Show us your vintage mountain bikes!
#8101
Quoted: 469 Post(s)
Liked 2,443 Times
I pulled this out of the rafters this morning. I put it away when Thomas quit riding his trailer bike behind it, about ten years ago.
Well, he's finally grown into it. I put some streetish tires on it so he can meet up with his friends at the park.
92? MB-1
92? MB-1
#8102
Bikes: 1984 Miyata 310, 1986 Schwinn Sierra, 2011 Jamis Quest, 1980 Peugeot TH8 Tandem, 1992 Performance Parabola, 1987 Ross Mt. Hood, 1988 Schwinn LeTour, 1988 Trek 400T, 1981 Fuji S12-S LTD, 197? FW Evans
Quoted: 533 Post(s)
Liked 1,007 Times
My son took his 1986 MB-2 to college for five years. Amazingly, it did not get stolen, although it is a little weather beaten. He didn't want to take it to his new job, so I can use it as a blank canvas to play with.
#8103
Quoted: 566 Post(s)
Liked 1,052 Times
Performance MTB
I posted this in the saved from the trash thread. Steel, no bouncy front forks and it doesn’t shift properly but it was free and included a set of knobby tires with tubes. I wiped it down and hosed down the shift levers and derailleurs with WD-40 which helped the shifting but not perfect. The chain rings are shot so it will get new (used?) cranks. Not fancy but not bad for free.
Pre-cleaning pics.
BTW - I know nothing about MTBs and finding appropriate cranks is a minefield. Over thinking it?
Pre-cleaning pics.
#8104
Must be symmetrical
Pre-cleaning pics.
Pre-cleaning pics.
MTB cranks are just a different forest, not really a minefield. Depending on the dropout spacing and some other things, the chainline should be about 47mm-ish, measured to the middle chainring. On a road bike the chainline is measured to point between the two chainrings. Before you take off the cranks, measure the stock chain line. When the cranks are off, measure the spindle. You can get a replacement for the BB if it is running raw based on that.
Otherwise, any modern crank you buy will have a spindle length recommendation and a chainline spec. You can adjust the spindle length recommendation to maintain the stock chainline, if you want, but in reality a few mm doesn't make a big diff on derailleur systems.
If you want to go 1x, use the middle chainring position with the recommended spindle length to achieve the spec chainline.
Regarding the shifters, old rapid fire shifters gum up like crazy. If you want to try again to clean them, open the plastic covers and use a mild degreaser while working all the cams etc inside with tweezers. It can help to heat up the shifter first, warm water or a blow drier works. After the parts are all moving ok, rinse them under hot tap water and shift up and down repeatedly to clear out the solvent. Finally, use a light oil to drive the water out and relube. Don't use grease. WD 40 works, but theoretically will degrade the plastic bits and doesn't leave much lubrication behind when it dries (it was designed as a Water Displacer, to dry aerospace parts, not as a solvent or a lube like everyone uses it today).
I have revived completely stuck units this way.
#8105
Hoards Thumbshifters
Bikes: '23 Black Mtn MC, '87 Bruce Gordon Chinook, '08 Jamis Aurora, '86 Trek 560, '97 Mongoose Rockadile, & '91 Trek 750
Quoted: 246 Post(s)
Liked 338 Times
Pre-cleaning pics.
Pre-cleaning pics.
Pore shifting is more likely caused by rusty chains, the need for new cables and housing, and maybe time to replace shifters. Maybe a cheaper route to investigate first.
Lubing everything can go a long way too from chains to cables to shifters. I like TriFlow for stuff like that but others have different kinds they like.
#8106
Quoted: 566 Post(s)
Liked 1,052 Times
The chain rings on that are almost certainly steel, and don't look all that bad in terms of wear from the pics. Grime, yes, but the teeth look ok. More likely is that your chain is stretched. You could probably get away with popping the cranks off, giving them a really good clean, and replacing the chain. If you get new cranks you should replace the chain, anyway, so it's a 0 risk experiment.
