
#181
Liked 4,857 Times
#183
Liked 9,036 Times
Had you run your mtb tyre tubeless you could have simply pulled the nail out, fired in a Dynaplug (or similar) and been on your way in less than a couple of minutes. Tubeless for mtb has been a no-brainer for years now, despite the inevitable resistance when it first appeared some 20 years ago.
#184
Liked 9,036 Times
Overall, the biggest takeaway from AeroCoach’s latest round of testing seems to be that casing flexibility is the most important single determinant when it comes to rolling efficiency. However, it’s also interesting that AeroCoach found no difference in rolling resistance between a tubeless-ready tire that is set up tubeless with a latex-based liquid sealant, and one that has a high-performance latex inner tube installed.
What’s faster, tubes or tubeless? The answer remains the same: it depends - CyclingTips
#185
climber has-been
Liked 3,566 Times
Already done, in this thread.
#186
Agree with this. I went tubeless straight away on my Domane with GP 5Ks. This decision was almost 100% because I wanted to. My rural roads aren’t the smoothest but generally clear of flat causing crap. Flats are not a headache for me. So far I’m pleased. Only issue I’ve had is the front tire valve clogging with sealant. I pulled the core out and heard the dreaded pop-pop and sealant oozing out. Well, crap I thought. Put the core back in and pumped back up to my normal 60 psi. Seated right back in place. I did have my LBS replace the core.
#187
Bikes: Time Scylon, Lynskey R350, Ritchey Breakaway, Ritchey Double Switchback, Lynskey Ridgeline, ICAN Fatbike
Quoted: 464 Post(s)
Liked 546 Times
Maybe. Convince me. How would I have handled this situation had I a tubeless system?
1. Put a tube in a tubeless tire - might work but messy and a hassle.
2. Attempt to repair with more sealant - unlikely to be successful
3. Call for a ride.
As it was, I changed the tube and put in a dollar bill boot and rode home. Put on a new tire when I got back.
No, this is not a "normal" flat, but it's valid to include it in the mix.
I use sealant in my tubular tires, because "why not?". But I still bring a spare.
3. Call for a ride.
I have had two hassles with road tubeless:
1) tape / rim / sealant compatibility. Tires would be fine for a month or so, then go flat sitting over night. I tried several brands of sealant and tape. Settled on Orange Seal Winter and 3M tape.
2) Royal 1st class PITA to mount: I use a ratcheting wood worker's clamp to keep one side on the rim. I have used the same clamp to dismount tube and tubeless MTB tires that seem to get stuck to the rim. I also use my higher quality levers (Pedro's for me, but I am sure there are other brands that are just as good or better). The cheap ones that I had to change tubed touring tires don't seem to do the job.
The issue I have not had is having to put a tube in on the road. I don't like the idea of patching larger cuts with a piece of plastic or paper to hold the tube in place. When touring I carry a spare tire in the paniers.
I do know that when I take an old tubeless tire off it is not that big a job. Again, I am using a stiffer tire lever. And, yes, in the "good old days" I changed road tires without any tools. So maybe carrying 3 nylon levers is a downside.
#188
Quoted: 111 Post(s)
Liked 69 Times
Can you set the beads on a new (recently folded) tubeless tire on the roadside with a CO2 inflator or road pump?
Some accounts say it's easy, other folks complain that it's tough with a regular floor pump (or even a compressor, sometimes..).
#189
Quoted: 2975 Post(s)
Liked 1,181 Times
It is too bad I just replaced my front (GP5000 tubeless) but the rear is nearing replacement. When it does need replaced, I will put a drywall screw through it. I will let you know how it works, but I expect it to hold air.
https://www.trekbikes.com/us/en_US/e...strip/p/31426/
As far as fit and mounting...that doesn't change whether it's a tubed or tubeless tire. I've had some tires go on easy and some are a PITA...both tubed and tubeless...depends on the tire manufacturer and model. Just because a tire is tubeless doesn't mean it's harder to put on than the same exact make and model of tubed tire.
#190
It's MY mountain
Bikes: Klein, Merckx, Trek
Quoted: 4338 Post(s)
Liked 2,980 Times
Likes For DiabloScott:
#191
Liked 4,857 Times
#192
Syringe or Not
Does anyone use the syringe to put in the fluid? I've changed my tubeless fat bike tires a couple of times, and it can get messy, even if I am careful. I was initially keen on the syringe, but an LBS guy said no need. I think I am going to revisit this. I realize that most of the mess is from removing the tire, which wouldn't involve the syringe. Thanks.
#193
Super Modest
Quoted: 10963 Post(s)
Liked 4,620 Times
I use a syringe on road bikes. Works fine. I rotate the valve to about 7 or 8 and slowly put the fluid in. Reinsert valve. Be sure to wash the syringe. I’ve probably done 10 tires that way.
Keep the chain tight!
Likes For Trsnrtr:
#194
Would 4 or 5 o'clock work? I will do this next time. I have a Monster X Seven being built, which I may receive someday if SRAM starts producing some components, or they make it out of the docks in LA. That will be all tubeless. Thank you, Dennis.
#195
Liked 1,181 Times
#196
Liked 4,857 Times
Same with Muc-off sealant if you buy the litre bottles.
#197
Quoted: 464 Post(s)
Liked 546 Times
Back when I ran tube tires we did have a pinch flat, though, on a very rough "B" road on Skye. My pump failed to inflate anywhere close to the correct inflation pressure. Three French lads came over the hill and one of them had a Silca pump in his pack. I bought one when I got home.
At home I use a compressor. If my pump can't inflate it on tour I will put the tube I carry in.
#198
Quoted: 464 Post(s)
Liked 546 Times
Usually the manufacturer of the tubeless compatible rim will make a tape that fits the rim correctly or in the case of Trek, they make a one piece tubeless strip if you don't want to use tape.
And when I think about it, the 32mm on the tandem are not so bad. Spinergy wheels from House of Tandems. It is the 25mm on the solo bike Rolf wheels that are so hard to mount..
#199
Liked 1,181 Times
Yes. Because if you are doing a roadside fix on a tubeless tire, more than likely you are putting in a tube and when you pump it up it will seat the beads.
