#4126
Quoted: 1106 Post(s)
Liked 1,328 Times
Worked the dent in the top tube of my Koga-Miyata WorldTraveller with a set of Paragon Machineworks tube blocks. They referred me to Ceeway bike building supplies in the UK as shipping from there was a lot cheaper.
Worked pretty well but I will try again next week when my vice comes in to put some actual clamping force on there.
If you have a clean shiny greased metal surface the blocks work MUCH better.
Likes For oneclick:
#4127
Ellensburg, WA
Bikes: See my signature
Quoted: 313 Post(s)
Liked 458 Times
Slowly working on the overhaul of one of the Colnagos from last weekend. It's cleaned up well. It was a frankenbike of components so Roger M helped with a few bits to make it consistent. Cleaned and polished it last night and started putting it back together.
#4128
CL Addict
Bikes: '50s Leon Cattrysse - late 50s Raleigh Lenton Sports - 1960/61 Raleigh Lenton Grand Prix - '72 Canadian Tire Company Supercycle - '74 Raleigh International - '83 Nishiki Cresta - '84 Centurion Turbo - '86 v. Herwerden (Chesini) - '87 Specialized Sirr
Quoted: 85 Post(s)
Liked 96 Times
Building a couple of wheels this morning.
Likes For malcala622:
#4131
In the wind
Ready to build. Was planning to use v-brakes (and even bought new levers) but the post spacing on the front fork is so narrow that I fear I will be forced to stick with cantis.
#4132
Quoted: 1199 Post(s)
Liked 1,355 Times
I got a sort of beat up Cinelli 1R stem to gut it for the small parts.
#4133
A bit of work on my Ross 294S. Cold set and realigned the rear, went from bar end to DT shifters (both 8 sp), added a spacer to the bb for better chainline, made some mudflaps. I think it’s about done.
#4134
Long time part timer
Liberia "clunker" rehab
It started with this post.
Since this Liberia is a cool frame and in my size neighborhood I knew I wanted to do something with it but didn't know what. I'm not a "restorer" of bikes so stripping, painting, new decals, etc. wasn't in the cards - besides, I like patina Ultimately I wanted to make this an errand/rail trail/ lunch ride bike so I decided to give myself a "clunker challenge" and use parts I hopefully had already.
I got lucky with the bottom bracket. The cottered cranks had to go but I knew I didn't want to blow the budget on a square tapered conversion kit.so I messed around with some spindles at a bike co-op and found one that fit perfectly. From there the dominos started to fall: a Sugino crankset, Tech 500 (Falcon) RD, Shimano FD (only one I had that fit the seat tube), ornate Rigida wheels, Maillard 5sp freewheel, Weinmann brake levers, wear-appropriate Avocet saddle and reflectors were yanked from the shelf or other parts bikes. The Huret DT shifter was also from the co-op. I already had some universal shifter cables so I could use it as well as some black bar tape. The new dummy-cut-it-too-short chain from another project was used here with a pair of master links (at least I had the sense to keep the extra links!). Mafac Racer brakes were already on the bike but I took them apart and gave them a cleaning. I did have to purchase some wire-beaded tires for the straight-walled rims and new brake hoods but I ended up having enough left over in the budget to buy some Kool Stop salmon brake pads to replace the original (worn) Mafac pads.
I had a lot of fun with the rehab especially knowing I literally saved this cool bike from the dump. I'm looking forward to starting its new life this weekend.
Before:
After:
Before:
After:
Likes For HMJ:
#4135
No projects at the moment, so I’ve been collecting and organizing my tools and parts cabinets.
Semper fi
Semper fi
#4136
Quoted: 5888 Post(s)
Liked 3,471 Times
I got lucky with the bottom bracket. The cottered cranks had to go but I knew I didn't want to blow the budget on a square tapered conversion kit.so I messed around with some spindles at a bike co-op and found one that fit perfectly. From there the dominos started to fall: a Sugino crankset, Tech 500 (Falcon) RD (only one I had that fit the seat tube), Shimano FD, ornate Rigida wheels, Maillard 5sp freewheel, Weinmann brake levers, wear-appropriate Avocet saddle and reflectors were yanked from the shelf or other parts bikes. The Huret DT shifter was also from the co-op. I already had some universal shifter cables so I could use it as well as some black bar tape. The new dummy-cut-it-too-short chain from another project was used here with a pair of master links (at least I had the sense to keep the extra links!). Mafac Racer brakes were already on the bike but I took them apart and gave them a cleaning. I did have to purchase some wire-beaded tires for the straight-walled rims and new brake hoods but I ended up having enough left over in the budget to buy some Kool Stop salmon brake pads to replace the original (worn) Mafac pads.
Before:
snip . . .
After:
Before:
snip . . .
After:
Also French threaded bottom brackets are not expensive. You can pick up a set from Amazon for $14:
https://www.amazon.com/Action-Bottom...6081238&sr=8-1
Likes For bikemig:
#4137
thanks!
Very nice. I did something similar to an early 70s Peugeot UE8. The bike comes stock with a cottered crank but I managed to make a cotterless spindle work with the exiting cups.
