bike science: more than 1 way to turn a bike?
Quoted: 1858 Post(s)
Liked 664 Times
My impression is that a bike can be either steered or leaned to turn.
That you can keep a bike more upright and turn it by moving the bars. Or that you can move the bars less and lean it over more to turn it.
Who is a bike science expert here?
I understand countersteering. I also see that wiki says "countersteering has not yet been fully described in scientific literature."
It seems like some geometry is more conducive to leaning a bike. ...Fork flop is a front end function. Some bikes have a slack head angle and thus a lot of fork flop and yet don't turn the bike quickly: like a chopper. The front wheel lays over more than it redirects the bike. Other bikes have steep head angle and small bar movements change bike direction a lot.
I feel like I can take slippery corners faster than many riders, especially in cyclocross, because I have more steer in my ratio of lean/steer. The bike might as a result slide in a corner but it doesn't fall down. (This happens in rain, mud, snow.)
In fast flat crit corners I feel like I can go thru them faster because I keep pedaling through the corner, again because of my steer proportion. ...In an UPHILL corner most know how to corner AND keep the power on, but some do get confused because they aren't used to powering and cornering at the same time.
Quoted: 3376 Post(s)
Liked 5,526 Times
After taking a motorcycle training course to get a motorcycle endorsement on my driver's license and buying my first motorcycle at age 50, I learned from from the instructor to push on the right side of the bars to turn right. If you quit pushing the bike will quit leaning and go straight. Counter steering force must be maintained to keep turning. It's not just something you do to initiate a turn. The problem with drop bar road bikes is that pushing to rotate the bars from the drops is awkward. For most, it's pushing down that translates to a small rotation of the bars. With a straight bar bike, counter steering works more like a motorcycle. A common cause of motorcycle accidents is failing to push hard enough in a right turn. The rider panics and quits pushing, with the bike going into the on coming lane. Slowing down also tightens the turn.
After passing the MSF course and getting my CO motorcycle endorsement, I bought a bike.
The first time I descended Boulder Canyon, I missed a curve. i.e. I ran off the left side of a righthand curve into the gravel, but thankfully there was enough space to brake to a stop w/o hitting anything or dropping the bike. Shaken, I went hope and began an online search for everything about turning motorcycles. I learned a lot!
Liked 5,526 Times
Here are a couple videos demonstrating counter steering.
In the first, he engages cruise control at 20mph in a large parking lot, and just pushes one end of the bars at a time, Jump to 1:40 where it begins:
In the second, the video is shot by a bystander and played in slow motion, so you can see the movement of the front wheel. This is at 8mph:
Airplanes, bikes, beer.
Bikes: Road bikes, mountain bikes, a cx bike, a gravel bike…
Quoted: 398 Post(s)
Liked 788 Times
Likes For AdkMtnMonster:
Tortoise Wins by a Hare!
Quoted: 1549 Post(s)
Liked 942 Times
Counter steering was taught in the League of American Bicyclists road course. To initiate a turn you briefly push the bars the opposite direction you wish to go. This sets the bike lean up for the direction you want to turn. The quicker and harder you do this the quicker the turn. They taught us how to do this to avoid road obstacles.
Counter steering is for initiating a turn and cannot be maintained. If you push the bar forward and hold it there you will soon be going down.
Liked 5,526 Times
climber has-been
Quoted: 3432 Post(s)
Liked 3,567 Times
Likes For terrymorse:
Liked 942 Times
Maybe the LAB training was wrong, or maybe motorcycles are different, but I don't think so.
So to turn right you push the bars left (that's counter steering) and hold it there? Video please.
Likes For AlmostTrick:
Quoted: 398 Post(s)
Liked 788 Times
Countersteering can be used to shift the weight to the side of the intended turn, but for a left turn STEERING right of center (once already turning) will NOT result in a left turn. Weighting, weight shifting and leaning on a handlebar are NOT countersteering. But please, turn right to go left. It works for UPS. What else can brown do for you, besides stain your shorts?
climber has-been
Liked 3,567 Times
On a motorcycle in a turn, you need to continue pushing "counter" on the bars to counteract the trail forces trying to center the bars. But once in the turn, there is absolutely no counter steering (unless you intentionally counter steer to shorten the turn radius).
Quoted: 398 Post(s)
Liked 788 Times
People are confusing counterWEIGHT with counterSTEER. This is sad. I grieve for the children of the future.
Liked 942 Times
Your bike will not turn left while the front wheel is pointing right (counter steered).
On a motorcycle in a turn, you need to continue pushing "counter" on the bars to counteract the trail forces trying to center the bars. But once in the turn, there is absolutely no counter steering.
climber has-been
Liked 3,567 Times
I don't follow that at all.
