Addiction 2024.1
Bikes: 79 Trek 930 is back on the road, 80 Trek 414, 84 Schwinn Letour Luxe,87 Schwinn Prelude, 92 Schwinn Paramount PDG 5
Quoted: 3235 Post(s)
Liked 1,872 Times
Definitely a misfire, rough idle but doesn't die. The thing that makes it especially fun is that it only misfires on cold start. If the engine warms up and it's driven a little bit then left to sit everything is happy and no DTC codes thrown.
Thanks, I grabbed a coil just in case but I'll be more than happy to return it. I've got to do this in my driveway tonight so my wife can get to work the rest of the week, so hopefully a new injector fixes it. I'll clean all contacts on the injectors and take a look at the harness assembly since I've got to take the whole damn thing apart anyways. Why does it always have to be the hardest one to get to?
Quoted: 3369 Post(s)
Liked 3,677 Times
Thanks big john and LAJ. No more misfires on my test drive tonight. Did plugs, too. Felt a lot zippier!
My guess is that the plastic retaining tab on the injector connector failed so it was making intermittent contact. I went ahead and replaced the injector since I was in there, but I didn’t have a new connector so it’s got a zip tie bandaid that I’ll remedy on Sunday.
Ended up having to use the coil I had bought since one of the connector retaining clips broke on the coil side of that one too, and then a second one broke about halfway off so I’ll fix that properly when I do the injector harness work.
At least now I know exactly how to pull the intake and fuel rail now, and since I won’t have to remove the injector again I shouldn’t smell like gas after I do that work.
Crimping is the best splice method for engine stuff, right?
Liked 1,872 Times
I came in tired today but not completely wiped like yesterday. I am completely wiped now though. All afternoon in the wood shop. A good wiped.
Quoted: 8322 Post(s)
Liked 9,132 Times
The good heat shrink connectors will make a complete seal when you get them hot enough.
I started using gloves whenever handling fuel or battery acid after years of smelling like gas or diesel. I think diesel is harder to get rid of than gasoline. I use chain lube that has kerosene or diesel in it and I always glove up so I don't smell like that later.
Mostly Harmless
Bikes: Have two wheels
Quoted: 13736 Post(s)
Liked 4,542 Times
Liked 9,132 Times
Likes For big john:
Liked 3,677 Times
A lot of that plastic stuff gets brittle after so many years. Some recommend heat shrink connectors for splicing but I soldered a lot of wires, too. Some are against soldering but I did it a lot without comebacks. Solder and use heat shrink tubing, works in places where you can't get easy access.
VFL For Life
Bikes: Velo Volmobile
Quoted: 28693 Post(s)
Liked 1,869 Times
VFL For Life
Liked 1,869 Times
Not actually Tmonk
Bikes: road, track, mtb
Quoted: 2685 Post(s)
Liked 3,217 Times
West coast bands should do more drug testing. SMH.
KCB members always maintain a professional demeanor, obviously.
https://twitter.com/MarchMadnessMBB/...85894791070070
"Your beauty is an aeroplane;
So it is
Quoted: 11419 Post(s)
Liked 4,790 Times
So it is
Liked 4,790 Times
Likes For LAJ:
Liked 9,132 Times
Likes For big john:
Liked 9,132 Times
So it is
Liked 4,790 Times
VFL For Life
Liked 1,869 Times
Klaatu..Verata..Necktie?
Quoted: 10477 Post(s)
Liked 11,991 Times
Finally got the Dodge towed to a mechanic. Fingers crossed.
It turned out to be SO SIMPLE that I feel stupid for putting it off. This happens all the time with anxiety-driven avoidant behavior, unless what you're putting off is something that gets much, much worse if you put it off. Then you feel REALLY stupid for putting it off. But, if emotions always yielded to logic, the self-help and counseling industries would never have existed.
cowboy, steel horse, etc
Bikes: everywhere
Quoted: 12841 Post(s)
Liked 7,763 Times
Mostly Harmless
Liked 4,542 Times
Bikes: everywhere
Liked 7,763 Times
NCMD.
Quoted: 10246 Post(s)
Liked 5,205 Times
over dressed for Austin.
VFL For Life
Liked 1,869 Times
climber has-been
Quoted: 3496 Post(s)
Liked 3,637 Times
Not actually Tmonk
Liked 3,217 Times
killer, nice work! How does the garmin device determine VO2? Is it backing out the cardiovascular stuff from power and weight?
Not actually Tmonk
Liked 3,217 Times
Killer groove here, and Hiromi's piano solo is sooooo sick. So much fun.