#4138
Bikes: A few too many
Quoted: 1364 Post(s)
Liked 2,181 Times
Not bike related, My 50-gallon water heater gave out and I got quotes of 1800.00 to 2600.00 depending on the model to install a new one.
Big box store and done for under 800.00 and 1/2 day work.
Curbside pick-up next week...and while I support my local businesses....I felt in this instance I could use the support.
Best, Ben
Best, Ben
Voltaire
Voltaire
#4139
Quoted: 1143 Post(s)
Liked 1,743 Times
I would like to give a shout out for the premier vintage bike shop and repair in King Co., Wright Bros. I had Charles chase the bbs on a couple of elders. Soon I will have the Peugeot available for cruising. Unfortunately I'm running into issue pulling the freewheel off Normandy/Mavic sewups, so I'm going to have to use some back up clinchers.
Here is the before shot on the fence at Bikeworks, it's cleaned up very well but the front derailleur is frozen. Bummer cause the body is not cracked like most are these days.
#4140
Overdoing projects
Quoted: 784 Post(s)
Liked 1,238 Times
While I wait for stocks to replenish a bit I did some test fitting on the 1992 Koga-Miyata Traveller I picked up yesterday.
While the 1993 WorldTraveller gets the full rando treatment with some cool parts I just wanted to turn this one into a cheap gravelgrinder/xBike. So with as little parts as possible and with wider tyres. Just a fun throw-it-around bike. Probably a 10-speed Microshift group or a 2x11 friction setup.
It will need different rims but that shouldn't run all that expensive, especially if I can somehow reuse the spokes.
Still needs cleaning though.
First impressions are that it will easily fit 42mm tyres which should make for some interesting riding.
#4141
Bikes: Trek 970, Bianchi Volpe,Casati
Quoted: 358 Post(s)
Liked 122 Times
Whaaa
Best, Ben
Best, Ben
#4142
Liked 2,181 Times
Like auto mechanics at some, dealerships where labor is 140-180 an hour (VW), there is a book rate no matter how long it takes to install anything.
It still takes more than 2 hours to do this job....but I could use the money and was able to do it myself.
I know what things cost and how to do a lot of maintenance so I usually do the work....cars with computers and a lot of plastic garbage that passes for parts are another matter.....still driving my 83 and 1990.
Ben
Voltaire
Voltaire
#4143
This1981 Trek 412 (One of the Waterford bikes) from a local flipper.
@DQRider - A 1981 Trek 412 24" is my fist Trek as well and I'm really loving it! I'm trying to run Mud butler fenders as well, what is the max tire size you can fit under them? I'm hoping to run 700c x 35s. Also is that wheelset from velomine? If so how are you liking it?
#4144
buy my bikes
Bikes: my very own customized GUNNAR CrossHairs
Quoted: 519 Post(s)
Liked 428 Times
is that a heavy oil or an adhesive?
I've been using a light 3-in-1 oil.
Over this winter I build a wheelset with vintage hubs, new spokes, new nipples, new rims. Seem like the first few months of use are going fine.
I build a 2 speed kickback wheel, all new stuff. Seems OK. So far.
I re-built a front wheel to replace a rim, so re-cycled spokes. Initially I re-used the nipples, or tried to, but a few were full of some kind of heavy goop used by VELOCITY. I guess to machine build the wheel.
I road it once and had lots of clicking and couldn't get round enough (I thought), so I replaced all the nipples and used 3-in-1 oil.
Rode the wheel again about 16 miles, seemed good - took off for another longer ride and EVERYTHING came loose. No crash or anything.
- so I dropped some blue thread locker onto the nipples where the spoke enter the nipple and tightened everything back to true and round (I think). Planning to test ride today.
Wondering if I got this all screwed up....
#4145
CL Addict
Quoted: 85 Post(s)
Liked 96 Times
I do use engine oil for my spokes and nipples.
Likes For b dub:
Likes For daverup:
#4147
1978 Fuji S10s that I got for $40. All original with a missing saddle.
Wrestling with a seized stem and should be downhill (hopefully) from there.
#4148
Quoted: 938 Post(s)
Liked 2,944 Times
Dynamo lighting for the Mk I. Of course, that includes relacing the front wheel with the super-cheap Panasonic hub that Soma had on sale a month or so back. What I save there went into the BM IQ-X and Secula fender lights. I have two more bikes to similarly outfit.
Likes For ascherer:
#4149
Quoted: 4512 Post(s)
Liked 6,386 Times
Unlike my usual setup that ends up with addonitis, camera/lights front and rear plus an extra 2 rear 1 front lights and GPS for good measure.
Do you run the lights on in the daytime?
#4150
Quoted: 938 Post(s)
Liked 2,944 Times
Great looking, good job. I always cringe a little bit at permanently mounting things on a beautiful bike but these are integrated perfectly.
"Addonitis", that's great! I'm going to steal that one! It's blocked in the picture but it does sport a Garmin unit and I'm suspecting that radar may creep it's way in. This bike gets a lot of urban miles where I'm matching the pace of surrounding vehicles, but I think this season it will find itself on more shared country-ish roads with limited shoulders where that extra measure may be useful.