Those are not bad cranks. Just low end. What makes you think they are no longer usable? Those are steel rings, so they should have worn slowly.
I was going to replace the cranks because I’m finding new cranks are cheaper than chainrings. Pic of the big ring. The middle has similar wear.
#8107
Must be symmetrical
But you are right, it is often more cost effective to replace inexpensive cranks sets completely when a ring wears out. But not always. Remember that a new crank set may need a different bottom bracket spindle length, so there is that cost too.
Nice cleaning and polishing job btw.
#8108
Mad bike riding scientist
Quoted: 6220 Post(s)
Liked 4,221 Times
It's Of course hard to tell from a picture, but to me that's not really consequential wear. No tooth on a Hyperglide chain ring or cassette for that matter looks completely like another. That is why they shift well. Really worn teeth look like shark fins.
worn vs unworn by Stuart Black, on Flickr
Stuart Black
Stuart Black
Likes For cyccommute:
#8109
Must be symmetrical
I agree. Here’s a comparison. New on the right, obviously.
#8110
Quoted: 566 Post(s)
Liked 1,052 Times
The top of the cogs are shorter above the “Dual SIS” sticker but mo bettah shifting makes sense. (Most of my fleet is friction shifting, pre 1980.) I’ll continue to clean, lube, etc until I’m happy with it.
#8111
Must be symmetrical
I'm pretty sure it's just Hyperglide being Hyperglide. The teeth are different heights, and none are "full height" in comparison to a classic road chainring pre indexing and/or pre-ramped and pinned.
#8112
Quoted: 2364 Post(s)
Liked 1,751 Times
And?..... IOW, that describes almost every bike posted here. Rigid fork == one less set of moving parts to worry about.
And +1 the above re. the chainrings. They're not minty fresh, but they're most definitely not shark-finned. FIRST place to look if you suspect driveline issues is the chain. A clean, shiny, well-lubed chain that's elongated will still shift poorly. Only way to know is by measurement. START there, along with the obvious derailleur adjustments, etc. BTW, I'm over-generalizing here, but any crankset with removable chainrings is generally of good quality.
Overall a pretty well-appointed bike, free or otherwise. Nice rims. (Front wheel is on backwards.) Wonder who built those frames for Performance BITD.
#8113
Must be symmetrical
#8114
small ring
Quoted: 438 Post(s)
Liked 925 Times
What bars are those? Looks like something that would be about perfect for me.
59 Allegro Special -- 72 Bob Jackson -- 74 Motobecane Grand Jubile -- 74 Sekine SHS 271 -- 80 Nishiki International
#8115
Thrifty Bill
Quoted: 1236 Post(s)
Liked 964 Times
To me, part of the fun of these builds is taking parts out of your bins (ideal), or from the local co-op (2nd choice), and building up a bike you enjoy to ride. As such, sometimes they won't be color matched, or aesthetically pleasing. But if they work for you, great! And if you did it with left over parts, double great. On mine, the stem is a different color than the seat post. So I am breaking some kind of rule there.
#8116
Must be symmetrical
It doesn't necessarily have to be true to the original aesthetic of the bike, or some received wisdom like matching seat post and stem, but it does all have to "work" together based on my goal for a particular build.
#8117
Quoted: 246 Post(s)
Liked 338 Times
#8118
JHD
1984 Ross Mt Hood
I'm guessing an 84 model Mt Hood although some components have an 83 date stamp.
As found original classic down to the tires.
#8119
Must be symmetrical
Look at that! And the wheels are original? The anodizing is spotless. If you are going to ride that, please please get a second pair of wheels so those don't get worn!
Likes For Frkl:
#8120
Pics of that sweet cycle computer mounted at the front wheel please. And looks like a Cannondale velcro mounted water bottle to boot. What a great find!
#8122
JHD
#8123
My favorite
1983
Cunningham Indian
1983
Cunningham Indian
Likes For Fat Tire Trader:
Likes For attylah:
#8125
That's really nice. I wish mine came with the original wheels.
Did the first toptube cable guide pop off, or did the housing just come loose from it?
