Immersive waxing / it should be more popular
#376
Bikes: '23 Poseidon Redwood, '07 Specialized Roubaix Comp Triple, '12 Gravity Fixie, '21 Liv Rove 4, '06? Giant EB Spirit
Quoted: 345 Post(s)
Liked 237 Times
I'll give it a try
I will take the advice of others and start with a new chain so it may be a while before I try it.
I've used White Lightning drip wax before. Loved how clean everything was but hated how quickly I had a squeaky chain - seemed like I had to reapply after every 30 mile ish ride. It was the noise that got to me and I went back to my tried and true Finish Line Dry.
It will be interesting to give this approach a try.
btw, I've tried using coffee and COVID mask filters to filter used mineral spirits. I've even did it multiple times in a row. Nothing seems to get it the liquid clear after a first use for me. Any suggestions? Seems like a waste to use it only once.
Thanks
Thanks
#377
Quoted: 345 Post(s)
Liked 237 Times
Another question
For those of us doing touring: if you were to start your 2000 mile ride with a freshly waxed chain, what would you use to lube it every 100ish miles when it gets squeaky? I’m not trying to be snarky: if it lasts more than that let me know. I can’t see myself reimmersing the chain in wax during a tour
thanks
thanks
#378
Method to My Madness
Bikes: Trek FX 2, Cannondale Synapse, Cannondale CAAD4, Santa Cruz Stigmata GRX
Quoted: 1953 Post(s)
Liked 1,475 Times
In my experience, a waxed chain is good for between 200 and 300 miles, which (shamefully) covers my monthly mileage for most months.
Likes For SoSmellyAir:
#379
Zoom zoom zoom zoom bonk
Bikes: Giant Defy, Trek 1.7c, BMC GF02, Fuji Tahoe, Scott Sub 35, Kona Rove, Trek Verve+2
Quoted: 551 Post(s)
Liked 722 Times
thanks
thanks
Likes For znomit:
#380
ignominious poltroon
Quoted: 2245 Post(s)
Liked 3,449 Times
thanks
thanks
If on-road, I would use DumondTech Lite after about the first 300 miles, and would be very careful about removing the excess.
If off-road, with a lot of grit present, I would probably try Squirt.
#381
Quoted: 426 Post(s)
Liked 274 Times
Thanks
Thanks
Not 100% clear but 1000x times better than trying to filter right after I took out the chain from the jar.
#382
The title merely asks why waxing isn't more popular.
Lots of assertions surrounding a question says to me that the person wanted to voice their opinion, not get an answer to their question. I don't know what the OP thinks he did in his OP, but my bet is that a language scientist would parse it as a provocation. Which worked. I can't see much has been lost.
I've been waxing my chains for close to 40 years. I was an early user of Tri-flow, and it blackened everything that touched it. Wax is much cleaner, IMO, and I don't mind taking the chain off and soaking it in paraffin every so often. But I've tried only 3 processes - oil, Tri-flow, and wax; there are many approaches I haven't tried, and won't. I would not assert that wax is the best lubrication; I do think it's good enough.
Likes For philbob57:
#383
Liked 3,449 Times
OK, the title merely asserts waxing should be more popular.
Likes For SpedFast:
#385
Quoted: 3241 Post(s)
Liked 2,512 Times
I bought six cheap mason jars from amazon. Since I have so many jars it allows me to let the used jar settle for a week then pour most the mineral spirits through a coffee filter into another clean jar.
#386
climber has-been
Quoted: 3432 Post(s)
Liked 3,567 Times
At least in dry conditions.
If the basis is ease of use and minimizing time between applications, not so much.
#387
Quoted: 9656 Post(s)
Liked 6,366 Times
Likes For Mojo31:
#388
Quoted: 345 Post(s)
Liked 237 Times
I took the plunge
Bought all the goods and thoroughly degreased chainrings, cogs and jockey wheels (surprisingly dirty!).
I’ll report back
ordered a new SRAM chain but may try my used Shimano since I had it go through several mineral spirit and acetone soaks. I hear Shimano chains may not be great for this application due to wax not sticking.
im going to use straight Gulf canning wax btw
I’ll report back
#389
Liked 3,449 Times
I've only used Shimano chains and straight Gulf canning wax. You will be fine.
Likes For Polaris OBark:
#390
Quoted: 345 Post(s)
Liked 237 Times
Originally Posted by Polaris OBark;[url=tel:22642001
22642001[/url]]I've only used Shimano chains and straight Gulf canning wax. You will be fine.
#391
Liked 1,475 Times
#392
thanks
thanks
As for the chains, I use coated YBN and Shimano chains, no dramas.
Likes For yaw:
#393
Quoted: 345 Post(s)
Liked 237 Times
First impressions
Haven’t ridden it yet but I found the process of cleaning/degreasing the drive train and chain a lot of work. The waxing of the chain wasn’t too bad actually but the loosening of the “frozen” waxed chain was annoying. The part that really was a pain was attaching the waxed quick link. I found I had to scrape off wax from several tight spots to get it to lock. Even then it took quite a while to get it to lock properly. I was using a KMC quick link. I tried and failed using SRAM’s quick link supplied with the chain.
I know there is a learning curve but so far I’m not impressed with the ease of the process. I learned a few tricks to speed it up next time.
im also not too impressed with the look of the furry” wax on the chain after breaking the wax free. I assume this will fall off as I ride.
my $0.02
my $0.02
#394
Liked 1,475 Times
A little wax is not going to prevent the quick link from locking if you use this tool: Amazon.com : Super B 2-in-1 Master Link Pliers (The Trident) : Sports & Outdoors
Some fall off. Some stick to the RD pulleys but is easy to brush off if the bike is on the stand.
#395
Quoted: 345 Post(s)
Liked 237 Times
Excellent ideas
Originally Posted by SoSmellyAir;[url=tel:22643357
22643357[/url]]I clamp an old wooden broom handle in my Feedback Sports Ultralight work stand, rotate the clamp so that the broom handle is horizontal (and parallel to the ground). I drape the chain over the broom handle and drag the chain over the broom handle while holding both ends of the chain. Flip chain over and repeat.
I wax the chain with the quick link separately attached, by looping a wire (from the inside of a twist tie) around the groove near the protruding end of the pin. But next time I will just wax the chain with the quick link closed.
I like your idea about waxing with the quick links on the chain that might work better
#396
Fat n slow
Quoted: 3259 Post(s)
Liked 2,085 Times
I’ve only ever had a problem with the quick link when I was using the Silca bag in boiling water, once I switched to the crock pot method, I just hang the chains from one of the adjustment rods on my stand and break the links on the stand itself.
#397
Liked 3,449 Times
I've never waxed the quick-link. I just remove the wax from the ends, put the pins in a few times to push out the residual wax, and then close it with the Park tool.
#398
carbon is too light
Bikes: Yes.
Quoted: 103 Post(s)
Liked 250 Times
Haven’t used this wax for almost two years. It’s just been sitting in the crock pot. It used to come out sorta opaque white, today it came out brown and sorta crusty… What happened?? Yes, my chain was and stripped from all grease prior to this.
#399
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
Wow...that looks great.
#400
Quoted: 345 Post(s)
Liked 237 Times
also, I think it is possible to overheat the wax. Not sure if that could cause this though.