If you are in a left turn and you counter steer to the right, the bike will lean farther to the left, you will compensate for the lean by turning the bars left, and the radius of the turn will decrease.
Rule: Counter steering in the middle of a turn tightens the turn radius.
Quoted: 398 Post(s)
Liked 788 Times
https://www.youtube.com/watch?v=lzk8oyNO708
https://www.youtube.com/watch?v=FjA2RsLZknI
Not once in the first video did the bike’s handlebar turn RIGHT when he was making LEFT turns. Pushing on the left bar, once turning, prevents the turn from tightening up and works to establish a balance of energy between speed, angular momentum, acceleration and center of mass and gravity. It’s still not countersteering. Sorry.
Liked 5,526 Times
I use the term counter to include the opposite pressure while maintaining the turn, but yes, the wheel only briefly points in the opposite direction on the initiation.
Likes For Shimagnolo:
Quoted: 398 Post(s)
Liked 788 Times
If you are already in a left turn and you counter steer, you won't turn left?
Steel might be real, but countersteering to turn is not.
climber has-been
Liked 3,567 Times
Also incorrect. Pushing on the LEFT bar, once in the LEFT turn, resists the trail forces of the front wheel from straightening the bike and ending the turn. It prevents the turn from loosening up.
climber has-been
Liked 3,567 Times
Counter steering is the only way you can use your handlebars to:
- initiate a turn
- change the radius of a turn
climber has-been
Liked 3,567 Times
Quoted: 3241 Post(s)
Liked 2,512 Times
After thinking about it, I use the Jeannie method from "I Dream Of Jeannie." I don't have to blink my eyes like Jeannie, either. I think it, and it happens.
Likes For seypat:
Liked 664 Times
I’ve just been reading the Wiki article called “Counter-steering.” There are a lot of other articles which come up in the list of articles, and I don’t know if they are consistent. The one I found shows two kinds of counter-steering. The first one is “by momentarily steering counter to the desired direction ("steer left to turn right").”
The second one (somewhat down-page) in called “counter steering by leaning,” which would have to be what we do when we no-hand.
In both cases after starting the turn, there is the trade off between keeping the upper body in-plane with the bike frame, leaning the upper body into the turn more than the bike frame (better pedal clearance), and leaning the upper body away from the turn (less pedal clearance and the tires are running closer to the sidewalls).
This Wiki article clarified that for both kinds of counter-steer, the counter-steer is for initiating a turn. The bicycle must transition from the steady state of vertical, stable motion in a straight line to a (simplified) steady state of leaning, stable motion in a constantly curved path. I call this “simplified” because a curved path can have varying radius. I think the two modes of counter-steering can force the bike to transition from the leaned mode back into the vertical mode.
I haven’t read the whole Wiki page, but I don’t see where that author says something suggesting the science is incomplete. What I see is that the steered and leaned transitions between two steady state types of path are explained, and the distinctions between steady motion and transitions are made pretty clearly. We weren’t taken into the math, but it seems to me one can create math models for everything that was discussed. With my ancient history in college physics, nothing looks wrong or omitted to me, at least assuming smooth roads, rigid frames and wheels, and of course the ubiquitous ideal sphere from physics textbooks.
Question: where is that sphere when I’m pedaling?
Ken
Quoted: 2236 Post(s)
Liked 1,314 Times
I think perhaps the confusion is in the term counter "steering".
What you are doing is maintaining your balance in a lean by pushing against the inside bar.
Example: You are turning left, leaning left,
You push against the left bar with your left hand to maintain your balance and keep your body up.
If you pull left with your left hand to maintain balance, you would decrease the radius of the turn, your body would not be able to balance and you would fall into the turn or you would counter too quickly and flop the other way.
If you pull right with the right hand to maintain balance you lay the bike down more on its left side (pulling yourself across the top of the bike).
If you push right with the right hand you again decrease the radius of the turn while shifting weight over the bike and laying it down, eventually losing traction on the sidewalls.
Pushing against the left bar allows you to balance and maintain traction through the bike into the tires/road.
When people bail in a turn they usually are going too fast and get afraid of the steep lean and try to right themselves mid turn by pulling the right side of the bar. That increases the radius but shifts their body weight to the outside and they can't maintain the turn so they wander into the oncoming lane. The option then is really to decrease speed while maintaining the turn which is difficult if task loaded and usually one learns to decrease before the turn and then power up through it.
It may be called counter steering but its really counter weighting.
Bikes: Focus Arriba, Specialized Roubaix Expert, Bianchi Impulso Allroad
Quoted: 109 Post(s)
Liked 82 Times
A fault I find with the MSF course is that they don't teach about counter-steering.
Quoted: 18430 Post(s)
Liked 15,584 Times
This train is right on schedule.
Likes For indyfabz:
