#4401
Bikes are okay, I guess.
Quoted: 2647 Post(s)
Liked 2,446 Times
Fixed my old Vetta floor pump, again. Found this thing in an urban alley years ago and it has served well with its Presta/Shrader head and thumblock. The hose finally began to crack and leak a while ago so I cut it and used a barbed fitting to rejoin the sections but the hose lately began splitting at those fittings so I bought new hose at Ace and hooked it up. Works fine again.
#4402
Ad picture. Was hoping for one broken cable guide and the need for some red touch up. Showed up to find extensive paint bubbling on seat tube all around front deraiilleur mount. More bubbling on top tube near cable guides and other random spots. I still gladly gave him his $100 and will tear this one down for a powder coat.
#4403
Quoted: 339 Post(s)
Liked 632 Times
This Ital Vega mixte was once just an ugly taxi cab yellow frame with black stripes on the downtube sitting in the back room of the shop, its head badge taken to complete another Ital Vega restoration. After sitting on the side of my house for a couple years, I decided to put it back together. Mixte’s are such great frames I thought it deserved a second chance. To keep things simple, I thought to use 26inch wheels and a coater brake. No gears, no brake levers or cables, just a simple cruiser. Not wanting to go through the work of completely stripping the paint I chose instead to sand the frame with 400 grit sandpaper, treat any rust spots, spot prime, and then top coat with Rustoleum High Performance enamel in Safety Yellow. The ugly black stripes on the down tube were repainted white and the black stripes were cut from bar rap finishing tape. For a head badge I used a Bike Exchange decal.
Everything went great till I tried fitting the wheels and realized that the rear coaster brake wheel was actually a fractional instead of decimal size. Regular mountain bike tires wouldn’t fit. So, I went with plan B and there you have it, another in my Hipster series and a real stunner that any techie worth their calculator would love to be seen riding around downtown Mountain View on.
Likes For capnjonny:
#4404
Bikes: N+1
Quoted: 94 Post(s)
Liked 419 Times
I had been wanting to try out ergo levers on my de Rosa, but also wanted to keep my wheel set, which is 126 spaced and freewheel. Yesterday I was looking around the back room of the co-op, and saw a bike with a Sachs ergo group. Now, I can index my 7speed freewheel and they look and feel like the aero campy levers I had. The 5000 rear derailer is kind of ugly, so I have an order in for a new success rear.
Likes For VtwinVince:
#4406
Bikes: A few too many
Quoted: 1364 Post(s)
Liked 2,182 Times
Not so much vintage bike wrenching, but working on a carrier solution for said vintage bicycle. In preparation for Cino, I needed to come up with a way to haul our tandem. In the past I put it on the roof of my wagon(using a Yakima tandem rack). For this trip we're driving Mrs. Ms SUV.
Even as tall as I am, I don't want to hoist it up that high. There's also a pretty good fuel mileage penalty with it on the roof(over 1,300 plus miles). I thought about putting it inside with wheels removed, but no room with kids, dog, gear, etc.
Anyhow, I decided to modify the Yakima tandem rack to mount on a hitch rack. With the wheels off, it barely protrudes beyond the width of the car. I am fairly pleased with the results.
You'll have to excuse a couple things. It's just mocked up now, and I need to get to the hardware store for some proper bolts, nuts, washers. Also,, the tandem is being worked on and is missing stoker vars at the moment.
Best, Ben
Voltaire
Voltaire
#4407
Overdoing projects
Quoted: 784 Post(s)
Liked 1,238 Times
And the giant sign you will need otherwise probably won't help fuel efficiency either.
#4408
Liked 2,446 Times
Messed around with the Trek 850 between house chores today, pulling the crankarms and BB in order to dribble some stuff into the seat tube from below. I want to try breaking it loose even though rustystrings61 said he'd take it as is. Look at that rusty powder that came out!
#4409
2k miles from the midwest
Quoted: 525 Post(s)
Liked 931 Times
Trying to decide what I want to ride for next weeks ChillyHilly. The obvious choice is something modern, but I like being different. How about a french-fit, Cinelli Equipe with a 650bx35 conversion. It looks horrible, but I find it to be very comfortable. Still need some tweaking to the cockpit and the brakes re-run.
#4410
#4411
Quoted: 469 Post(s)
Liked 2,443 Times
The tandem on the rack measures 83 inches from the loop on the rear derailleur cable, to the tip of the rack(in front of the fork). Volkswagen specs the width of this vehicle at 78.3 inches(not including the mirrors. They ad 10-12 inches, making total width 88.3-85.3").
The tandem is centered on the rack. There's <2.5" past the body on each side. The mirrors are quite a bit wider than that.
As a salute to jacco, I will probably fly a big banner back there. Not quite sure what it'll say though...
#4412
Liked 2,182 Times
There's a Negative Nellie in every group...
The information you provided in your last link answered some of my questions.
NNN, Ben
Voltaire
Voltaire
#4413
Quoted: 469 Post(s)
Liked 2,443 Times
That was geared towards Jacco, as his comment about it being three feet wider than the car is a bit of a stretch...
I knew it was gonna be wide, and that's why I removed the rear wheel as well. It worked out good in my opinion. I will most probably wrap the rear derailleur in plastic and tape, as well as the saddles.
Likes For Roger M:
#4414
Quoted: 4513 Post(s)
Liked 6,391 Times
Sorry Ben
I think you did a great job of sorting this out.
Maybe the forks bent.
Likes For merziac:
#4415
Overdoing projects
Quoted: 784 Post(s)
Liked 1,238 Times
Instead you chose to be an ass about it.
Anyway, good luck with your project.
#4416
Liked 6,391 Times
#4417
Liked 6,391 Times
#4418
Quoted: 112 Post(s)
Liked 213 Times
So I was overhauling a minty Voyageur recently with zero wear on the chain rings and freewheel.
A check of the chain with the Park CC 3.2 showed the chain needs to be replaced.
This is mystifying. But so is most everything else these days.
#4419
Liked 2,446 Times
Sorting through some handlebars for a touring setup. I usually like a 42cm bar and have several but wanted to try a Randonneur bend, difficult to find that wide. Well, I got an SR out of the co-op's dumpster and it's stamped 42 and measures it but the bar narrows quite a bit at the levers so the width I like is not where I'd be spending most of my time, on the levers. Comparing it to another foundie (like a freebie, only different) shows them very close in width at the ends but not in the middle. Photo angle shows more of a width difference at the ends than actually exists.
Looking at my Cresta GT, the project in mind, its Randonneur bar is also a 42 but a different configuration with much greater width at the levers than the SR bars have. Rats! I was hoping to yank this original bar/stem/levers combo and park it while I use something else on the bike but if the bar is the best of my bunch but I want a different stem and aero levers then I have to take it all apart. Nothing is ever simple.
*edited for more pix*
So here's the Cresta with its stock 42cm Randonneur bar with the setup I'm planning to use, a normal 42cm drop bar on a Technomic stem. This one is slightly wider at the levers but the stock ain't bad by comparison.
And here is the found SR 42cm Randonneur bar compared to stock; more rise and even narrower at the levers, which I feel somewhat negates its width. The flare does make the SR as wide as the stocker at the ends but I'm afraid it'll feel cramped riding on the levers.
#4420
Quoted: 1944 Post(s)
Liked 2,165 Times
Kelly TakeOffs
Finished installing, and tweaking, a set of Kelly TakeOffs. Levers are 6401, which has a spring activated left shifter.
Used curved bosses and rotated them to get the levers a couple mm's closer to the bars.
John
John
#4421
Just finished this Bob Jackson last night.
Semper fi
Semper fi
#4423
Quoted: 1143 Post(s)
Liked 1,757 Times
A PX10 get some cleansing and is put on a pair of track wheels for shop rolling. Cleaner calipers have replaced the original crusty critters. The hubs original to the purchase have been cut from the rusty spokes and 27" hoops.
Likes For Mr. 66:
#4424
Quoted: 472 Post(s)
Liked 1,041 Times
^^^^^^ Well done. I'm quite pleased that FWs no longer intimidate me. They're easy and quite satisfying when you restore them. I've found that actual wear is from use is rare. It's grit, ancient dried grease and a bit of water that's the problem, easily resolved. If done carefully, they don't even "asplode". BTW, I like those caged bearing assemblies. Nice design.
#4425
Bumped my head.
Working on a 930, but, Im too new to post pics yet. Cmon 10!
Likes For Devilmedic:
