Drop your heels!
#101
Bikes: Trek Madone 5.2 SL 2007, Look KG386, R022 Re-framed Azzurri Primo, Felt Z5, Trek F7.3 FX
Quoted: 405 Post(s)
Liked 85 Times
I am not saying that the way I described above is the only way. I cycled simply by pushing the pedals for about 18 years.
I find that the new method of pushing forwards,with my femur on my saddle and then trebuchet-ing backwards with my glutes
propels me as fast as I have ever been in my life, now at nearly 58, and gives me a good glute exercise, thus protecting
my knees and hip joints (I find it is weak knees that leads to old person knee pain). I wish I had known sooner, but other
than "heel down," "scrape the mud off your feet" and some important advice by Carbonfibreboy, there was very little
information that I could find.
![timtak is offline](images/statusicon/user_offline.gif)
#102
pan y agua
Quoted: 1483 Post(s)
Liked 768 Times
So any actual data? You feel faster great. If it works for you fine, but there are tons of studies out there that all the various pedal thoughts don’t make an actual difference.
if we had someway to define your before and after pedal styles, then time and speed data over the same fixed course, with power,heart rate, and perceived effort over multiple efforts, then we’d at least have a study of one. Do the same thing with hundreds of cyclists, and hundreds of repeats, then we might be on to something.
However, all the data I’ve seen trying to look at pedaling style, it just doesn’t make a difference.
You could get lost and die.
You could hit a tree and die.
![merlinextraligh is offline](images/statusicon/user_offline.gif)
#103
pan y agua
Liked 768 Times
As for my own anecdotal evidence, I’ve raced on and off for 40 years, and worked with a number of professional coaches, including guys who have coached elite pro tour level athletes, done a number of training camps, and it’s just never been an issue about you heel angle or pedaling like a midevil siege weapon.
Some fast pedal drills and one legged drills in the early season is about as sophisticated as work on pedal dynamic has been in my experience.
And I was faster in my 50’s than my 20’s not by coming up with a pedaling gimmick, but by doing a lot of structured interval work, and racing against faster people.
Likes For merlinextraligh:
#104
Quoted: 405 Post(s)
Liked 85 Times
#105
pan y agua
Liked 768 Times
You night as we’ll be chanting a mantra as you pedal( which is fine if it works for you).
All that said, the people who have actually tried to study this with decent study protocols have t come up with data to support it.
#106
Quoted: 405 Post(s)
Liked 85 Times
You’re missing the point. You may well be faster than you were 10 years ago. And you may believe it’s because you’ve captured a Monty Pythonesque force. Without controlled results, it’s impossible to draw any conclusion.
I do chant a mantra, but not to improve my speed.
Tim
#107
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2751 Post(s)
Liked 6,106 Times
I won't drop my heals, or flats, for anyone. I stay on the level except climbing out of the saddle. Then who knows and who cares.
Road 🚴🏾♂️ & Mountain 🚵🏾♂️
![rsbob is offline](images/statusicon/user_offline.gif)
#108
Quoted: 4084 Post(s)
Liked 7,671 Times
![tomato coupe is offline](images/statusicon/user_offline.gif)
Likes For tomato coupe:
#109
Quoted: 405 Post(s)
Liked 85 Times
Unfortunately it seems that the free version of Strava does not allow me to compare my times any more in the free version and I don't think I want to pay. For the time being I can only say that subjectively I am going like a rocket, using my 53 11 gears as in days of yore.
I have a 360 camera so I think I will make a video explaining the old-school Frenchy technique while riding.
For the time being here is a diagram for those that may be interested, I wish I had found more instruction many years ago myself.
Put your femur on the back of your saddle, by standing on your pedals and clamping your thighs together like you want to pee, and then sit on your saddle with the top of your thighs.
Rotate your hips so that you can stomp forwards, raising your knees very slightly perhaps as you do so (1 in diagram below)
Stomp forwards. Since your femur is resting on your saddle you will not be able to stomp down quite to the 6 O'clock position.(2 in diagram). Your heels may not actually drop, but it will feel that way since you will feel you are pushing the pedal forwards rather than down.
Adjust the lever position so that the end of your forward stomp corresponds to about the 4:30 to 5 position
Use your glutes to pull upwards to catapult (or trebuchet) yourself forwards for the last part of the cycle ( 3 in diagram below) using the rear of the saddle as a lever.
Rock your femur on the lever of the saddle to turn yourself into a rocket.
Channel Eddy Merx (who is Belgian)
![](https://cimg9.ibsrv.net/gimg/bikeforums.net-vbulletin/295x546/cycling_a43d219d71cc1df0ee5d62f44151943bb3c2d468.jpg)
French-y Pedalling, femur supported by saddle
If you are a solo cyclist, whatever you do, avoid riding like the pros of today because they ride in groups (making cycling a group activity, which it always was but more so) using radio controlled pace lines, taking turns at sprinting at the front and then using the slip stream while on the hoods behind. If you are not riding in a group, either adjust your bike to turn it more into a time trial bike and pedal like the pros except in a more aero position, or go old school and Frenchy as described above and pictured below.
![](https://live.staticflickr.com/2661/4149915787_b0f2f06cac.jpg)
Merckx_1967 by Chris Protopapas, on Flickr
#110
Liked 7,671 Times
This thread is destined to be a classic.
#111
pan y agua
Liked 768 Times
So some actual data. https://citeseerx.ist.psu.edu/docume...d315ae96e1b905
Conclusion of that study, and a summary of the literature it cites is that a wide range of pedaling dynamics will produce close to optimal power, with the only exception being over doing ankling will decrease your power output.
#112
Klaatu..Verata..Necktie?
Quoted: 10660 Post(s)
Liked 12,332 Times
No, he's saying there are too many confounding variables for your data to be of any use. I'm faster than I was 10 years ago, but I'm also riding more than twice as much and paying more attention to my training. I also adjusted my saddle up about 3mm. So, which variable is responsible for the improvement?
![genejockey is offline](images/statusicon/user_offline.gif)
#113
Quoted: 4717 Post(s)
Liked 1,882 Times
This is something I struggle with. Not sure why but I have to actively think about dropping my heels throughout my pedal strokes. I usually don’t do it. I have a bike fit. My bike is comfortable to me. I just know that you’re supposed to drop your heels and recently a rider last Saturday told me that I should drop my heels while riding. Is there a way to train myself to change my pedal strokes so that it becomes natural?
![noodle soup is offline](images/statusicon/user_offline.gif)
#114
Quoted: 405 Post(s)
Liked 85 Times
It seems to me that sprint cycling is close to what the professional races have turned into: a sprint relay. The peloton and even pace lines create a situation in which even the person in pole position has reduced drag, and those following are dragged along. This means that with radios and cooperation, if the person in pole position gets down low with horizontal forearms on an "aero-road" he can provide drafting to team mates for 6 minutes (or perhaps two times 3? or three times 2?) an hour with the rest of his team following in his wake on the hoods.
Sprint cycling has always, afaik, been done by getting down low and forwards and push pushing with ones thighs (and pulling on the drops with ones upper body) in true sprints, and in the modern sprint-relay peloton.
I have never ridden in a group so data regarding that type of cycling is not much use to me.
As the study shows, ankling is a bad idea in a sprint.
Get forwards on your drops and push backwards! Use your upper body to pull too.
I see a forum as a place where people can exchange their suggestions and help and advice, hopefully.
#115
pan y agua
Liked 768 Times
So one year and 114 posts and no one has come up,with any data to show how you pedal much matters. From that absence of data, the combined expereince of most of the posters here, and the observation that different styles seem to work well for different professional cyclists, the answer appears to be pedal the way you feel comfortable with.
With power meters that can measure torque and angular velocity at multiple points of the pedal stroke, the tools are there to determine whether how you pedal makes a difference. If it did we would certainly have some data to support it. Yet pretty much every idea about a magic way to pedal ( for example that you can produce power on the upstroke) has been debunked.
If you care about your pedal stroke, do some high cadence drills, one legged drills, and best of all rider on rollers.
There’s no need to overthink this.
#116
Quoted: 2664 Post(s)
Liked 3,229 Times
![Trakhak is offline](images/statusicon/user_offline.gif)
#117
climber has-been
Quoted: 3607 Post(s)
Liked 3,797 Times
Sprint cycling has always, afaik, been done by getting down low and forwards and push pushing with ones thighs (and pulling on the drops with ones upper body) in true sprints, and in the modern sprint-relay peloton...
"Push backwards"? I don't see how any sprinter is pushing backwards. They are pushing down on their pedals, with their centers of mass over the pedals. They are not pulling with their upper bodies.
![terrymorse is offline](images/statusicon/user_offline.gif)
Likes For terrymorse:
#118
Liked 3,229 Times
As terrymorse said: you don't pull up on (both sides of) the handlebars (simultaneously).
The way Cavendish puts it at about 3:00, you alternate pulling up on the two sides of the handlebars to rock the bike and, quote, "bring the bike to your feet."
#119
Quoted: 405 Post(s)
Liked 85 Times
However, what I am finding now is that using my glutes in the way described (placing the top of ones femur on the saddle and then pulling upwards with ones glutes to create an upside down trebuchet catapult) that I am using my glutes in the last part of the down-swing not on the up-swing.
The advantage is that I am using two muscle groups. I am sure that in a sprint or relay sprint, this method is still slower because my quads are faster but using two muscle groups but (as described by CarbonFibreBoy) it may have advantages on long periods of high power such as climbs, and I think breakaways. I am always in a breakaway since I ride alone.
I think a power meter alone would find it difficult to measure this. One would need sensors on the muscles themselves to sense which ones are firing.
No, sprinters don't pull up on the drops. They rock the bike from side to side. "Push backwards"? I don't see how any sprinter is pushing backwards. They are pushing down on their pedals, with their centers of mass over the pedals. They are not pulling with their upper bodies. Slow motion sprint finish
It is difficult to tell whether they are using their upper bodies or not but since I use my upper body in that position on climbs, and as you say he rocks the bike from side to side, (claiming he does for another mundane reason) but I think he is using his upper body muscles to pull upwards on the drops as he pushes, so that he can push more than would be possible using gravity as the thing he is pushing against alone. Please see Cavendish at 0:53 in Green here.
I think that this is why Cavendish is so fast. The little man (well, he is my height) worked out how to use his whole body. It was a secret until you read it here! (Or maybe, as you say, it is my mistake).
Sorry, no, not a secret! Others opine similarly here
https://www.bikeforums.net/road-cycl...-strength.html
#120
Quoted: 405 Post(s)
Liked 85 Times
How To Sprint Like Mark Cavendish – Cav's Top 5 Sprinting Tips
I did not mean to suggest that one pulls on both sides of the bars simultaneously but as you say, alternately.
But in the video Cavendish only mentions "bringing the bike to the feet" as if that is the only reason for the side to side rock. He does not mention that he is pulling on the bars. I agree with Trakhak that Cavendish is pulling.
I am guessing again that Trakhak probably pulls on the bars too. Do you?
I only do it on climbs but I just had a go today. It would take practice.
I had a go today on my way home. If you pull on the bars (alternately [of course]) then you rock. I rocked.
#121
pan y agua
Liked 768 Times
Cavs was fast because it produced good power in relation to his size, had a very aerodynamic position, and was a great tactician.
His power numbers were not spectacular compared to other top level sprinters
#122
Quoted: 405 Post(s)
Liked 85 Times
@merlinextraligh
You may be right but, I still think that Cavendish uses his upper body to pull as well as push with his legs, more than most sprinters.
Try getting out of your saddle in the drops and pull as you push on your pedals. I think you will find you rock from side to side.
Cavendish may rock for (many) other reasons but my conspiracy-ish theory is that he is not admitting the extent to which the rock is a result of his being a puller.
Tim
Tim
#123
Quoted: 4645 Post(s)
Liked 5,180 Times
![PeteHski is offline](images/statusicon/user_offline.gif)
#124
Liked 7,671 Times
#125
Liked 5,180 Times
